SevenEleven Posted February 18, 2009 Share #76 Posted February 18, 2009 Here's one that happened on the yesterday: BLOCKAGE: Damaged rail outside 50th Street lower level on line, Jamaica bound. TIME: AM Rush Hour ANTICIPATED DURATION: 2-3 Hours Fix: Uptown trains rerouted over the to 145th St. My Fix: trains to 145th Street. Trains that run to 145th Street will turn and run back to WTC. trains to Manhattan run over the to W4, and then regular. These trains run on the back to Queens. Once rail problems are fixed, train service restored. Link to comment Share on other sites More sharing options...
metsfan Posted February 18, 2009 Share #77 Posted February 18, 2009 This is like a crossword puzzle, but you can go and ride it. :eek: - A Link to comment Share on other sites More sharing options...
Daniel The Cool Posted February 19, 2009 Share #78 Posted February 19, 2009 here's the train derailment G.O via CPW Local between W 145th Street and 59th Street suspended via CPW Local to Inwood-207th Street Link to comment Share on other sites More sharing options...
Amtrak7 Posted February 21, 2009 Share #79 Posted February 21, 2009 My solution for derailment (s/b express at 81): suspended runs to Euclid local both directions 168-59 local southbound 125-59, both directions W4-47/50 ( Terminates at W4 suspended. My solution to SevenEleven's problem: suspended runs on both directions to 2 Av. My problem: Broken rail, Manhattan-bound 60 St. tunnel AM Rush Hour. Expected to last 2-3 hours. Link to comment Share on other sites More sharing options...
Ken S. Posted February 21, 2009 Share #80 Posted February 21, 2009 Turns at Lexington Avenue on Queens-bound track. Operates via 63rd Street Line in both directions. Operates as Shuttle between Astoria and QBP LL. Passengers transfer to for Manhattan. Link to comment Share on other sites More sharing options...
Amtrak7 Posted February 21, 2009 Share #81 Posted February 21, 2009 Turns at Lexington Avenue on Queens-bound track. Operates via 63rd Street Line in both directions. Operates as Shuttle between Astoria and QBP LL. Passengers transfer to for Manhattan. OK. My original idea was similar, but suspend the and run the in 2 sections. Link to comment Share on other sites More sharing options...
bknightshadow45 Posted May 12, 2009 Share #82 Posted May 12, 2009 BLOCKAGE: Due to a Police investigation, the upper and the lower level of 145th Street is closed in all directions. TIME: Start of AM Rush Hour ANTICIPATED DURATION: 5 hours Link to comment Share on other sites More sharing options...
MTR Admiralty Posted May 12, 2009 Share #83 Posted May 12, 2009 BLOCKAGE: Due to a Police investigation, the upper and the lower level of 145th Street is closed in all directions.TIME: Start of AM Rush Hour ANTICIPATED DURATION: 5 hours Oh snap. This one is pretty tricky. Okay, customers can transfer to the M10 at 59th Street, as it follows the CPW route. Suspend (, and service. Send the to Forest Hills via QBL local. A shuttle can operate between 205th and 161st-Yankee. There are switches past the station that can allow it to change direction. Split the route. The will run LOCAL between 125th and its Queens branches and a shuttle will run between 207th and 168th Street. Those to 135th, 145th, 155th (Ams), 163rd will have to take a bus. Link to comment Share on other sites More sharing options...
Ken S. Posted May 12, 2009 Share #84 Posted May 12, 2009 BLOCKAGE: Due to a Police investigation, the upper and the lower level of 145th Street is closed in all directions.TIME: Start of AM Rush Hour ANTICIPATED DURATION: 5 hours - Replaced by Shuttle Buses between 125th and 207th Streets. ( - Diverted to 57/6 and relayed behind the wall at 63/Lex to the Broadway Line by wrong-railing on the 63rd Street BMT if possible. - Replaced by selected Trains. - As MTR said, replaces the between 34th Street and Forest Hills. Bronx passengers can use the Bx1 and Bx2 to the or or take the express bus. Link to comment Share on other sites More sharing options...
MTR Admiralty Posted May 12, 2009 Share #85 Posted May 12, 2009 - Replaced by Shuttle Buses between 125th and 207th Streets.( - Diverted to 57/6 and relayed behind the wall at 63/Lex to the Broadway Line by wrong-railing on the 63rd Street BMT if possible. - Replaced by selected Trains. - As MTR said, replaces the between 34th Street and Forest Hills. Bronx passengers can use the Bx1 and Bx2 to the or or take the express bus. Or in fact, I'll make the part of the Broadway line during this period. Knock out the ? Link to comment Share on other sites More sharing options...
