dolowicz Posted October 13, 2011 Author Share #51 Posted October 13, 2011 Where is this you're talking about? the ramps, stairs and escalators leading down to the platform? Yes, I am talking about the ramps at the IRT Flushing station – sorry if I was unclear. There are still some ramps intact, although unaccessible to the public. The one I was referring to however, was closed to the public long before the rehabilitation of the complex started but should still be there, probably used for storage or similar. Link to comment Share on other sites More sharing options...
dolowicz Posted October 13, 2011 Author Share #52 Posted October 13, 2011 Where is this you're talking about? the ramps, stairs and escalators leading down to the platform? Yes, I am talking about the ramps at the IRT Flushing station – sorry if I was unclear. There are still some ramps intact, although unaccessible to the public. The one I was referring to however, was closed to the public long before the rehabilitation of the complex started but should still be there, probably used for storage or similar. Link to comment Share on other sites More sharing options...
Eric B Posted October 13, 2011 Share #53 Posted October 13, 2011 Oh, I knew they completely reconfigured that area, and I thought removed some ramps and escalators (like now, you can go straight across on that middle level, and you couldn't do that before. It was a real maze back in the day), but I didn't know anything was closed off (other than the construction barriers during the work). Link to comment Share on other sites More sharing options...
Eric B Posted October 13, 2011 Share #54 Posted October 13, 2011 Oh, I knew they completely reconfigured that area, and I thought removed some ramps and escalators (like now, you can go straight across on that middle level, and you couldn't do that before. It was a real maze back in the day), but I didn't know anything was closed off (other than the construction barriers during the work). Link to comment Share on other sites More sharing options...
dolowicz Posted October 13, 2011 Author Share #55 Posted October 13, 2011 Oh, I knew they completely reconfigured that area, and I thought removed some ramps and escalators (like now, you can go straight across on that middle level, and you couldn't do that before. It was a real maze back in the day), but I didn't know anything was closed off (other than the construction barriers during the work). You could see the boarded up ramps up until around 2005. Coming down the first two sets of ramps from the western side of the IRT Flushing station, you would then see the single escalator on your left side and then straight ahead you could see that the ramp continues down, but the entrance is completely sealed up. So you would instead have to go left at the bottom and loop around the escalator and at the bottom you would reach the lower mezzanine level of the Flushing station. One staircase down and you would be at track level and there you could also see the single staircase leading up to the sealed off ramps. Attaching a photo that shows this part, straight ahead you can see the boarded up ramp part. This would if opened up go straight down and then make a u-turn, dip down further and then meet up with the platform staircase. Link to comment Share on other sites More sharing options...
dolowicz Posted October 13, 2011 Author Share #56 Posted October 13, 2011 Oh, I knew they completely reconfigured that area, and I thought removed some ramps and escalators (like now, you can go straight across on that middle level, and you couldn't do that before. It was a real maze back in the day), but I didn't know anything was closed off (other than the construction barriers during the work). You could see the boarded up ramps up until around 2005. Coming down the first two sets of ramps from the western side of the IRT Flushing station, you would then see the single escalator on your left side and then straight ahead you could see that the ramp continues down, but the entrance is completely sealed up. So you would instead have to go left at the bottom and loop around the escalator and at the bottom you would reach the lower mezzanine level of the Flushing station. One staircase down and you would be at track level and there you could also see the single staircase leading up to the sealed off ramps. Attaching a photo that shows this part, straight ahead you can see the boarded up ramp part. This would if opened up go straight down and then make a u-turn, dip down further and then meet up with the platform staircase. Link to comment Share on other sites More sharing options...
Ceya Posted October 15, 2011 Share #57 Posted October 15, 2011 You mean the exit in the 8th Avenue passageway? Probably not because of crime, because a manned exit / entrance would probably discourage crime. There was however a sealed up ramp at the far side of the complex that probably closed in the early 1980s for crime reasons. It lead to the eastern most staircase (which was also blocked off). It could be seen up until the recent renovations, and the ramp is probably intact behind the new staircase and escalator which was installed then. It was closed up by early mid 90s (92-95). That closed off ramp was a maze, we used to ride bikes down it late nights. Like 14th st tunnel from 7th to 8th aves. Sometimes to 6th ave. With so many people now , there is no space to get around the system. Those stairs were long to walk up though. Feel like a rat in a maze. S/F, CEYA! Link to comment Share on other sites More sharing options...
