N6 Limited Posted October 11, 2017 Share #1051 Posted October 11, 2017 1 hour ago, RailRunRob said: I think so as well.. Logically it makes sense I just don't have the Math to Verify (TPH ect). I've gotten pushback on the idea mostly on Premise of the East River tubes being at capacity. But in my mind if you added to more two more tubes on the Hudson side. And locked 2 tracks for each direction I don't see the issue. Take a few tracks out at Penn and widen the platforms that should cut on dwele times. Where the trains go? Some to Sunnyside , Jamaica, Huntspoint? Secaucus, Newark Penn? Seems workable again i'd have to understand headways And scheduling I can probably run a simulation from that. I'm thinking that these trains can replace existing NJT trains between Secaucus and Penn, and Existing LIRR trains between Penn Station and Jamaica, it'll be a more efficient use of track capacity. Run the thru service, and people can make connections to whatever branch they need at the normal transfer points. I mean if using Secaucus as a terminal is a problem they can they can have a train go from Trenton to Jamaica, or say a "Beach Train" in the summer that goes from Bay Head, NJ on the North Jersey Coast Line to Long Beach, NY 1 Quote Link to comment Share on other sites More sharing options...
Truckie Posted October 11, 2017 Share #1052 Posted October 11, 2017 3 hours ago, RailRunRob said: I've seen a few trains over the years they seemed Moderately full.. maybe 60-75% full. Maybe it was an operation thing? Crew Scheduling? Not sure of the exact reason but heard it was something on NJT's end. Crew scheduling on MNR's side was covered on the extra list. I don't know how NJT handled their scheduling. It was their rolling stock used . Might have been something with equipment cycles. Again, can't say for sure. 1 Quote Link to comment Share on other sites More sharing options...
paulrivera Posted October 12, 2017 Share #1053 Posted October 12, 2017 (edited) 1 hour ago, Truckie said: Not sure of the exact reason but heard it was something on NJT's end. Crew scheduling on MNR's side was covered on the extra list. I don't know how NJT handled their scheduling. It was their rolling stock used . Might have been something with equipment cycles. Again, can't say for sure. 5 hours ago, RailRunRob said: I've seen a few trains over the years they seemed Moderately full.. maybe 60-75% full. Maybe it was an operation thing? Crew Scheduling? NJT has a pretty significant crew shortage right now. In fact, their crew shortage is so significant that some of their regular service trains actually get cancelled due to short staffing. That *could* have had something to do with NJT axing this service. Edited October 12, 2017 by paulrivera added link to an article re: NJT crew shortage 1 Quote Link to comment Share on other sites More sharing options...
RailRunRob Posted October 12, 2017 Share #1054 Posted October 12, 2017 5 hours ago, N6 Limited said: I'm thinking that these trains can replace existing NJT trains between Secaucus and Penn, and Existing LIRR trains between Penn Station and Jamaica, it'll be a more efficient use of track capacity. Run the thru service, and people can make connections to whatever branch they need at the normal transfer points. I mean if using Secaucus as a terminal is a problem they can they can have a train go from Trenton to Jamaica, or say a "Beach Train" in the summer that goes from Bay Head, NJ on the North Jersey Coast Line to Long Beach, NY It's all technically possible the infrastructure's in place. All politics and ops. 0 Quote Link to comment Share on other sites More sharing options...
