Fan Railer Posted December 10, 2015 Author Share #26 Posted December 10, 2015 This is the DTG New Jersey Transit EMD GP40PH-2B & Comet Car Physics & Sound Mod Pack Version 0.5 In order to utilize this freeware physics & sound upgrade, you must have purchased the "Train Simulator: NJT GP40PH-2B Loco Add-On" available here: http://store.steampowered.com/app/325991 This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics & sound enhancements found in this pack for personal use if you so choose. THIS *WILL* BE BOTH A PHYSICS AND SOUND UPGRADE PACK. The purpose of this pack is to correct physics errors in the GP40PH-2B locomotive, and will introduce more accurate sounds for the DLC in a later update. General Parameter Change Log (Physics): 1. Slight tweak of TE and Dynamic Brake curves. 2. Changing the rated power. 3. Modified coupler slack performance. 4. Modified fuel capacity. 5. Raised brake pipe pressure from 90 PSI to 110 PSI. 5b. This fixes issues when operating from Comet V cab car. General Parameter Change Log (Sounds): 1. To come in V1.0 release update. Technical specifications for GP40PH-2B: 1. EMD GP40PH-2B (EMD 645; 3200 THP; separate HEP) a. Starting tractive effort of 65,000 lbs (289.1344 kN) b. Continuous tractive effort of 38,240 lbs (170.1 kN) @ 16.5 mph c. Dynamic Brake effort of 35,000 lbs (177.93 kN) @ 55 mph; extended range sawtooth curve between 55 mph and 36 mph. Fade to 0 lbs @ 0.5 mph d. Wheel horsepower of 3,000 hp (2,240 kW) @ 30 mph e. Maximum speed of 103 mph f. Engine RPM range = 30 - 900 g. RPM change rate (rpm/second) = 25 h. Fuel consumption range (gph)= 4 - 155 i. Weight = 286,000 lbs (129.729 metric tons) j. Fuel capacity = 2500 gallons k. Max traction amps = 1785 l. Max brake amps = 700 IMPORTANT; Install Instructions 1. Open the following directory: "C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\GP40PHPack01" 2. Open the "DTG_NJT_EMD_GP40PH-2B_Mod_Pack.7z" file 3. Drag both folder(s) from the .rar file into the directory from step 1. 4. Mod installation is complete. 5. Run TS2016 to confirm. Thank you for downloading and installing. Please contact me if there is a problem with the functionality of this mod pack (http://www.facebook.com/FanRailerMODS/). Enjoy =) Download link: http://www.mediafire.com/download/3vv6pysxcxy8oes/TS2016_DTG_NJT_EMD_GP40PH-2B_Mod_Pack.rar Link to comment Share on other sites More sharing options...
Fan Railer Posted January 8, 2016 Author Share #27 Posted January 8, 2016 This is the Union Pacific EMD SD60M Physics & Sound Modification pack version 1.0 In order to utilize this freeware physics upgrade, you must own the "Train Simulator: Union Pacific SD60M Loco Add-On Loco Add-On" pack available at Steam: http://store.steampowered.com/app/222629/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics enhancements found in this pack for personal use if you so choose. The purpose of this pack is to make minor adjustments to the physics performance of the locomotive, fix the air brakes, and make minor sound adjustments. List of changes: 1. Modified tractive effort and braking effort curves. 2. Modified power ratings @ alternator and @ wheel. 3. Set fuel capacity to 5000 gallons. 4. Set weight to 395,000 lbs. 5. Removed coupler slack. 6. Adjusted rpm range and rate of change. 7. Adjusted locomotive load response times. 8. Includes signature JohnS brake fix. 9. Includes JohnS throttle fix (throttle now snaps into preset notches). 10. Adjusted engine sound rpm range. 