T J Trainman Posted September 2, 2014 Share #176 Posted September 2, 2014 Any luck with this new line? Link to comment Share on other sites More sharing options...
Q43LTD Posted September 7, 2014 Share #177 Posted September 7, 2014 So what's this I'm hearing about a Q111 limited in January? Link to comment Share on other sites More sharing options...
BM5 via Woodhaven Posted September 7, 2014 Share #178 Posted September 7, 2014 So what's this I'm hearing about a Q111 limited in January? If that happens, ain't no way in hell that's gonna be new buses. Probably gonna come off the current Q111 Local, and off some other unrelated lines. It also tells me that 114 service has increased usage of the limited significantly (which is a good thing). Link to comment Share on other sites More sharing options...
Q43LTD Posted September 7, 2014 Share #179 Posted September 7, 2014 If that happens, ain't no way in hell that's gonna be new buses. Probably gonna come off the current Q111 Local, and off some other unrelated lines. It also tells me that 114 service has increased usage of the limited significantly (which is a good thing).But it won't be all day though, it'll be rush hour. How many limiteds does Brewer need? It's like giving Woodhaven another limited... Link to comment Share on other sites More sharing options...
BM5 via Woodhaven Posted September 7, 2014 Share #180 Posted September 7, 2014 But it won't be all day though, it'll be rush hour. How many limiteds does Brewer need? It's like giving Woodhaven another limited... In that case, it'll probably only come off the Q111. The way I see it, you'll have a limited every 15 minutes, and a local every 8 minutes or something, I don't know. I guess they really want to trim down overall runtime (as well as costs) on that corridor. The stops south of Baisley are enough to get it an SRO load or more on both trips. In anyway, it just screws over the riders at local only stops. In other words, current Q111 Local setup: 5 minutes during the rush, 12 buses per hour Possible changes: 1. 6 minute headways local, 30 minute headways limited (retains 12 bph) 2. 7 minute headways local, 15 minute headways limited (retains 12 bph in select time frames) 3. 8 minute headways local, 12 minute headway limited (retains 12 bph in select time frames) 4. 9 minute headways local, 10 minute headway limited (retains 12 bph in most time frames) 5. 10 minute headways local, 10 minute headways limited (retains 12 bph) Possibly, the Cedarhurst trips would become Limited Q111 trips as well (or at least the AM ones). That's for the full route, the short turns will probably be reconfigured around to have an even headway. Link to comment Share on other sites More sharing options...
Q43LTD Posted September 7, 2014 Share #181 Posted September 7, 2014 In that case, it'll probably only come off the Q111. The way I see it, you'll have a limited every 15 minutes, and a local every 8 minutes or something, I don't know. I guess they really want to trim down overall runtime (as well as costs) on that corridor. The stops south of Baisley are enough to get it an SRO load or more on both trips. In anyway, it just screws over the riders at local only stops. In other words, current Q111 Local setup: 5 minutes during the rush, 12 buses per hour Possible changes: 1. 6 minute headways local, 30 minute headways limited (retains 12 bph) 2. 7 minute headways local, 15 minute headways limited (retains 12 bph in select time frames) 3. 8 minute headways local, 12 minute headway limited (retains 12 bph in select time frames) 4. 9 minute headways local, 10 minute headway limited (retains 12 bph in most time frames) 5. 10 minute headways local, 10 minute headways limited (retains 12 bph) Possibly, the Cedarhurst trips would become Limited Q111 trips as well (or at least the AM ones). That's for the full route, the short turns will probably be reconfigured around to have an even headway. Or extended to Brookville during the rush, other times end at Farmers. Then they'll probably give it another designation. Link to comment Share on other sites More sharing options...
B35 via Church Posted September 7, 2014 Share #182 Posted September 7, 2014 111LTD's... Lol... Guy R Brewer is becoming Woodhaven blvd. like, in terms of bus service..... Link to comment Share on other sites More sharing options...
BM5 via Woodhaven Posted September 7, 2014 Share #183 Posted September 7, 2014 Eh, I'd lol if they make a second local bus on Guy R. Brewer with the short turns, on top of the existing service. Link to comment Share on other sites More sharing options...
Q43LTD Posted September 7, 2014 Share #184 Posted September 7, 2014 Not even necessary... Link to comment Share on other sites More sharing options...