N6 Limited Posted October 12, 2017 Share #1055 Posted October 12, 2017 1 hour ago, Truckie said: Not sure of the exact reason but heard it was something on NJT's end. Crew scheduling on MNR's side was covered on the extra list. I don't know how NJT handled their scheduling. It was their rolling stock used . Might have been something with equipment cycles. Again, can't say for sure. So when through trains are used crews are swapped at state lines? 1 minute ago, RailRunRob said: It's all technically possible the infrastructure's in place. All politics and ops. They'd have to work out pricing between states as well right? If someone wanted to go from Jamaica to Newark Penn, they'd have to decide on the fare structure for something like that right? Would adding the NJT and LIRR fare for the same trip be out of the question? 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted October 12, 2017 Share #1056 Posted October 12, 2017 6 hours ago, RailRunRob said: I think so as well.. Logically it makes sense I just don't have the Math to Verify (TPH ect). I've gotten pushback on the idea mostly on Premise of the East River tubes being at capacity. But in my mind if you added to more two more tubes on the Hudson side. And locked 2 tracks for each direction I don't see the issue. Take a few tracks out at Penn and widen the platforms that should cut on dwele times. Where the trains go? Some to Sunnyside , Jamaica, Huntspoint? Secaucus, Newark Penn? Seems workable again i'd have to understand headways And scheduling I can probably run a simulation from that. Electrification incompatibility is the big one. If they had built ARC Alt G, you could through run NJT-MetroNorth and it would be all good, because 1. they already work together and 2. there are trains in existence that already do that. There's a lack of terminating capacity in the west and also in the east, since the systems were never designed for that, and end-to-end runtimes would be nothing short of ridiculous on any through-routed lines. On 10/10/2017 at 5:48 PM, N6 Limited said: Would it make sense for the LIRR and NJT to run Joint train service between say Secaucus and Jamaica? This way the LIRR can save on running time by just making connections in Jamaica and NJT in Secaucus (I guess they'd need a diesel to do that?) Which brings up the question (which I'm sure has come up before) Why doesn't the LIRR switch to catenary? Cost? That would cost a metric ton of money for very little tangible benefit other than the fuzzy benefits of through routing. Through routing through Penn is the least useful option, because all successful through-running schemes have multiple stops in the city's central area so that passengers spread out and don't jam up any one place. Any through running using existing infrastructure would instead just have the one station, Penn, tanking reliability with excessive dwell times. 0 Quote Link to comment Share on other sites More sharing options...
RailRunRob Posted October 12, 2017 Share #1057 Posted October 12, 2017 2 minutes ago, N6 Limited said: So when through trains are used crews are swapped at state lines? They'd have to work out pricing between states as well right? If someone wanted to go from Jamaica to Newark Penn, they'd have to decide on the fare structure for something like that right? Would adding the NJT and LIRR fare for the same trip be out of the question? I believe crews need to certified for sections of NEC. I remember hearing this many years ago . So there maybe two engineers in cab for the trip or parts of it. NJT is fine into Penn but im not sure if MN crews can run over the Hell Gate and south of New Rochelle. So I'm curious myself on that one. Shouldn't the goal be to pull everything under one umbrella? LIRR, MN, NJT? At least a fare standard and ticketing. So no I don't think that's completely out of the question. 0 Quote Link to comment Share on other sites More sharing options...
RailRunRob Posted October 12, 2017 Share #1058 Posted October 12, 2017 Just now, bobtehpanda said: Electrification incompatibility is the big one. If they had built ARC Alt G, you could through run NJT-MetroNorth and it would be all good, because 1. they already work together and 2. there are trains in existence that already do that. There's a lack of terminating capacity in the west and also in the east, since the systems were never designed for that, and end-to-end runtimes would be nothing short of ridiculous on any through-routed lines. That would cost a metric ton of money for very little tangible benefit other than the fuzzy benefits of through routing. Through routing through Penn is the least useful option, because all successful through-running schemes have multiple stops in the city's central area so that passengers spread out and don't jam up any one place. Any through running using existing infrastructure would instead just have the one station, Penn, tanking reliability with excessive dwell times. The M8's are some of the most advanced cars out there. 