Chris127 Posted November 24, 2014 Share #1 Posted November 24, 2014 Received my track worker letter mail and they gave me 10 extra points i dont know why? Link to comment Share on other sites More sharing options...
dp142 Posted November 24, 2014 Share #2 Posted November 24, 2014 I gave an answer in the Track Worker heading in this section. Take a look. I copied and pasted, LOL All I could think of is some answers were contested and as opposed to one correct answer they allow two and now one answer you may have been scored as wrong was now re-scored as a correct answer. It has happened.I myself contested 9 proposed answers on a promotional and had eight changed. Now there were two correct answers.I wouldn't say anything if or when your called. Those 10 points can put you one or two numbers ahead and make a huge difference when called. Chances are others were given the credit also. 0 Quote MultiQuote Link to comment Share on other sites More sharing options...
Chris127 Posted November 24, 2014 Author Share #3 Posted November 24, 2014 Thanks for the info @dp142 and I'm not saying nothing about it plus I'm pretty high up there Link to comment Share on other sites More sharing options...
dp142 Posted November 25, 2014 Share #4 Posted November 25, 2014 When a friend of mine and myself took the Track worker exam back in the early 90's he was ahead of me by about 50 numbers. I thought "ok" I'll be a few months after him. Next class maybe. I was wrong! It was 2 years later When I called. Link to comment Share on other sites More sharing options...
dp142 Posted November 25, 2014 Share #5 Posted November 25, 2014 When a friend of mine and myself took the Track worker exam back in the early 90's he was ahead of me by about 50 numbers. I thought "ok" I'll be a few months after him. Next class maybe. I was wrong! It was 2 years later When I was called. Link to comment Share on other sites More sharing options...
Chris127 Posted November 25, 2014 Author Share #6 Posted November 25, 2014 So the closer the sooner is what your basically saying? Link to comment Share on other sites More sharing options...
dp142 Posted November 25, 2014 Share #7 Posted November 25, 2014 Yes. The lower your number the quicker you are called. As I said, my friend and I were only 50 numbers apart and I waited two years to be called. Somewhere between his number and mine they stopped calling. Link to comment Share on other sites More sharing options...
Jsalcedo718 Posted January 27, 2016 Share #8 Posted January 27, 2016 <p><p> I gave an answer in the Track Worker heading in this section. Take a look. I copied and pasted, LOL All I could think of is some answers were contested and as opposed to one correct answer they allow two and now one answer you may have been scored as wrong was now re-scored as a correct answer. It has happened. I myself contested 9 proposed answers on a promotional and had eight changed. Now there were two correct answers. I wouldn't say anything if or when your called. Those 10 points can put you one or two numbers ahead and make a huge difference when called. Chances are others were given the credit also. 0Quote MultiQuote How do people contest answers on the open competitive test? I never understood how that worked...how do people memorize what questions they wanted to contest after they took the test, in order to know what answer should've been in their favor? Link to comment Share on other sites More sharing options...
dp142 Posted January 27, 2016 Share #9 Posted January 27, 2016 From when I was taking civil service tests you would recieve your answer key in the mail once the answers were released and the question numbers with answers were printed in the chief. The bottom had a slip you could send in to protest. You would then go in when notified and they give you your booklet used for the exam tho see which ones you had wrong. If you had some short of proof that your answer was the correct one you would fill out an appeal slip making your case and then wait tho be notified of the results in the mail. Link to comment Share on other sites More sharing options...
Jsalcedo718 Posted January 27, 2016 Share #10 Posted January 27, 2016 From when I was taking civil service tests you would recieve your answer key in the mail once the answers were released and the question numbers with answers were printed in the chief. The bottom had a slip you could send in to protest. You would then go in when notified and they give you your booklet used for the exam tho see which ones you had wrong. If you had some short of proof that your answer was the correct one you would fill out an appeal slip making your case and then wait tho be notified of the results in the mail. Oooh I see now. Thanks for the info. Much appreciated. Link to comment Share on other sites More sharing options...