11. Removes alerter sound that plays when the independent brake handle is moved. Technical specifications: 1. EMD SD60M (EMD 16-710G3A; 3800 THP) a. Starting tractive effort of 137,066 lbs (610 kN) b. Continuous tractive effort of 100,100 lbs (445 kN) @ 14.7 mph c. Dynamic Brake effort of 70,285 lbs (313 kN) @ 25 mph to 10 mph; fade to 0 lbs @ 3.5 mph. d. Wheel horsepower of 3,500 hp (2,612 kW) @ 21.5 mph e. Maximum speed of 70 mph f. Engine RPM range = 269 - 904 g. RPM change rate (rpm/second) = 25 h. Fuel consumption range (gph)= 3.1 - 184.7 i. Weight = 395,000 lbs (179.171 metric tons) j. Fuel capacity = 5000 gallons k. Max traction amps = 1650 l. Max brake amps = 820 IMPORTANT; Install Instructions 1. Locate SD60MPack01 (C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\RSC\SD60MPack01) 2. Open DTG_UP_EMD_SD60M_Physics_Mod_Pack.rar 3. Drag the file folders from the .rar in step 2 into the directory you opened in step 1. 4. The installation should be complete. Run TS2016 to check. 5. If installation is botched or does not work, to back up to original files, delete the folder from step 3. Thank you for downloading and installing. Enjoy =) Download link: http://www.mediafire.com/download/icxat3f7c4hrmk2/TS2016_DTG_UP_EMD_SD60M_Physics_Mod_Pack.rar Facebook Page: http://www.facebook.com/FanRailerMODS/ Link to comment Share on other sites More sharing options...
Fan Railer Posted January 29, 2016 Author Share #28 Posted January 29, 2016 This is the DTG New Jersey Transit EMD F40PH-2CAT & Comet Car Physics & Sound Mod Pack Version 0.5 In order to utilize this freeware physics & sound upgrade, you must have purchased the "Train Simulator: NJT F40PH-2CAT Loco Add-On" available here: http://store.steampowered.com/app/325968/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics & sound enhancements found in this pack for personal use if you so choose. THIS *WILL* BE BOTH A PHYSICS AND SOUND UPGRADE PACK. The purpose of this pack is to correct minor errors in the F40PH-2CAT locomotive, and will introduce more accurate sounds for the DLC in a later update. This pack also reduces drag coefficient on the Comet cars to Amfleet levels. General Parameter Change Log (Physics): 1. Slight tweak of TE and Dynamic Brake curves. 2. Changing the rated power. 3. Modified coupler slack performance. 4. Modified fuel capacity. 5. Modified locomotive weight 6. Lowered passenger car drag coefficient. General Parameter Change Log (Sounds): 1. To come in V1.0 release update. Technical specifications for F40PH-2CAT: 1. EMD F40PH-2CAT (EMD 16-645E3B; 3200 THP; separate HEP) a. Starting tractive effort of 65,000 lbs (289.1344 kN) b. Continuous tractive effort of 38,240 lbs (170.1 kN) @ 16.5 mph c. Dynamic Brake effort of 35,000 lbs (177.93 kN) @ 55 mph; extended range sawtooth curve between 55 mph and 36 mph. Fade to 0 lbs @ 0.5 mph d. Wheel horsepower of 3,000 hp (2,240 kW) @ 30 mph e. Maximum speed of 103 mph f. Engine RPM range = 410 - 900 g. RPM change rate (rpm/second) = 25 h. Fuel consumption range (gph)= 4 - 155 i. Weight = 275,450 lbs (122.96875 imperial tons) j. Fuel capacity = 1800 gallons k. Max traction amps = 1785 l. Max brake amps = 700 IMPORTANT; Install Instructions 1. Open the following directory: "C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\F40PH2Pack01" 2. Open the "DTG_NJT_EMD_F40PH-2CAT_Mod_Pack.rar" file 3. Drag both folder(s) from the .rar file into the directory from step 1. 4. Mod installation is complete. 5. Run TS2016 to confirm. Thank you for downloading and installing. Please contact me if there is a problem with the functionality of this mod pack (http://www.facebook.com/FanRailerMODS/). Enjoy =) Download link: http://www.mediafire.com/download/h9ap192fbdr5s8z/TS2016_DTG_NJT_EMD_F40PH-2CAT_Mod_Pack.rar Facebook Page: http://www.facebook.com/FanRailerMODS/ Link to comment Share on other sites More sharing options...