3 power types Hybrid cars could solve some of that. 3rd rail extended to Secaucus for MU's, NJT Locomotives built with Hybrid modes the ie ALP 46's . Technolgy could solve for this. LIRR,MN and NJT covered. Give me some numbers on TPH? Why couldn't you turn a few trains via Sunnyside Helix? A few to Hunts Point and maybe even Jamaica? That's 3 possible locations to split the load? On the Western end Secaucus and Newark. Steamline the tracks and widen Platforms and Stairways in Penn that'll help greatly with dwelle time. 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted October 12, 2017 Share #1059 Posted October 12, 2017 48 minutes ago, RailRunRob said: The M8's are some of the most advanced cars out there. 3 power types Hybrid cars could solve some of that. 3rd rail extended to Secaucus for MU's, NJT Locomotives built with Hybrid modes the ie ALP 46's . Technolgy could solve for this. LIRR,MN and NJT covered. Give me some numbers on TPH? Why couldn't you turn a few trains via Sunnyside Helix? A few to Hunts Point and maybe even Jamaica? That's 3 possible locations to split the load? On the Western end Secaucus and Newark. Steamline the tracks and widen Platforms and Stairways in Penn that'll help greatly with dwelle time. Too bad Metro North just upgraded everything to M7s. No one else is gonna take them if the MNR tries moving to all M8s. Same for the LIRR. And we're about to lock in the M9s as well. NJT has no money to run its existing service, how is it supposed to buy new trains? More importantly, what happens in a through running scenario where one state agency isn't pulling their weight with funding? You can't just suck it up and take the hit. Jamaica and Hunts Point are not designed to take trains from the west. Congestion at Sunnyside is why we're even considering through-running in the first place, because there's not enough room and therefore NJT terminates some trains within Penn itself. You can widen the platforms and stairways all you want, but if everyone is leaving the train at the same time at the same station, there's gonna be congestion. 0 Quote Link to comment Share on other sites More sharing options...
Truckie Posted October 12, 2017 Share #1060 Posted October 12, 2017 12 hours ago, N6 Limited said: So when through trains are used crews are swapped at state lines? Trains were re-crewed at NY-Penn. A bunch of MNR crews (C&E) qualified from New Rochelle to NYP where the train was re crewed with NJT crews. Mind you, per NJT, it was only the 1PM games that ran direct service. NJT had an issue with equipment cycles for the night games. 1 Quote Link to comment Share on other sites More sharing options...
RailRunRob Posted October 12, 2017 Share #1061 Posted October 12, 2017 14 hours ago, bobtehpanda said: Too bad Metro North just upgraded everything to M7s. No one else is gonna take them if the MNR tries moving to all M8s. Same for the LIRR. And we're about to lock in the M9s as well. NJT has no money to run its existing service, how is it supposed to buy new trains? More importantly, what happens in a through running scenario where one state agency isn't pulling their weight with funding? You can't just suck it up and take the hit. Jamaica and Hunts Point are not designed to take trains from the west. Congestion at Sunnyside is why we're even considering through-running in the first place, because there's not enough room and therefore NJT terminates some trains within Penn itself. You can widen the platforms and stairways all you want, but if everyone is leaving the train at the same time at the same station, there's gonna be congestion. 2 You're overthinking here. I need you to put your planner's cap on just for a second. You could make this happen with a few adjustments with current equipment and technology. Before we get into that understand this would be a long-term plan 20-25 years this is a regional undertaking it affects everything most importantly GDP and growth. If you start with showing someone how they'll make money you'll get different outcomes this is where a lot of projects and smart folks go wrong love and logic. You have to start with the doe. To this point, this type of streamlining could benefit the region greatly I don't think it's to crazy to fold NJT into a seamless regional network with the MTA. It's not going to happen overnight these Agencies will find money for what they feel is Priority trust and believe Federal level as well the New York Metro area is the crowning jewel for the country how long do you think they'll let this go on? Until it starts hitting some pockets. Now on to equipment do we need new cars? Extend 750 DCV 3 Miles from the Bergen Portal to Secaucus. MU now you have free range from Secaucus to Jamaica and points east and north to the Hell Gate. M7/M8 check. LIRR's EMD are covered there good to Newark. NJT's ALP 45's are Dual powered much like the EMD's so Sunnyside, South Bronx or Jamaica for them. ALP46's would be Sunnyside or the South Bronx they run on both phases. So check for the NJT. To your point on the Stations are you Saying they can't be Reconfigured to terminate trains? If so why not? Terminals and train Compatibility below. 0 Quote Link to comment Share on other sites More sharing options...
