Homeless Problem Spreads to NYCT Buses
Via Garibaldi 8
On 9/23/2018 at 11:49 PM, Via Garibaldi 8 said:
The passageway from PATH basically links riders to ALL subway lines that stop at Herald Square. When it closes overnight, you simply walk one block over to 34th and 6th which is Herald Square where you can access all of the subway lines. Not all of the subway lines are on the same platform so some walking within the station is needed, but you can access all of the subway lines nonetheless.
Therefore why on the PATH site there is written "Passageway from PATH to NYC Subway N, Q, and R trains closed daily from 11 p.m. until 5 a.m" and not "Passageway from PATH to NYC Subway N, Q, R , B, M, F and D trains closed daily from 11 p.m. until 5 a.m"?
You would have to ask them. I didn't create the sign. The fact of the matter is the passageway can connect you to the other subway lines, but you can also exit and go to the street. Maybe that's part of the reason. It's not like you're getting a free transfer or anything. It's just a matter of convenience in not having to go street level to reach the subway and then go back below ground again. The real issue is the homeless problem.