Fan Railer Posted January 30, 2016 Author Share #29 Posted January 30, 2016 Some Hoboken Division action: The New York Division - Bergen Line (between Hoboken and Harriman) as of 1/30/16. Enjoy the ride smile emoticon Schedule: http://www.njtransit.com/pdf/rail/R0020.pdf Route: http://steamcommunity.com/sharedfiles/filedetails/… Support: http://railworksamerica.com/forum/viewtopic.php?f=31&t=13875 Link to comment Share on other sites More sharing options...
Fan Railer Posted January 31, 2016 Author Share #30 Posted January 31, 2016 More Hoboken division action: The Pascack Valley Line (between Secaucus Junction and Spring Valley) as of 1/30/16. Enjoy the ride =) Schedule: http://www.njtransit.com/pdf/rail/R0010.pdf Route: http://steamcommunity.com/sharedfiles/filedetails/?id=582765320 Link to comment Share on other sites More sharing options...
Fan Railer Posted February 1, 2016 Author Share #31 Posted February 1, 2016 Here is the preview for the sound portion of the Dash 8-32BWH mod package. Sounds were tested on the P32AC-DM and are sourced to Callum Beatson for the no-HEP engine sounds and sound code, and to Chris Reynolds (MilwaukeeNorth418) for the new K5LA horn recording. I also take no credit for the last two image thumbnails; credits go to the respective photographers behind those photos. I have not yet decided whether I will be porting these sounds over to the P32AC-DM as a mod update or the P42DC versions. If I do, I will announce it. Stay tuned for the sound and physics mod release announcement. Enjoy =) Link to comment Share on other sites More sharing options...
Fan Railer Posted February 5, 2016 Author Share #32 Posted February 5, 2016 Link to comment Share on other sites More sharing options...
Fan Railer Posted February 5, 2016 Author Share #33 Posted February 5, 2016 Route still available here, I believe: http://rail-sim.de/forum/wsif/index.php/Category/89-Shin-Osaka-to-Okayama/ Link to comment Share on other sites More sharing options...
Fan Railer Posted February 12, 2016 Author Share #34 Posted February 12, 2016 Link to comment Share on other sites More sharing options...
Fan Railer Posted February 12, 2016 Author Share #35 Posted February 12, 2016 Train 605 Timelapse: Real-time: Link to comment Share on other sites More sharing options...
Fan Railer Posted February 16, 2016 Author Share #36 Posted February 16, 2016 Enjoy this mod development tutorial: This is the DTG Feather River Canyon Locomotive Physics Modification pack version 1.0 In order to utilize this freeware physics upgrade, you must have purchased the "Train Simulator: Feather River Canyon Route Add-On" pack available at Steam: http://store.steampowered.com/app/376932/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics enhancements found in this pack for personal use if you so choose. This is NOT a mod pack. That full mod pack MAY be available separately from this one (if I deem it necessary to create one). The purpose of this pack is to adjust the physics performance of the two diesel locomotives that come with the DLC (EMD F7 & GE U30B). List of general changes; specific changes for each specific locomotive located below: 1. Modified tractive effort and braking effort curves. 2. Modified power ratings @ alternator and @ wheel. 3. Modified fuel capacity. 4. Modified weights. 5. Removed coupler slack. 6. Adjusted rpm range and rate of change. 