Trainmaster5 Posted October 12, 2017 Share #1062 Posted October 12, 2017 (edited) I’d like to make a quick point and ask an obvious question. AFAIC any extension of NJT eastward to Jamaica station is a no-go. With ESA on the horizon the LIRR has already planned to evict the Atlantic Branch Brooklyn trains from the existing plant at Jamaica citing “ no room “ as the reason. The existing trackage will be for Penn Station, HPA, LIC, and ESA LIRR trains. My question is what gives anyone the idea that there’s an actual, profitable, market for a Babylon- Trenton service. That’s even if the equipment, signals, and power issues could be overcome. Anyone familiar with the existing plant at Jamaica knows that there is no easy way to turn Eastbound trains there. A NJT-MNRR combo appears to be an easier nut to crack IMO. Qualifying on the signal systems alone is no easy task as it is. That’s why you had crew swaps at Penn Station for the Meadowlands service. Feel free to critique my post and I won’t be offended. Carry on. Edited October 12, 2017 by Trainmaster5 2 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted October 13, 2017 Share #1063 Posted October 13, 2017 7 hours ago, RailRunRob said: You're overthinking here. I need you to put your planner's cap on just for a second. You could make this happen with a few adjustments with current equipment and technology. Before we get into that understand this would be a long-term plan 20-25 years this is a regional undertaking it affects everything most importantly GDP and growth. If you start with showing someone how they'll make money you'll get different outcomes this is where a lot of projects and smart folks go wrong love and logic. You have to start with the doe. To this point, this type of streamlining could benefit the region greatly I don't think it's to crazy to fold NJT into a seamless regional network with the MTA. It's not going to happen overnight these Agencies will find money for what they feel is Priority trust and believe Federal level as well the New York Metro area is the crowning jewel for the country how long do you think they'll let this go on? Until it starts hitting some pockets. Now on to equipment do we need new cars? Extend 750 DCV 3 Miles from the Bergen Portal to Secaucus. MU now you have free range from Secaucus to Jamaica and points east and north to the Hell Gate. M7/M8 check. LIRR's EMD are covered there good to Newark. NJT's ALP 45's are Dual powered much like the EMD's so Sunnyside, South Bronx or Jamaica for them. ALP46's would be Sunnyside or the South Bronx they run on both phases. So check for the NJT. To your point on the Stations are you Saying they can't be Reconfigured to terminate trains? If so why not? Terminals and train Compatibility below. Planning and engineering don't exist in a vacuum. NJT is broke, continues to be broke, and will forever be broke short of the money fairy showing up and taking a huge dump on the state. Interstate planning and operation doesn't work. Exhibit A is the Port Authority, the agency that runs everything it touches in the most expensive ways possible, topping the 'most expensive' lists in the nation. No one wants to pay for someone else's crap even if they get something out of it. Look at WMATA and see how that's working out for them. Even if they did, New Jersey wants no part in that. They cancelled ARC over the slightest hint of taxes because of cost overruns. More importantly, NJT runs transit for the entire state. South Jersey is faring less well economically than North Jersey, so they get some cross-subsidy over there. Central and South Jersey are not about to give up money going to their services, and they sure as hell aren't about to fork over control to Albany. Trenton may be crap, but it's the devil they know versus the devil they don't. What the hell are they supposed to fund their services off of? The carcasses of Atlantic City and Camden? 0 Quote Link to comment Share on other sites More sharing options...