Ken S. Posted May 12, 2009 Share #86 Posted May 12, 2009 Or in fact, I'll make the ( part of the Broadway line during this period. Knock out the ? The serves Lower Manhattan unless you mean sending the via the tunnel, but then you'd have to suspend the south of Chambers so there's room for the ( in the tunnel. But, now a problem in Harlem/Washington Heights could be affecting subway riders in Middle Village and Fresh Pond as well as people getting off the SI Ferry. Link to comment Share on other sites More sharing options...
MTR Admiralty Posted May 12, 2009 Share #87 Posted May 12, 2009 The serves Lower Manhattan unless you mean sending the ( via the tunnel, but then you'd have to suspend the south of Chambers so there's room for the in the tunnel. But, now a problem in Harlem/Washington Heights could be affecting subway riders in Middle Village and Fresh Pond as well as people getting off the SI Ferry. That's true. However I think that turning at Lex/63rd for the ( will have greater service impacts on the . Link to comment Share on other sites More sharing options...
Matt91 Posted July 24, 2009 Share #88 Posted July 24, 2009 I see no one's posted here in a while... BLOCKAGE: Water Main break at 9th St (4th Ave) TIME: 4PM on weekday ANTICIPATED DURATION: ~3 or 4 hrs Link to comment Share on other sites More sharing options...
via White Plains Road Posted July 24, 2009 Share #89 Posted July 24, 2009 I see no one's posted here in a while... BLOCKAGE: Water Main break at 9th St (4th Ave) TIME: 4PM on weekday ANTICIPATED DURATION: ~3 or 4 hrs Hmmmm.....send trains via line in both directions, via the line directions. trains terminate @ Broad Street and suspend the . Hey I tried, couldn't think of anything else lol! Link to comment Share on other sites More sharing options...
KTrainExp Posted July 25, 2009 Share #90 Posted July 25, 2009 BLOCKAGE: Water Main break at 9th St (4th Ave) TIME: 4PM on weekday ANTICIPATED DURATION: ~3 or 4 hrs -Send all downtown trains to Brighton Beach and suspend ( service along Brighton Beach because of overcrowding issues. -For the uptown trains, make the terminate at 36th street. -Activate the shuttle. -Suspend the completely and make it terminate at it's Manhattan Terminals with some trains at Myrtle Avenue. -Uptown trains terminate at 36th street. -Downtown trains either terminate at Second Avenue with the or West 4th Street on the Downtown Track and then turn back around. -Activate the Grand Street and make it run two trains with both terminating at Grand Street, then switching over the switch outside Broadway Lafayette and then letting all trains terminate at West 4th Street UPTOWN platform to allow customers to connect to the trains. <DEPENDING ON THE SITUATION> -If one track is still available, then run a Shuttle between 36th Street and Atlantic Avenue Pacific Street making all local stops with ONLY 1 TRAIN. - train customers must take the or to 34th for or service. - service is self-explanatory there. - trains customers are forced to transfer at Canal to resume trip. Crazy Day ain't it. Link to comment Share on other sites More sharing options...
Matt91 Posted July 25, 2009 Share #91 Posted July 25, 2009 Hmmmm.....send trains via line in both directions, via the line directions. trains terminate @ Broad Street and suspend the . Hey I tried, couldn't think of anything else lol! that's the simple way, but what happens to the Brooklyn riders? -Send all downtown trains to Brighton Beach and suspend ( service along Brighton Beach because of overcrowding issues. -For the uptown trains, make the terminate at 36th street. -Activate the shuttle. -Suspend the completely and make it terminate at it's Manhattan Terminals with some trains at Myrtle Avenue. -Uptown trains terminate at 36th street. -Downtown trains either terminate at Second Avenue with the or West 4th Street on the Downtown Track and then turn back around. -Activate the Grand Street and make it run two trains with both terminating at Grand Street, then switching over the switch outside Broadway Lafayette and then letting all trains terminate at West 4th Street UPTOWN platform to allow customers to connect to the trains. <DEPENDING ON THE SITUATION> -If one track is still available, then run a Shuttle between 36th Street and Atlantic Avenue Pacific Street making all local stops with ONLY 1 TRAIN. - train customers must take the or to 34th for or service. - service is self-explanatory there. - trains customers are forced to transfer at Canal to resume trip. Crazy Day ain't it. Complicated, and it would affect riders b/t Marcy and Myrtle and riders along CPW. My solution: terminates at 2nd Ave terminates at Pacific terminates at Broad via Brighton exp To CI or Brighton Beach (if CI becomes congested) and shuttle 59th-CI terminates at Dekalb on its own downtown track, crosses back over to uptown track using switch north of Lawrence, reduce headway. Shuttle 36th-95th (if possible) extend via culver (express to Church, then express downtown local uptown to Church) to CI to make up for loss of service Link to comment Share on other sites More sharing options...