7. Adjusted locomotive load response times. Technical specifications: 1. EMD F7 (EMD 567; 1500 THP) a. Starting tractive effort of 56,500 lbs (251 kN) b. Continuous tractive effort of 40,000 lbs (178 kN) @ 9.3 mph c. Dynamic Brake effort of 30,000 lbs (133 kN) @ 25 mph; fade to 0 lbs @ 0.5 mph. d. Wheel horsepower of 1,500 hp (1,120 kW) @ 20 mph e. Maximum speed of 65 mph f. Engine RPM range = 275 - 835 g. RPM change rate (rpm/second) = 35 h. Fuel consumption range (gph)= 3.5 - 93.1 i. Weight = 237,500 lbs (106 imperial tons) j. Fuel capacity = 1200 gallons k. Max traction amps = 1500 l. Max brake amps = 600 2. GE U30B (GE 7FDL; 3000 THP) a. Starting tractive effort of 72,000 lbs (320 kN) b. Continuous tractive effort of 64,000 lbs (289 kN) @ 10.7 mph c. Dynamic Brake effort of 40,000 lbs (178 kN) @ 26 mph; extended range sawtooth curve between 26 mph and 8 mph. Fade to 0 lbs @ 0.5 mph. d. Wheel horsepower of 2,700 hp (1,881 kW) @ 20 mph e. Maximum speed of 70 mph f. Engine RPM range = 550 - 1050 g. RPM change rate (rpm/second) = 25 h. Fuel consumption range (gph)= 4 - 155 i. Weight = 287,000 lbs (128.125 imperial tons) j. Fuel capacity = 1700 gallons k. Max traction amps = 1800 l. Max brake amps = 900 IMPORTANT; Install Instructions 1. Locate FeatherRiver (C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\FeatherRiver) 2. Open DTG_Feather_River_Canyon_Locomotive_Mod_Pack.rar 3. Drag the file folder from the .rar in step 2 into the directory you opened in step 1. 4. The installation should be complete. Run TS2016 to check. 5. If installation is botched or does not work, to back up to original files, delete the folder from step 3. Thank you for downloading and installing. Enjoy =) Download here: http://www.mediafire.com/download/x1422ldc3vadiuv/TS2016_DTG_Feather_River_Canyon_Locomotive_Mod_Pack.rar Link to comment Share on other sites More sharing options...
Fan Railer Posted February 16, 2016 Author Share #37 Posted February 16, 2016 This is the DTM UP EMD GP30 Physics Modification pack version 1.0 In order to utilize this freeware physics upgrade, you must have purchased the "Train Simulator: Union Pacific GP30 Loco Add-On" pack available at Steam: http://store.steampowered.com/app/277759/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics enhancements found in this pack for personal use if you so choose. The purpose of this pack is to adjust the physics performance of the locomotive. List of changes: 1. Modified tractive effort and braking effort curves. 2. Modified power ratings @ alternator and @ wheel. 3. Set fuel capacity to 1700 gallons. 4. Set weight to ~260,000 lbs (unit specific). 5. Removed coupler slack. 6. Adjusted rpm rate of change. 7. Adjusted locomotive load response times. 8. Removed field divert feature. Technical specifications: 1. EMD GP30A (EMD 16-567D3; 2250 THP) a. Starting tractive effort of 63,375 lbs (281.906 kN) b. Continuous tractive effort of 50,000 lbs (222.4 kN) @ 9.3 mph c. Dynamic Brake effort of 40,000 lbs (177.93 kN) @ 25 mph; fade to 0 lbs @ 0.5 mph. d. Wheel horsepower of 2,025 hp (1,511.2 kW) @ 20 mph e. Maximum speed of 65 mph (104.6 km/h) f. Engine RPM range = 275 - 835 g. RPM change rate (rpm/second) = 35 h. Fuel consumption range (gph)= 3.5 - 124.9 i. Weight = 262,200 lbs (117.0536 imperial tons) j. Fuel capacity = 1700 gallons k. Max traction amps = 1500 l. Max brake amps = 700 2. EMD GP30B (EMD 16-567D3; 2250 THP) a. Weight = 258,800 lbs (115.536 imperial tons) IMPORTANT; Install Instructions 1. Locate GM GP30-UP (C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTM\GM GP30-UP) 2. Open DTM_UP_EMD_GP30_Physics_Mod.rar 3. Drag the file folders from the .rar in step 2 into the directory you opened in step 1. 4. The installation should be complete. Run TS2016 to check. 5. If installation is botched or does not work, to back up to original files, delete the folder from step 3. Thank you for downloading and installing. Enjoy =) Download link: http://www.mediafire.com/download/zn1d30mmn3o3qqo/TS2016_DTM_UP_EMD_GP30_Physics_Mod.rar Link to comment Share on other sites More sharing options...