RailRunRob Posted October 13, 2017 Share #1064 Posted October 13, 2017 (edited) 1 hour ago, bobtehpanda said: Planning and engineering don't exist in a vacuum. NJT is broke, continues to be broke, and will forever be broke short of the money fairy showing up and taking a huge dump on the state. Interstate planning and operation doesn't work. Exhibit A is the Port Authority, the agency that runs everything it touches in the most expensive ways possible, topping the 'most expensive' lists in the nation. No one wants to pay for someone else's crap even if they get something out of it. Look at WMATA and see how that's working out for them. Even if they did, New Jersey wants no part in that. They cancelled ARC over the slightest hint of taxes because of cost overruns. More importantly, NJT runs transit for the entire state. South Jersey is faring less well economically than North Jersey, so they get some cross-subsidy over there. Central and South Jersey are not about to give up money going to their services, and they sure as hell aren't about to fork over control to Albany. Trenton may be crap, but it's the devil they know versus the devil they don't. What the hell are they supposed to fund their services off of? The carcasses of Atlantic City and Camden? So my question at this point is how does the New York Metro continue to grow and stay competitive? Especially if you have next two generations trapped in boondoggle after boondoggle? As an American, you have to feel some kinda of way to know we're the old beauty queen that still thinks she has it. How long until we lose our edge and it all go's to crap? Your probably under 30 and already limited from potential problems you could solve. The world needs more Champions, another Moses isn't that the goal? Again 25-50 years out we don't know the possibilities drop the State limitations and create Regional Jurisdictions. Planning is finding solutions and path's for future growth and prosperity aim for the stars and touch the clouds. If you dont have that Mentality then what's the point? Everything I stated before is technically possible only thing in its way is short-sightedness and greed. Edited October 13, 2017 by RailRunRob 0 Quote Link to comment Share on other sites More sharing options...
RailRunRob Posted October 13, 2017 Share #1065 Posted October 13, 2017 (edited) 6 hours ago, Trainmaster5 said: I’d like to make a quick point and ask an obvious question. AFAIC any extension of NJT eastward to Jamaica station is a no-go. With ESA on the horizon the LIRR has already planned to evict the Atlantic Branch Brooklyn trains from the existing plant at Jamaica citing “ no room “ as the reason. The existing trackage will be for Penn Station, HPA, LIC, and ESA LIRR trains. My question is what gives anyone the idea that there’s an actual, profitable, market for a Babylon- Trenton service. That’s even if the equipment, signals, and power issues could be overcome. Anyone familiar with the existing plant at Jamaica knows that there is no easy way to turn Eastbound trains there. A NJT-MNRR combo appears to be an easier nut to crack IMO. Qualifying on the signal systems alone is no easy task as it is. That’s why you had crew swaps at Penn Station for the Meadowlands service. Feel free to critique my post and I won’t be offended. Carry on. My view was more flexibility with options to route to Jamaica. If you had a ALP45 and you wanted to get it in and out of Penn Quickly and Sunnyside isn't an option would be nice to have the option to route it to Jamaica and turn it there. Maybe it's 3-4 trains a hour at peak.? Service Feasibility for a Babylon to Trenton I'd have to look at the data off hand I'll say it's low. Equipment shouldn't be an issue with Dual Mode trains and Signaling I believe is Pulse code or a close variation with ASC most locomotives should have ASC and ACSES so signaling should be achievable but work nontheless. Moving forward why couldn't you standardize everything for certifications? Boston to Washington what does Amtrak put their engineers thru? LIRR is Pretty detached from the main line rail so that might be the Special case to Jamaica. As for Jamaica station and space, Maybe the reconfiguration just east of the station create pockets to turn trains? Im not 100% on the operations, checks and time it takes fully to back a train. But im going to say with 2 tracks turning 5 trains an hour is possible. Fill me in if im off. These options of thru running IMO is an option to get more trains in and out of the CBD and meet more demand. Edited October 13, 2017 by RailRunRob 0 Quote Link to comment Share on other sites More sharing options...
FamousNYLover Posted October 16, 2017 Share #1066 Posted October 16, 2017 There's bus direction mistake at Hicksville Station because new sign still says N48 to Jericho Quad which doesn't run anymore. They should have fixed to n48/49 to Broadway Mall. 0 Quote Link to comment Share on other sites More sharing options...
Via Garibaldi 8 Posted October 20, 2017 Share #1067 Posted October 20, 2017 Well this is weird. I'm on a peak train to Grand Central. Plenty of seats open and this lady is standing blocking the aisle. I got on and took my seat in the Quiet Car area thinking she was getting off, but nope. She's been standing since I got on in Riverdale. 0 Quote Link to comment Share on other sites More sharing options...