B35 via Church Posted September 7, 2014 Share #185 Posted September 7, 2014 Eh, I'd lol if they make a second local bus on Guy R. Brewer with the short turns, on top of the existing service. What would be the point? Link to comment Share on other sites More sharing options...
T J Trainman Posted September 7, 2014 Share #186 Posted September 7, 2014 I knew this was gonna happen a Q-111 LTD. Would this help the Q-114? Link to comment Share on other sites More sharing options...
Q43LTD Posted September 7, 2014 Share #187 Posted September 7, 2014 Great...what next, all day Q6 LTD service? Link to comment Share on other sites More sharing options...
NewFlyer 230 Posted September 7, 2014 Share #188 Posted September 7, 2014 Great...what next, all day Q6 LTD service?Next might be a renaming of the 150 Av short turn Q10's maybe. I don't get it's service now. From the way the schedule is it seems that buses now go either to JFK or short turn at Rockaway Blvd. Do buses still end at 150 Ave all day like they use to when the Q10 was using standard buses? Link to comment Share on other sites More sharing options...
BM5 via Woodhaven Posted September 7, 2014 Share #189 Posted September 7, 2014 What would be the point? Exactly. No point, so it's a waste. Link to comment Share on other sites More sharing options...
Q43LTD Posted September 7, 2014 Share #190 Posted September 7, 2014 Next might be a renaming of the 150 Av short turn Q10's maybe. I don't get it's service now. From the way the schedule is it seems that buses now go either to JFK or short turn at Rockaway Blvd. Do buses still end at 150 Ave all day like they use to when the Q10 was using standard buses?Yes there are Q10's that end at 150... Link to comment Share on other sites More sharing options...
SubBus Posted September 13, 2014 Share #191 Posted September 13, 2014 No to Q111 LTD. Its bad enough that the Q114 LTD runs 19/7. Its also bad enough that the Q111 is crowded at 1130p leaving JC. Beef up Q111 service first. Maybe more Farmers short turns runs while the Q114 LTD is running..... Link to comment Share on other sites More sharing options...
Q43LTD Posted September 13, 2014 Share #192 Posted September 13, 2014 Or bring back the 137 short turns... Link to comment Share on other sites More sharing options...
SubBus Posted September 13, 2014 Share #193 Posted September 13, 2014 Or bring back the 137 short turns... Those short turns were basically during the rush hour. Im talking all day while the Q114 LTD is running. I believe the last Farmers bus is around 10pm... Link to comment Share on other sites More sharing options...
Q43LTD Posted September 14, 2014 Share #194 Posted September 14, 2014 Those short turns were basically during the rush hour. Im talking all day while the Q114 LTD is running. I believe the last Farmers bus is around 10pm...9:49 to be exact. They should run until the last 114 limited. Or extend them to Brookville Link to comment Share on other sites More sharing options...
SubBus Posted September 14, 2014 Share #195 Posted September 14, 2014 9:49 to be exact. They should run until the last 114 limited. Or extend them to Brookville Exactly. Run the Farmers short turns during the same hours as the Q114 LTD. Link to comment Share on other sites More sharing options...
R32 3838 Posted September 20, 2014 Share #196 Posted September 20, 2014 This is only rumored and this came from a MTA source who works at BP In January they are talking about making the Q111 LTD peak direction only, am to Jamaica and pm to rosedale and additional local Q111 service, again this is rumored nothing official, there's also talks of SBS on the Q113/114 but that's just rumors Link to comment Share on other sites More sharing options...
Via Garibaldi 8 Posted September 20, 2014 Share #197 Posted September 20, 2014 lol I can't believe this thread has gone 20 pages.... All of you people that live in the area should be this active in the community by going to the board meetings regarding transportation. Link to comment Share on other sites More sharing options...
Q43LTD Posted September 20, 2014 Share #198 Posted September 20, 2014 lol I can't believe this thread has gone 20 pages.... All of you people that live in the area should be this active in the community by going to the board meetings regarding transportation.For the record, I don't live in Rosedale, but these are my home routes Link to comment Share on other sites More sharing options...
Via Garibaldi 8 Posted September 20, 2014 Share #199 Posted September 20, 2014 For the record, I don't live in Rosedale, but these are my home routes Well close enough to have a say in the routes with your community board... With all of the comments here there are obviously problems which should be taken to the transportation meetings, etc. moreso than here. Link to comment Share on other sites More sharing options...
