7LineFan 256 Posted July 14, 2008 Share #1 Posted July 14, 2008 I jsut got BVE. How do I work it with a keyboard? Link to comment Share on other sites More sharing options...
Pablo M 201 35 Posted July 14, 2008 Share #2 Posted July 14, 2008 Up and Down arrow keys for the reverser. (Up for Forward/Neutral. Down for Back/Neutral.) Z key for power. A key to brake. Q key for emergency brake. But, IMO, keyboard assignment 2 is much better. If you go to Settings, look for something with the keyboard, you should fine the list. With Keyboard Assignment 2: F key = put reverser to forward. N key = put reverser to neutral. B key = put reverser into reverse. Up arrow key = power Down arrow key = brake 0 key = emergency brake. Link to comment Share on other sites More sharing options...
7LineFan 256 Posted July 15, 2008 Author Share #3 Posted July 15, 2008 Up and Down arrow keys for the reverser. (Up for Forward/Neutral. Down for Back/Neutral.) Z key for power. A key to brake. Q key for emergency brake. But, IMO, keyboard assignment 2 is much better. If you go to Settings, look for something with the keyboard, you should fine the list. With Keyboard Assignment 2: F key = put reverser to forward. N key = put reverser to neutral. B key = put reverser into reverse. Up arrow key = power Down arrow key = brake 0 key = emergency brake. Thanks. Link to comment Share on other sites More sharing options...
SubwayGuy 2,322 Posted July 15, 2008 Share #4 Posted July 15, 2008 Just adding on what Pablo wrote...If your train has two handles A and Z operate the master controller, and "<" and ">" operate the brake handle. Also with two handles "/" dumps the train, not Q. Link to comment Share on other sites More sharing options...
error46146 1,007 Posted July 15, 2008 Share #5 Posted July 15, 2008 Up and Down arrow keys for the reverser. (Up for Forward/Neutral. Down for Back/Neutral.) Z key for power. A key to brake. Q key for emergency brake. But, IMO, keyboard assignment 2 is much better. If you go to Settings, look for something with the keyboard, you should fine the list. With Keyboard Assignment 2: F key = put reverser to forward. N key = put reverser to neutral. B key = put reverser into reverse. Up arrow key = power Down arrow key = brake 0 key = emergency brake. for keyboard assignment 2, you can also use the Num Lock keys 8 for forward/release brakes 5 to put it in neutral/coasting 2 to put the brakes also here are some more controls: Horn: keyboard 1 - Enter keyboard 2 - Num Lock 3 Other horn sound (if applicable): keyboard 1- SHIFT + Enter keyboard 2- 6 Link to comment Share on other sites More sharing options...
KTrainExp 16 Posted August 2, 2008 Share #6 Posted August 2, 2008 Sorry for posting in almost a month old topic, but how do u put the reverser into Forward using Control Set 2 with the Number Lock Keys? Link to comment Share on other sites More sharing options...
7LineFan 256 Posted August 2, 2008 Author Share #7 Posted August 2, 2008 Press the "F" key. Link to comment Share on other sites More sharing options...