Union Tpke Posted October 20, 2017 Share #1068 Posted October 20, 2017 Changes in LIRR service Screen Shot 2017-10-20 at 3.54.28 PM by Union Turnpike, on Flickr Screen Shot 2017-10-20 at 3.54.46 PM by Union Turnpike, on Flickr 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted October 21, 2017 Share #1069 Posted October 21, 2017 (edited) On 10/12/2017 at 5:01 PM, Trainmaster5 said: I’d like to make a quick point and ask an obvious question. AFAIC any extension of NJT eastward to Jamaica station is a no-go. With ESA on the horizon the LIRR has already planned to evict the Atlantic Branch Brooklyn trains from the existing plant at Jamaica citing “ no room “ as the reason. The existing trackage will be for Penn Station, HPA, LIC, and ESA LIRR trains. My question is what gives anyone the idea that there’s an actual, profitable, market for a Babylon- Trenton service. That’s even if the equipment, signals, and power issues could be overcome. Anyone familiar with the existing plant at Jamaica knows that there is no easy way to turn Eastbound trains there. A NJT-MNRR combo appears to be an easier nut to crack IMO. Qualifying on the signal systems alone is no easy task as it is. That’s why you had crew swaps at Penn Station for the Meadowlands service. Feel free to critique my post and I won’t be offended. Carry on. The Brooklyn trains are being nixed ostensibly so that the LIRR can streamline the interlocking (in reality, they're too stingy to spend on a couple flyovers that would allow seamless integration of BK and PS/GCT flows). Once that is done, capacity is said to increase by about 40%. The only way thru-running would work would be to do actual thru running. Babylon-Trenton, Huntington-Morristown, Ronkonkoma-Long Branch etc. Even then, the commute markets will still be hub/spoke -- the gains will be in equipment utilization and capacity. Edited October 21, 2017 by RR503 0 Quote Link to comment Share on other sites More sharing options...
N6 Limited Posted October 23, 2017 Share #1070 Posted October 23, 2017 On 10/21/2017 at 2:43 PM, RR503 said: The Brooklyn trains are being nixed ostensibly so that the LIRR can streamline the interlocking (in reality, they're too stingy to spend on a couple flyovers that would allow seamless integration of BK and PS/GCT flows). Once that is done, capacity is said to increase by about 40%. The only way thru-running would work would be to do actual thru running. Babylon-Trenton, Huntington-Morristown, Ronkonkoma-Long Branch etc. Even then, the commute markets will still be hub/spoke -- the gains will be in equipment utilization and capacity. Will this be because of east side access? Most Hempstead Branch Trains use Atlantic Terminal as the Western Terminal, will most go to Penn or Grand Central or just terminate in Jamaica? Do will MTA do Joint LIRR Metro North tickets once East Side access opens? 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted October 23, 2017 Share #1071 Posted October 23, 2017 9 minutes ago, N6 Limited said: Will this be because of east side access? Most Hempstead Branch Trains use Atlantic Terminal as the Western Terminal, will most go to Penn or Grand Central or just terminate in Jamaica? Do will MTA do Joint LIRR Metro North tickets once East Side access opens? Yes correct. ESA will be able to handle around 20tph at peak so Atlantic Terminal trains + new trains will head there. It's a shame -- they're screwing BK and Lower Manhattan. It'd be one thing if the Jamaica xfer was well designed but only one overpass will connect to the new platform. Classic LIRR. 2 Quote Link to comment Share on other sites More sharing options...