Fan Railer Posted February 23, 2016 Author Share #38 Posted February 23, 2016 Shanghai Maglev is out: http://store.steampowered.com/app/376933/ Link to comment Share on other sites More sharing options...
Fan Railer Posted February 26, 2016 Author Share #39 Posted February 26, 2016 Welcome aboard the UP 844 Feather River Canyon excursion. We will be taking a consist of 24 cars up the 1% grade from Oroville to Keddie Wye and back. Settle back and enjoy the trip =) Table of contents: 0:00 - 30:20 - Assembling the consist in Oroville Yard and proceeding to Oroville Depot to pick up passengers. 32:08 - 3:44:12 - Departing Oroville, 844 powers up the 1.0% ruling grade towards Keddie. Along the way we experience an issue with the water pump from the auxiliary tenders, necessitating a slower than normal speed and a short stop at Paxton to trouble shoot. 3:44:12 - 3:56:53 - After correcting the issue at Paxton, we continue the final few miles to Keddie. 4:00:20 - 4:13:44 - Following a brief breather stop at Keddie, we reverse the train over the wye in preparation for the return trip. 4:14:50 - 6:50:40 - The return trip downgrade to Oroville. 6:50:40 - 7:10:51 - Bringing the train back to the yard and laying up the locomotive. Link to comment Share on other sites More sharing options...
Fan Railer Posted March 1, 2016 Author Share #40 Posted March 1, 2016 READ FIRST (EXPAND): Section 1: 0:00 - 17:58 (Phase V w/ HEP sounds on NEC) Section 2: 17:58 - 27:59 (File manipulation) Section 3: 27:59 - 48:54 (Pepsi Can w/ no-HEP sounds on San Diegan) You tell me which sounds better =) This is the Amtrak GE Dash 8-32BWH Sound & Physics Modification pack version 1.0 In order to utilize this freeware physics upgrade, you must have purchased the "Train Simulator: Amtrak Dash 8-32BWH Loco Add-On" pack available at Steam: http://store.steampowered.com/app/376931/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics enhancements found in this pack for personal use if you so choose. This is both a sound AND physics mod. The purpose of this pack is to adjust the traction characteristics values for more realistic operation. It additionally replaces the default horn and bell sounds with files that are authentic to the locomotive. This pack includes the option to operate with or without HEP (changes acceleration characteristics and prime mover sounds). Credits to Callum Beatson for the no-HEP engine sounds and sound code, and to Chris Reynolds (MilwaukeeNorth418) for the new K5LA horn recording. General Parameter Change Log: 1. Weight set to 274,890 lbs. 2. Traction characteristics adjusted; see below for more details. 3. Dynamic brake values enhanced. 4. Blend air-dynamic brake delay increased to 10 seconds (originally set at 0). 5. Replaced horn/bell sounds. 6. Includes no-HEP sound pack. 7. Removed coupler slack on Superliner cars. Technical specifications for the Amtrak Dash 8-32BWH: 1. GE Dash 8-32BWH (GE 7FDL-12; 3300 GHP); HEP version a. Starting tractive effort of 60,260 lbs (268.054 kN) b. Continuous TE of 38,500 lbs (171.26 kN) @ 26 mph c. Wheel horsepower of ~2,450 hp (~1,830 kW) @ 30 mph; assuming ~200 kW HEP load d. Maximum traction amps = 1800 (60,260 lbs) e. Dynamic Brake effort of 37,390 lbs (166.319 kN) from 41 mph to 9 mph f. DB resistor grid rating of 4,084 hp (3,047.76 kW) g. Max brake amps = 900 (37,390 lbs) h. Maximum speed of 103 mph i. Engine RPM range = 400 - 1050 j. RPM change rate (rpm/second) = 20 k. Fuel consumption range (gph)= 4 - 158 l. Fuel capacity = 1,800 gallons m. Weight = 122.71875 imperial tons (274,890 lbs) 2. GE Dash 8-32BWH (GE 7FDL-12; 3300 GHP); no HEP version a. Wheel horsepower of 3,000 hp (2,239 kW) @ 30 mph b. All other characteristics unchanged IMPORTANT; Install Instructions 1. Locate Dash8_32BWHPack01 (C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\Dash8_32BWHPack01) 2. Open DTG_Amtrak_Dash_8-32BWH_Sound_And_Physics_Mod_Pack.rar 3. Drag the file folders from the .rar in step 2 into the directory you opened in step 1. 