KTrainExp Posted July 25, 2009 Share #92 Posted July 25, 2009 Alright. I'll re-modify my method. _________ -( trains remain unaffected and should be used as an alternative for customers who want to travel along 6th Avenue from Brooklyn. - terminates at Atlantic/Pacific on the UPTOWN track via the switch outside of the station. trains will make the stop at DeKalb Avenue. -Norwood trains that are stuck in Brooklyn because of the situation must either get into Coney Island yard, or travel up the via the Express Tracks to not create too much congestion. The remainder of the trains will Shuttle in between 36th and Coney Island. -Shuttle in between 36th Street and Atlantic/Pacific on the local tracks. The Shuttle will be traveling down one track ONLY due to no switches available to cross over outside of Atlantic/Pacific. - trains will Shuttle in between 36th and Coney Island. - service will be cut at the duration of this situation with and trains stuck in Manhattan to substitute the service. - trains all terminate at Broad Street. - shuttle activated. Link to comment Share on other sites More sharing options...
BklynSouth Posted August 5, 2009 Share #93 Posted August 5, 2009 I see no one's posted here in a while... BLOCKAGE: Water Main break at 9th St (4th Ave) TIME: 4PM on weekday ANTICIPATED DURATION: ~3 or 4 hrs I would have my OT slip fill out and be willing and ready to go where ever they reroute me. Link to comment Share on other sites More sharing options...
Matt91 Posted August 5, 2009 Share #94 Posted August 5, 2009 Here's another one, harder this time: BLOCKAGE: Emergency station structure work at W4th St. No trains in either direction on both levels TIME OF DAY AND DURATION: All weekend Link to comment Share on other sites More sharing options...
via White Plains Road Posted August 6, 2009 Share #95 Posted August 6, 2009 Here's another one, harder this time: BLOCKAGE: Emergency station structure work at W4th St. No trains in either direction on both levels TIME OF DAY AND DURATION: All weekend For which line 8th Avenue or 6th Avenue? Link to comment Share on other sites More sharing options...
Matt91 Posted August 6, 2009 Share #96 Posted August 6, 2009 For which line 8th Avenue or 6th Avenue? Both! My solution: Local south of 34th St to help nearby 8th Ave riders Extended to Flatbush to help Bklyn Riders 2 sections: 207th - 14th st, express, crosses over before 34th (every 10/15 min): and Canal to Lefferts/Rock Pk terminates at 34th ( on S/B express track terminates 14th St via S/B local track, crosses over at 34th/42nd, runs every 15 min terminates at 7th Ave Upper (Southbound) level, crosses over at switch E of Lexington Ave, 10/15 min headway runs from Bway/Lafayette (N/B local track) to CI using switch south of Delancey/essex replaces via QB EXP or extended to CI via Montague St/4th Ave EXP/West End to replace runs with shorter headways to help crosstown manhattan riders Shuttle Bway/Lafayette (terminates on EXP tracks) to Prospect Park via Manhattan Bridge Special from 71st ave to 47th-50th sts via Roosevelt Is Link to comment Share on other sites More sharing options...
