megabus Posted January 12, 2013 Share #1 Posted January 12, 2013 Hello friends,I want to know how the system works for the rear doors on articulated buses on line M15+SBS+. When customers want to get on the bus by the rear doors is that they are activated by the driver at each stop or is it the users who need to operate thanks to a system available to them (such as on the following picture)? Buttons on each side of the rear door. Close-ups of the external buttons. Button inside the bus to the rear doors. When is it also for older New Flyer buses D60HF on the Bx12+SBS+? C.U.Soon, Laurent Link to comment Share on other sites More sharing options...
Gorgor Posted January 12, 2013 Share #2 Posted January 12, 2013 Whenever an SBS stops the driver opens all of the doors, you don't need to do a thing. Link to comment Share on other sites More sharing options...
Metro CSW Posted January 12, 2013 Share #3 Posted January 12, 2013 When a bus is on SBS service, the driver has controlls of all 3 doors to automatically open without passengers touching the tape. (They really shoud clear....) It's a different story when the buses are on regular local service. I believe there's switch. I hope I remember that clearly enough.... Hope it helps.... Link to comment Share on other sites More sharing options...
BreeddekalbL Posted January 12, 2013 Share #4 Posted January 12, 2013 Apparently from what i read the sbs light apparently allows the switch to trigger all 3 doors to open Link to comment Share on other sites More sharing options...
SevenEleven Posted January 12, 2013 Share #5 Posted January 12, 2013 Apparently from what i read the sbs light apparently allows the switch to trigger all 3 doors to open Yes, when the SBS lights are activated, it will open the rear doors automatically upon moving the door handle to Rear. Link to comment Share on other sites More sharing options...
Threxx Posted January 12, 2013 Share #6 Posted January 12, 2013 In normal service, since no one has talked about it, there is a sensor on the door. When it detects something and the rear doors are activated, they will open. When is it also for older New Flyer buses D60HF on the Bx12+SBS+? The Bx12SBS no longer uses D60HF's, but they worked similarly to the LFSA's. Link to comment Share on other sites More sharing options...
SevenEleven Posted January 12, 2013 Share #7 Posted January 12, 2013 In normal service, since no one has talked about it, there is a sensor on the door. When it detects something and the rear doors are activated, they will open. The Bx12SBS no longer uses D60HF's, but they worked similarly to the LFSA's. Pretty much the same way. The rear door control switch is put in the Driver's position so they will open and close with the door handle. Link to comment Share on other sites More sharing options...
Far Rock Depot Posted January 12, 2013 Share #8 Posted January 12, 2013 So that explains why 1) during the blackout following Sandy, Most LFSAs has the SBS lights flashing (like the M14'a) and 2) why LFSA Shuttle buses also have them flashing (like the Rockaway shuttle) Link to comment Share on other sites More sharing options...
megabus Posted January 15, 2013 Author Share #9 Posted January 15, 2013 Thank you for your answers friends."Bref" the driver opens and closes itself back doors so that customers can get on the bus.Do you have pictures of the "cockpit" of the LFSA's and D60HF's? C.U.Soon, Laurent Link to comment Share on other sites More sharing options...
NYCtrainfan01 Posted January 15, 2013 Share #10 Posted January 15, 2013 Thank you for your answers friends."Bref" the driver opens and closes itself back doors so that customers can get on the bus. Do you have pictures of the "cockpit" of the LFSA's and D60HF's? C.U.Soon, Laurent Here's some photos courtesy of TTMG (Click the link then click on misc expand gallery then click on Operator's area) LFSA Photos D60HF Photos Link to comment Share on other sites More sharing options...
Acela Express Posted January 16, 2013 Share #11 Posted January 16, 2013 <blockquote class='ipsBlockquote'data-author="Threxx" data-cid="631631" data-time="1358027514"> In normal service, since no one has talked about it, there is a sensor on the door. When it detects something and the rear doors are activated, they will open.<br /> <br /> </p></blockquote> Wrong. The doors only open in local mode if the passenger touches the yellow handle, even if someone bumps into the handle. The doors will not close until the door area is clear however. Link to comment Share on other sites More sharing options...
megabus Posted January 17, 2013 Author Share #12 Posted January 17, 2013 Here's some photos courtesy of TTMG (Click the link then click on misc expand gallery then click on Operator's area) LFSA Photos D60HF Photos Thank you, but I haven't found really interesting pictures, I wish pics where I could see all the commands for the driver detailled (door, brake...). I found a video on youtube, I don't know which network is the bus, but you must have the same system for the rear door on your bus? With a delayed closing slower I hope! http://www.youtube.com/watch?v=xRKX9dAOHII Link to comment Share on other sites More sharing options...