4. The installation should be complete. Run TS2016 to check. 5. If installation is botched or does not work, to back up to original files, delete the folders from step 3. User's Manual: Upon installation, the pack defaults to using the HEP physics and sounds. In order to switch physics/sounds, follow the steps below: 1. Open the following directories: a. "C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\Dash8_32BWHPack01\RailVehicles\Simulation" b. "C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\Dash8_32BWHPack01\Audio\RailVehicles\Diesel\Dash8_32BWH\Engine" 2. In each of those directories, you will see two folders (one for each set of locomotive physics/sounds): a. "HEP" b. "No HEP" 3. Once you choose which set of physics/sounds to use, open the respective type folder in both directories from step 1. 4. Copy (CTRL + C) all files you find in the opened folder located in directory 1a. 5. Proceed back to directory 1a and paste (CTRL + V) the copied files into the directory; overwrite (replace) when prompted. 6. Copy (CTRL + C) all files you find in the opened folder located in directory 1b. 7. Proceed back to directory 1b and paste (CTRL + V) the copied files into the directory; overwrite (replace) when prompted. 8. If the previous 7 steps were completed properly, the physics swap should be successful; run TS2016 to check. For adventurous players/developers, there are actually two sets of no-HEP notch 8 engine sounds included. If you can figure out how to swap between those two subsets, then have fun and decide for yourself which sounds better. Thank you for downloading and installing. Enjoy =) Download Link: http://www.mediafire.com/download/kviig9727y6434l/TS2016_DTG_Amtrak_Dash_8-32BWH_Sound_And_Physics_Mod_Pack.rar Facebook Page: http://www.facebook.com/FanRailerMODS/ Link to comment Share on other sites More sharing options...
Fan Railer Posted March 1, 2016 Author Share #41 Posted March 1, 2016 Link to comment Share on other sites More sharing options...
Fan Railer Posted March 2, 2016 Author Share #42 Posted March 2, 2016 Link to comment Share on other sites More sharing options...
Fan Railer Posted March 4, 2016 Author Share #43 Posted March 4, 2016 Link to comment Share on other sites More sharing options...
DaTransitMan4608 Posted March 6, 2016 Share #44 Posted March 6, 2016 This is a sign that I'm gonna enjoy my 19th birthday. Albeit they'll be about a week early. http://train-simulator.com/arriving-soon-nj-transit-multilevels/ Link to comment Share on other sites More sharing options...
Fan Railer Posted March 9, 2016 Author Share #45 Posted March 9, 2016 This is a sign that I'm gonna enjoy my 19th birthday. Albeit they'll be about a week early. http://train-simulator.com/arriving-soon-nj-transit-multilevels/ Dates are always subject to change. Link to comment Share on other sites More sharing options...
Fan Railer Posted March 14, 2016 Author Share #46 Posted March 14, 2016 In preparation for the release of the NJT Multilevels, I have updated the ALP-46/ALP-46A mod pack with a new file structure that eliminates the need to manually switch between 46 and 46A sounds and physics outside of the game. You can now select both locomotives simultaneously in the quick drive consist editor. Read the readme file for more info. Enjoy =) Download: http://www.mediafire.com/download/v1go2laq8afpe0f/TS2016_DTG_NJT_ALP-46_Sound_And_Physics_Mod.rar Facebook Page: http://www.facebook.com/FanRailerMODS/ Link to comment Share on other sites More sharing options...
