TrainFanatic Posted February 28, 2010 Share #1 Posted February 28, 2010 What is the top speed limit in the New York City Subway? Link to comment Share on other sites More sharing options...
bveguy Posted February 28, 2010 Share #2 Posted February 28, 2010 50 MPH, but most tend to go faster. Link to comment Share on other sites More sharing options...
INDman Posted February 28, 2010 Share #3 Posted February 28, 2010 50 MPH, but most tend to go faster. So then how is that the top speed if trains go faster? The top speed that a subway car can travel on level ground is 55 MPH. In some river tubes, like the 60th Street tube, trains have been known to go fast, into the 60s. Link to comment Share on other sites More sharing options...
TrainFanatic Posted February 28, 2010 Author Share #4 Posted February 28, 2010 50 MPH, but most tend to go faster. Thanks! Link to comment Share on other sites More sharing options...
BroadwayBuffer Posted February 28, 2010 Share #5 Posted February 28, 2010 The maximum attainable speed of most equipment has usually been considered 55 MPH. Although today there are few places where they can reach that speed due to timers, etc. No, they don't tend to go faster than 50. Link to comment Share on other sites More sharing options...
TrainFanatic Posted February 28, 2010 Author Share #6 Posted February 28, 2010 So then how is that the top speed if trains go faster? The top speed that a subway car can travel on level ground is 55 MPH. In some river tubes, like the 60th Street tube, trains have been known to go fast, into the 60s. Thanks also but I meant the top speed limit in which T/O's are suppose to obey. Link to comment Share on other sites More sharing options...
2 Train Master Posted February 28, 2010 Share #7 Posted February 28, 2010 I would say the top speed limit is about 60-65mph but in some spots or most fast runs you can hit 40-55mph. Link to comment Share on other sites More sharing options...
bveguy Posted February 28, 2010 Share #8 Posted February 28, 2010 So then how is that the top speed if trains go faster? The top speed that a subway car can travel on level ground is 55 MPH. In some river tubes, like the 60th Street tube, trains have been known to go fast, into the 60s. Read carefully and you'll see what he's trying to ask. Link to comment Share on other sites More sharing options...
INDman Posted February 28, 2010 Share #9 Posted February 28, 2010 Thanks also but I meant the top speed limit in which T/O's are suppose to obey. The fastest speed sign I have seen was for 45 MPH, but that is only a suggestion. In a river tube, unless you have timers or some other speed restriction, you go as fast as the equipment will go. Link to comment Share on other sites More sharing options...
St Louis Car 09 Posted February 28, 2010 Share #10 Posted February 28, 2010 I remember clocking 55 in R38 throught the east river tubes.but at one point the R46 had hostler controls which was good in theory,but due to a rear end colission it was disabled and speed limits were implemented throughout certain parts of the system. Link to comment Share on other sites More sharing options...
INDman Posted February 28, 2010 Share #11 Posted February 28, 2010 I remember clocking 55 in R38 throught the east river tubes.but at one point the R46 had hostler controls which was good in theory,but due to a rear end colission it was disabled and speed limits were implemented throughout certain parts of the system. What was so bad about the hostler, it did not let you go faster then normal. Link to comment Share on other sites More sharing options...
St Louis Car 09 Posted February 28, 2010 Share #12 Posted February 28, 2010 What was so bad about the hostler, it did not let you go faster then normal.Yeah true,but since its specific purpose was for ATO in terms of speed control,but what happened was that near Queens Plaza where the G meets with the R eastbound,an R46 collided with another as the train failed to slow down resultng n the collision and ultimately the removal of all hostler controls of the R46. Link to comment Share on other sites More sharing options...
Zman Posted February 28, 2010 Share #13 Posted February 28, 2010 There is no maximum speed limit in the NYC Subway System. If no speed limit sign is posted (with no switches, timers, or any other speed restrictions ahead), then you move as fast as you possibly can. Link to comment Share on other sites More sharing options...
St Louis Car 09 Posted February 28, 2010 Share #14 Posted February 28, 2010 There is no maximum speed limit in the NYC Subway System. If no speed limit sign is posted (with no switches, timers, or any other speed restrictions ahead), then you move as fast as you possibly can.But they are governors on the train that wouldnt allow you to achieve a higher speed.So really there is a speed limit thanks to the governor:mad: Link to comment Share on other sites More sharing options...
INDman Posted February 28, 2010 Share #15 Posted February 28, 2010 But they are governors on the train that wouldnt allow you to achieve a higher speed.So really there is a speed limit thanks to the governor:mad: Not really since different equipment have different "tops speeds", if there was a speed limit, everything thing would have the same max speed. Link to comment Share on other sites More sharing options...