Eric B Posted October 13, 2009 Share #97 Posted October 13, 2009 Man, this sort of "what if" ideas in the subway is what I used to live for before the Internet age; but this past year, I just did not have time to follow it. What I often think of is a more long term situation with the Manhattan Bridge going back to earlier partially colsed scenarios with the new patterns, or of course, completely closed. Even though it is all fixed up, you never know what could happen. Like they found problems a few months ago, leading to weekend shutdowns. Or, God forbid, an attack. Things are different now, with the 63rd St. connector completed, so things would be very different, especially in the northside only open scenario. You would most likely end up with the and being merged (probably retaining rather than (Q6). It could switch from express to local at Bway Laf/W4. If they keep it on the express, then, they would end up having to switch the and , with the going back to 53rd and the going to 63rd. It would be an emergency, basically, so they might have to. Or end up combining the and (Q6), and the would have to cover the Culver. Since there were always problems with the 46's on the Brighton, I would imagine them putting them back on the , and sending a bunch of 160's from CI to Jamaica, which would probably be the base yard for the line. So you would have a full time with 100% 160's. If the (Q6) and are merged, of course, the new combined line would have the 160's. Over on Broadway, of course, the would be swallowed by an local via tunnel again. It is possible they could keep the on Broadway, via tunnel, and cut back the , as they had planned in the cutbacks. That would be less disruptive to the service pattern. Now, if the service were like now, with express service on the Brighton eliminated, the would probably be simply replaced by a full time ( (to 145 evenings, nights and weekends, as was done in its last West End days). If you go back to the last service pattern, southside only open, it would just go back to the way it was. to Brooklyn and . I imagine, with the back as the express now, they might keep it the same, and it would only be an extension of the via tunnel, and cross to the express at Pacific. Though, southbound, they try to avoid this now. If the Brighton express service was out, then there would be no , and the space on the Bridge could be given to the . This makes it ironic, how in the same time frame as the 1986-88 pattern, they had this same setup on the Brighton, but still ran the two services --as skip stop, bumping the into the tunnel seemingly forever. Then, there is the fully closed scenario; the most drastic. In the pre-2001 plans, generally (which did get to run once in a 1992 rush hour shutdown), the West End was always cut back to Pacific, the cut back, and only one service on the Brighton, so you would only have 3 services in the tunnel. I imagine that's all they could do, unless they decide the West End was more important now, in which you would have the from Astoria to Coney Island, and the as a shuttle in Brooklyn, just like in the last pattern on weekends. the East River crossings study also had a shuttle from Brighton Beach to Franklin, but while the Franklin line's connections to other lines have been improved to better serve as alternative routes, the stations' capacity has been greatly reduced, and with no 170-or-less ft. train sets, there is nothing that could run there. They could build a temporary extension to the southbound platform at Botanic Gardens, borrow the 8 car 160's from the that would be isolated in CI, and terminate them on that side and run the existing shuttle cars the rest of the way from the other side. But that's dumping all of the people onto the IRT which is in permanent overcrowded state itself. They will not all transfer to the other side, and most wouldn't fit in the two car trains anyway. But we would really like to rather get them to the Franklin terminal since the IND local has additional capacity (One of the plans even suggested sending the to Brooklyn for this, or making the local). They made it hard to extend that other side platform, because a concrete room was built on the south end. If that were removed, It appears you could build temporary extensions on the other stations. The same plan also had the extended all the way to Coney Island! (though both local, and at that time, the decision to take the off 53rd was not made yet, so the was assumed to be 63rd) Link to comment Share on other sites More sharing options...
Eric B Posted November 3, 2009 Share #98 Posted November 3, 2009 Here's another one. Tunnel collapse on Nassau line somewhere between Bowery and Chambers. Looks so old and decrepit, not hard to believe would happen. The would be merged with the , and the with the . I had always said they would never do this, but this is just the sort of emergency that would warrant it. The would pick up the run of the rest of the to Euclid. would end at Essex middle. (M)/(V) would be normal weekday hours, and the -replacing services would run the normal all times except nights. Nights, would revert to normal (WTC) and would terminate Essex middle. ENY and the would now get a lot of the 32's from the . They might end up pulling 160's from the for the . The and would probably end up getting the 32's and 42's. I'm not even sure if they could run on the ENY lines, which can only use 8 cars. They butchered a lot of the station markers to try to run them on the , but I don't know if this was completed everywhere (like the 6th Ave line, or in Queens), or if some of it may have been changed back or whatever. So this would be the opportunity they would take to replace the 42's in ENY with 32's, and it would remain like that when service was restored. (So then the 42's would remain at JYD). Not sure if the Chambers-Bay Pkwy half of the and the shuttle would still have the 160's, or get 32's. If they did that, that would create a pool at CI that the (B)'s lone 32 could join. Also hope and would fit with the from Bway-Laf to W4. Link to comment Share on other sites More sharing options...
NX Express Posted November 17, 2009 Share #99 Posted November 17, 2009 I have one. FBI agents overhear a terrorist saying, "Bomb 42 St in Manhattan". They don't know where, so all service on/near 42 St. is affected. This includes: (©(S)42(V). I don't know what to do:confused::confused::confused::confused: Link to comment Share on other sites More sharing options...
Matt91 Posted November 18, 2009 Share #100 Posted November 18, 2009 I have one. FBI agents overhear a terrorist saying, "Bomb 42 St in Manhattan". They don't know where, so all service on/near 42 St. is affected. This includes: ((S)42(V). I don't know what to do:confused::confused::confused::confused: PANIC! Link to comment Share on other sites More sharing options...