Fan Railer Posted March 17, 2016 Author Share #47 Posted March 17, 2016 This is the DTG New Jersey Transit North Jersey Coast Line ALP-46 (46A) & Comet & Multilevel Car Physics & Sound Mod Pack V2.0 In order to utilize this freeware physics & sound upgrade, you must have purchased the "Train Simulator: NJT ALP-46 Loco Add-On" available here: http://store.steampowered.com/app/258658/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics & sound enhancements found in this pack for personal use if you so choose. THIS IS BOTH A PHYSICS AND SOUND UPGRADE PACK. The purpose of this pack is to make minor physics adjustments to the ALP-46 locomotive, include an ALP-46A Physics set and road numbers, and introduce more accurate sounds for the DLC. Version 1.0 includes updated horn and bell sounds from Chris Reynolds (MilwaukeeNorth418). Many thanks to him for allowing me to use his sounds free of charge for this mod. Version 1.5 includes horn sound for Comet V from Chris Reynolds (MilwaukeeNorth418) and interior bell sound from me. Version 1.6 eliminates the ability to power brake. Version 1.8 updates Comet Car drag coefficients to Amfleet standards (drag reduced). Version 1.9 eliminates the need to manually swap files (you can now select the ALP-46 and ALP-46A simultaneously) Version 2.0 includes the Multilevel Mod Pack update. General Parameter Change Log (Physics): 1. Slight tweak of TE and Dynamic Brake curves. 2. Include physics and road numbers for ALP-46A. Accessible via quick drive consist builder (no need to manually swap files). 3. V2.0 includes Multilevel physics mod (reduced resistance coefficient, locomotive compatibility patch; see quick drive consist builder). General Parameter Change Log (Sounds): 1. New K5LA horn and steel bell recorded directly off of an ALP-46 unit. 2. New Comet IV door chime included. 3. Replaced default traction motor sounds and code with custom code and new traction motor sounds (for both ALP-46 and ALP-46A). 4. Includes both steel bell and e-bell 5. Removes the annoying non-mono brake sounds from the Comet cars. 6. V2.0 includes new Multilevel horn/bell/door sounds and new Comet V door sounds. No need to manually swap files. Technical specifications for ALP-46/46A: 1. Bombardier ALP-46 (5480 kW THP; GTO Inverters) a. Starting tractive effort of 71,000 lbs (316 kN) b. Continuous tractive effort of 57,840 lbs (257.0447 kN) @ 47.7 mph c. Dynamic Brake effort of 34,000 lbs (150 kN) @ 83.53 mph; flat curve down to 5 mph, fade to 0 lbs @ 2 mph. d. Wheel horsepower of 7,456 hp (5,480 kW) @ 47.7 mph e. Maximum speed of 100 mph f. Weight = 207,000 lbs (92.41 imperial tons) g. Max traction amps = 710 h. Max brake amps = 340 2. Bombardier ALP-46A (5600 kW THP; IGBT Inverters) a. Starting tractive effort of 71,000 lbs (316 kN) b. Continuous tractive effort of 53,279.71 lbs (237 kN) @ 53 mph c. Dynamic Brake effort of 34,000 lbs (150 kN) @ 83.53 mph; flat curve down to 5 mph, fade to 0 lbs @ 1 mph. d. Wheel horsepower of 7,504 hp (5,600 kW) @ 53 mph e. Maximum speed of 125 mph f. Weight = 207,000 lbs (92.41 imperial tons) g. Max traction amps = 710 h. Max brake amps = 340 IMPORTANT; Install Instructions 1. Open the following directory: "C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\DTG\NJT-Alp46" 2. Open the "DTG_NJT_ALP-46_Sound_And_Physics_Mod.rar" file 3. Drag both folders from the .rar file into the directory from step 1. 4. Physics & Sound mod installation is complete. 5. Run TS2016 to confirm. Thank you for downloading and installing. Please contact me if there is a problem with the functionality of this mod pack. Enjoy =) Download link: http://www.mediafire.com/download/v1go2laq8afpe0f/TS2016_DTG_NJT_ALP-46_Sound_And_Physics_Mod.rar Facebook Page: http://www.facebook.com/FanRailerMODS/ ALP-45DP Mod: http://www.mediafire.com/download/mfkxx0sb20x3te9/TS2016_DTG_NJT_NJCL_ALP-45DP_And_Comet_Physics_And_Sound_Mod.rar Link to comment Share on other sites More sharing options...