St Louis Car 09 Posted February 28, 2010 Share #16 Posted February 28, 2010 Not really since different equipment have different "tops speeds", if there was a speed limit, everything thing would have the same max speed.You have a point.I know some of the equipment range between 55 and 65 tops. Link to comment Share on other sites More sharing options...
JFK 7212 Posted February 28, 2010 Share #17 Posted February 28, 2010 Top speed for local trains is 30mph.Top speed for express trains is 35-40mph. Link to comment Share on other sites More sharing options...
SubwayGuy Posted February 28, 2010 Share #18 Posted February 28, 2010 What is the top speed limit in the New York City Subway? IIRC, Fastest posted: 50 MPH in the 60th St tube. However as Zman said if no speed limit is posted, there is none. Link to comment Share on other sites More sharing options...
SubwayGuy Posted February 28, 2010 Share #19 Posted February 28, 2010 Yeah true,but since its specific purpose was for ATO in terms of speed control,but what happened was that near Queens Plaza where the G meets with the R eastbound,an R46 collided with another as the train failed to slow down resultng n the collision and ultimately the removal of all hostler controls of the R46. I thought the issue with that one was that the first few cars were cut out due to mechanical issues, so the train was being operated from other than head end, and the agreed upon signal procedure was to use a flashlight to signal the operator. When this didn't work and the train ran the red it didn't dump (because the the first cars were cut out), and plowed into the train ahead that was crossing over the switch. Link to comment Share on other sites More sharing options...
Fresh Pond Posted February 28, 2010 Share #20 Posted February 28, 2010 I thought that's what happened too Link to comment Share on other sites More sharing options...
INDman Posted February 28, 2010 Share #21 Posted February 28, 2010 I thought the issue with that one was that the first few cars were cut out due to mechanical issues, so the train was being operated from other than head end, and the agreed upon signal procedure was to use a flashlight to signal the operator. When this didn't work and the train ran the red it didn't dump (because the the first cars were cut out), and plowed into the train ahead that was crossing over the switch. I think your talking about the Roosevelt Ave wreck back in the 70's. Link to comment Share on other sites More sharing options...
St Louis Car 09 Posted March 1, 2010 Share #22 Posted March 1, 2010 I think your talking about the Roosevelt Ave wreck back in the 70's.Thats the incident I was refering to which caused the(NYCT) to disable the hostler controls. Link to comment Share on other sites More sharing options...
INDman Posted March 1, 2010 Share #23 Posted March 1, 2010 Thats the incident I was refering to which caused the(NYCT) to disable the hostler controls. I was responding to Subwayguy. I know the incident you speak of is different. Link to comment Share on other sites More sharing options...
St Louis Car 09 Posted March 1, 2010 Share #24 Posted March 1, 2010 I was responding to Subwayguy. I know the incident you speak of is different.I know but I think that incident he mentioned was the one I was telling. Link to comment Share on other sites More sharing options...
Zman Posted March 1, 2010 Share #25 Posted March 1, 2010 Thats the incident I was refering to which caused the(NYCT) to disable the hostler controls. Sorry St.Louis, but you're mistaken. The Roosevelt Av crash did not involve R46's. From nycsubway.org : An empty Brooklyn bound GG train running on the southbound local track (D1) crashed into another GG train west of Roosevelt Avenue that was crossing from the southbound express track (D3) to the southbound local track (D1). The empty GG had left Continental Avenue at 7:13 AM and developed brake trouble. Passengers were discharged at Woodhaven Boulevard and the first two cars were cut out. The motorman then operated the train from the third car with the conductor signaling with a flashlight from the front of the train. Because of the stalled train southbound EE and GG trains were routed to the express track (D3) and then crossed back over to the local track (D1) west of Roosevelt Avenue. The home signal tripper on the local track (D1) was working but as the empty train was running with the first two cars cut out it did not engage the trip cock in time. The empty train rammed into the train crossing over to the local track between the 6th and 7th cars. Two passengers were killed and 77 injured. The motorman, conductor, and an inspector were held responsible by an inquiry. The consist of the empty train was 4501-0, 4043-2, 3992-3, 4548-9 . Note that this was a mixed consist of R-38, R-40M and R-42. R-40M 4501 was badly damaged. The rerouted GG train had cars 6344-6492-6318-6469-6304-6468-6315-6355 . 6304 was so badly damaged that she was cut up on the spot. 6468 was moderately damaged. The other six R-16s were back in service in a week. The R46 hostlers were removed after SMS in the early 90's. Link to comment Share on other sites More sharing options...