East New York Posted January 18, 2013 Share #13 Posted January 18, 2013 In normal service, since no one has talked about it, there is a sensor on the door. When it detects something and the rear doors are activated, they will open. The Bx12SBS no longer uses D60HF's, but they worked similarly to the LFSA's. I still see the accasional D60HF on the Bx12SBS. Link to comment Share on other sites More sharing options...
jgood6195 Posted January 18, 2013 Share #14 Posted January 18, 2013 I still see the accasional D60HF on the Bx12SBS. I am not surprised, those LFSAs need to be worked on sometime. Link to comment Share on other sites More sharing options...
YankeesPwnMets Posted January 18, 2013 Share #15 Posted January 18, 2013 Yes, when the SBS lights are activated, it will open the rear doors automatically upon moving the door handle to Rear. You learn something new every day... I remember after Sandy when all fares were waived, I saw a M14A with its blue SBS lights activated. I didn't know why the 14A would have its blue lights on but now I know it was just to allow people to board through all doors, since there were no fares at that time. Link to comment Share on other sites More sharing options...
paulrivera Posted January 19, 2013 Share #16 Posted January 19, 2013 I still see the accasional D60HF on the Bx12SBS. Along with the not-so-rare LFSA without the SBS wrap Link to comment Share on other sites More sharing options...
Fresh Pond Posted January 19, 2013 Share #17 Posted January 19, 2013 Saw a bunch on M15 selects driving up and down the street without the lights flashing today. Link to comment Share on other sites More sharing options...
GojiMet86 Posted January 19, 2013 Share #18 Posted January 19, 2013 Saw a bunch on M15 selects driving up and down the street without the lights flashing today. http://secondavenuesagas.com/2013/01/18/flashing-blue-lights-no-longer-an-sbs-hallmark/ Reacting to specific concerns, MTA New York City Transit has agreed to turn off the flashing blue lights that have served to alert riders to the arrival of Select Bus Service buses (SBS) since the speedier service was introduced. This measure is being taken to eliminate the possibility of confusing the vehicles with volunteer emergency vehicles, which are entitled by law to use the blue lights. We are currently in the process of developing an alternate means of identifying SBS buses. Link to comment Share on other sites More sharing options...
BreeddekalbL Posted January 19, 2013 Share #19 Posted January 19, 2013 Does it affect back door boarding now that the lights are shut off? Link to comment Share on other sites More sharing options...
Vistausss Posted January 19, 2013 Share #20 Posted January 19, 2013 Thank you, but I haven't found really interesting pictures, I wish pics where I could see all the commands for the driver detailled (door, brake...). I found a video on youtube, I don't know which network is the bus, but you must have the same system for the rear door on your bus? With a delayed closing slower I hope! http://www.youtube.com/watch?v=xRKX9dAOHII I don't know which network either but given the fact that the bus contains Canadian ads I'm pretty sure it's somewhere in Canada lol. Link to comment Share on other sites More sharing options...
Fresh Pond Posted January 19, 2013 Share #21 Posted January 19, 2013 <blockquote class='ipsBlockquote'data-author="BreeddekalbL" data-cid="634368" data-time="1358569417"><p> Does it affect back door boarding now that the lights are shut off?</p></blockquote> Well the one I was on, the driver put it in SBS mode while in the bus stops (the blue lights came on) but once he left the stop, he turned SBS mode off Link to comment Share on other sites More sharing options...
megabus Posted January 20, 2013 Author Share #22 Posted January 20, 2013 I always look for pictures of cabs in this style : Thank you in advance for your helps Link to comment Share on other sites More sharing options...
Vistausss Posted January 21, 2013 Share #23 Posted January 21, 2013 Well, if you specifically mean American buses, then here I got one for you from an Orion EPA10: (^ courtesy of fellow forum member East New York) Link to comment Share on other sites More sharing options...
megabus Posted January 22, 2013 Author Share #24 Posted January 22, 2013 Well, if you specifically mean American buses, then here I got one for you from an Orion EPA10: (^ courtesy of fellow forum member East New York) Yes exactly what I'm looking for! Thank you for this photo and hope there will be more different models. And especially those of the NYCT. C.U.Soon, Laurent Link to comment Share on other sites More sharing options...