Fan Railer Posted March 17, 2016 Author Share #48 Posted March 17, 2016 Redownload this again for the "wheelslip during braking" hotfix. Link to comment Share on other sites More sharing options...
Fan Railer Posted March 22, 2016 Author Share #49 Posted March 22, 2016 This is the GE Dash 9-44CW conversion-to-AC4400CW physics mod pack. In order to utilize this freeware physics upgrade, you must have purchased the "Train Simulator: BNSF Dash 9 Loco Add-On" pack available at Steam: http://store.steampowered.com/app/208356/ This is a freeware pack; in no way is it to be used for commercial purposes. You are free, however to further modify the physics enhancements found in this pack for personal use if you so choose. THIS IS NOT A SOUND UPGRADE PACK. Physics adjustments made around the existing sounds. The purpose of this pack is to convert the locomotive over from Dash 9-44CW operating characteristics to AC4400CW characteristics for the specific purpose of operating with Metrolink equipment. General Parameter Change Log: 1. Adjusted locomotive weights slightly. 2. Adjusted tractive effort ratings and curves for individual locomotive models based on the specifications listed below. 3. Adjusted dynamic brake effort ratings and curves for individual locomotive models based on the specifications listed below. 4. Adjusted fuel consumption. 5. Reduced amount of coupler stretch. 6. Changed brake pipe pressure specification from 90 PSI to 110 PSI for passenger operations. 7. Changed road numbers for "Dash9-44CW BNSF Clean" unit to 30 confirmed Metrolink AC44 units. 8. Renamed "Dash9-44CW BNSF Clean" unit to "AC4400CW BNSF Clean [110PSI]" for easy identification & use in quick drive consist editor. *all other versions of the Dash 9 are untouched* Specifications for individual models: 1. GE AC4400CW (GE 7FDL-16; 4650 GHP) a. Starting tractive effort of 180,000 lbs (800.68 kN) up to 9.1547 mph. b. Traction horsepower at wheel is 4,390 hp (3,276.12 kW) c. Max Dynamic Brake effort of 98,000 lbs (435.926 kN) from 18 mph to 3 mph; fade to 0 lbs @ 0.5 mph. d. Dynamic Brake horsepower at wheel is 4,700 hp (3,507 kW). e. Increased weight of 190.1786 metric tons (426,000 lbs). f. Maximum speed of 70 mph. g. Fuel consumption @ notch 8 is 210 gallons per hour. h. Prime mover RPM range is 315 to 1050. i. Ammeter range is -980 to 1800. IMPORTANT; Install Instructions 1. Locate the Dash9Pack01 asset folder (C:\Program Files (x86)\Steam\SteamApps\common\RailWorks\Assets\RSC\Dash9Pack01) 2. Open DTG_BNSF_Metrolink_GE_AC4400CW_Physics_Mod.rar 3. Drag the file folder from the .rar in step 2 into the directory you opened in step 1. Overwrite if asked. 4. The installation should be complete. Run TS2016 to check. Thank you for downloading and installing. Enjoy =) Download link: http://www.mediafire.com/download/5692o8789ekdl4h/TS2016_DTG_BNSF_Metrolink_GE_AC4400CW_Physics_Mod.rar Facebook page: http://www.facebook.com/FanRailerMODS/ Link to comment Share on other sites More sharing options...
Fan Railer Posted March 24, 2016 Author Share #50 Posted March 24, 2016 Hoboken all the way down to Bay Head: Link to comment Share on other sites More sharing options...