Ceya Posted October 15, 2011 Share #58 Posted October 15, 2011 The above clip shows Times Square around 1999 before the recent renovations. If you jump 59 seconds into it, you can see the big set of stairs leading up from the BMT mezzanine up to the shuttle and transfer to the IRT lines. On the left side next to it you can kind of make out a very narrow passage, this is the same location as on the diagram that would ramp down and have a door at the other end. It would have to ramp down to actually even be able to house a mezzanine underneath the shuttle platforms. That part of the video was the stairs that was in front of the Florist after passing the Salsa shop. It was leading to the shuttle, if you watch the ladies turn they will be heading toward the IRT. If they went right was an entrance/exit, and the old Knickerbocker Hotel entrance door. If they walked straight it would have taken them to the shuttle and they old entrance to 1 Times Sq entrance and exit. S/F, CEYA! Link to comment Share on other sites More sharing options...
dolowicz Posted October 15, 2011 Author Share #59 Posted October 15, 2011 It was closed up by early mid 90s (92-95). That closed off ramp was a maze, we used to ride bikes down it late nights. Like 14th st tunnel from 7th to 8th aves. Sometimes to 6th ave. I always imagined there were a lot of skateboarders and bikers riding down the ramps in the 70s and 80s. If you got any photos of this complex from before the last rehab, I would love to see them! Link to comment Share on other sites More sharing options...
dolowicz Posted May 21, 2015 Author Share #60 Posted May 21, 2015 Long time, I never got those photos. Anyone got any more info to add to this thread? Link to comment Share on other sites More sharing options...
RollOver Posted May 21, 2015 Share #61 Posted May 21, 2015 I know you created this thread and all, but honestly, why did you revive it when it's been 5 years old now? That's still considered necroposting regardless. Link to comment Share on other sites More sharing options...
Javier Posted May 21, 2015 Share #62 Posted May 21, 2015 It's really not necessary to revive this thread if you have a question. Your could just use the "Random Thought" thread. Link to comment Share on other sites More sharing options...
Wallyhorse Posted May 21, 2015 Share #63 Posted May 21, 2015 I know you created this thread and all, but honestly, why did you revive it when it's been 5 years old now? That's still considered necroposting regardless. I never saw this thread previously and found it quite interesting. Link to comment Share on other sites More sharing options...
biGC323232 Posted May 22, 2015 Share #64 Posted May 22, 2015 Wow i wasn't even a member then Link to comment Share on other sites More sharing options...
Fresh Pond Posted May 22, 2015 Share #65 Posted May 22, 2015 Neither was RollOver or Javier... Back in the before era, where things were (somewhat) more peaceful lol Link to comment Share on other sites More sharing options...
Javier Posted May 22, 2015 Share #66 Posted May 22, 2015 I wish I was older now XD Link to comment Share on other sites More sharing options...
RollOver Posted May 22, 2015 Share #67 Posted May 22, 2015 Neither was RollOver or Javier... Back in the before era, where things were (somewhat) more peaceful lol Yeah wow, just wow, well excuse me for being *stupid* enough to not notice and shouldn't have said anything at all... Link to comment Share on other sites More sharing options...
Fresh Pond Posted May 22, 2015 Share #68 Posted May 22, 2015 Yeah wow, just wow, well excuse me for being *stupid* enough to not notice and shouldn't have said anything at all... No need to be condescending about it. It was a simple statement, get out of your feelings already Link to comment Share on other sites More sharing options...
dolowicz Posted May 23, 2015 Author Share #69 Posted May 23, 2015 Sorry, didn't realize anyone would take offense for reviving this topic. Instead of spreading things out, I thought it would better to condense it all within one thread, but that's just me. Link to comment Share on other sites More sharing options...