checkmatechamp13 Posted October 23, 2017 Share #1072 Posted October 23, 2017 (edited) I guess they took that 7:54am departure from Deer Park and had it start in Ronkonkoma at 7:30am, so they could create that midday trip that leaves Greenport at 9:43am. So they screw over Deer Park-Ronkonkoma (which also makes it that much harder to connect to that train, since there's a decent amount of SCT connections available at Brentwood, and to a lesser extent Central Islip and Deer Park) to benefit Riverhead-Greenport. Then what they didn't mention is that not only did they take away the 9:14am trip out of Penn, but they also took away the 1:14pm trip out of Penn. That "early quit" option was already available on the 1:14pm trip (that actually makes sense for people looking to go home after lunch). But 11:14am....if you took that first train of the morning in (that arrived at 8:20am), that means you probably didn't get to work until 8:30-9:00, depending on where exactly you work. Then you probably have to be out of your office by 10:30-11:00am to catch that train....so maybe you were able to attend one meeting, and that's about it. Then in the afternoon, they extended that afternoon trip to start from Greenport instead of Riverhead (and moved it up 37 minutes earlier). That extra trip from Yaphank was probably a deadhead that they put into service (once you get to Ronkonkoma, you have to wait 54 minutes, but it's better than nothing). I'd be curious to see what times they have planned for the extra weekend roundtrips. (Really, it's SCT's job, but one thing I definitely noticed on a lot of fantrips is people missing the last bus to Riverhead. So hopefully, it addresses that issue, even though the real solution is just later SCT service. Shutting down atround 6:30pm on a NYC-area transit system is nothing short of ridiculous) All I can say is, until they finish the Main Line Third Track and Ronkonkoma Branch 2nd Track projects, this is all just a reshuffling of trains. When we can get real reverse-peak service, and a decent frequency at least out to Riverhead, that's when it'll make a real difference. (At least in Riverhead, you have the option of transferring to the S92 if you need to. Or another bus to get to a destination such as Tanger or SCCC). And of course, SCT needs to hold up its end of the deal. Really, with the lack of reverse-peak service, the LIRR should at least attempt to run some reverse-peak shuttle buses between Hicksville & Ronkonkoma. For intra-island travel (or if you're really desperate, traveling all the way from NYC), yeah, NICE will get you as far as Hicksville, or maybe Farmingdale if you're taking the n6-n70/72, but beyond that, travel becomes really difficult because there's nothing running parallel to the LIRR east of there, and SCT frequency is crap. Perfect example: Under the current schedule, there's a train that arrives at Farmingdale at 7:00am, and a train that departs Deer Park at 7:54am heading east. Alright, fair enough, there's a single track in sections east of Farmingdale and most people need to get to NYC....but now what's the alternative for people heading east? A train stopping at Pinelawn & Wyandanch takes 11 minutes, and a nonstop train takes 8 minutes....say a bus takes 20 minutes. They could have the bus leave at 7:05am, get to Deer Park at 7:25am, and the people can hang out and wait for the 7:54am train. Not the best situation, but whatever. Instead, the only option to catch up to that train is to take the Babylon Branch train that leaves Penn at 4:54am (instead of one that leaves at 6:07am), and get to Babylon at 6:08am to catch either a 6:15am or 7:00am S27 to reach that train at Deer Park (and now that the train starts from Ronkonkoma, even that's not an option anymore). Heck, they could've still made it work with a shuttle bus. Farmingdale-Ronkonkoma is 29 minutes making all stops. Say a bus takes a few minutes longer, they could've still had that train leave at say, 7:45am, and had it get to Greenport in time to make a midday trip. Edited October 23, 2017 by checkmatechamp13 0 Quote Link to comment Share on other sites More sharing options...
N6 Limited Posted October 23, 2017 Share #1073 Posted October 23, 2017 What do conductors do with the tickets they collect? Are they discarded, or are they used for metrics? 0 Quote Link to comment Share on other sites More sharing options...
Via Garibaldi 8 Posted October 23, 2017 Share #1074 Posted October 23, 2017 1 hour ago, N6 Limited said: What do conductors do with the tickets they collect? Are they discarded, or are they used for metrics? Likely discarded. I once saw a bunch of punched tickets on Metro-North seats. One reason I would love for the to do away with paper tickets. Too much waste. 0 Quote Link to comment Share on other sites More sharing options...
N6 Limited Posted October 23, 2017 Share #1075 Posted October 23, 2017 1 hour ago, Via Garibaldi 8 said: Likely discarded. I once saw a bunch of punched tickets on Metro-North seats. One reason I would love for the to do away with paper tickets. Too much waste. Besides E-tix would you prefer a smartcard? The SBS receipts are a waste too. I already have an unlimited card, now I have to dip it for a temporary paper receipt. 0 Quote Link to comment Share on other sites More sharing options...
