darkstar8983 Posted December 4, 2017 Share #5826 Posted December 4, 2017 2 hours ago, T to Dyre Avenue said: If you just add more trains, then you’d have even more trains backing up the local tracks waiting to get into 71st - Continental. And you’d be over-serving the Sea Beach Line with all the extra trains that would be needed to make up for the loss of the . Seems like an awfully complicated solution for 2nd Ave train frequency. Cutting midday Brighton Local service down to just 6 tph isn’t going to sit well with Brighton Line riders. Or the can be kept at 8 min frequency. It was just to make sure headway’s are even in manhattan (something that is not the case at this time) example: train Broadway Express every 10 mins comes at 0:00, 0:10 0:20, 0:30, 0:40, 0:50 train Broadway express every 8 mins comes at 0:04, 0:12, 0:22, 0:28, 0:36, 0:44, 0:52, 1:02, 1:08, 1:16, 1:24 1:32, 1:42, 1:48, 1:56, 2:04 you end up with uneven frequency total on the Broadway express currently, If you implement 10 min frequency you could have the come at 5, 15, 25, 35, 45, and 55 past and headway’s will be even. alternatively, you could in the future proposal increase the to 8 mins but then the on Sea Beach would not be necessary at that point (overserving Sea Beach) 0 Quote Link to comment Share on other sites More sharing options...
darkstar8983 Posted December 4, 2017 Share #5827 Posted December 4, 2017 I would have personally preferred keeping the current Broadway Setup but then would have heard the backlash and the “ train is causing the clog up on Broadway and does not allow for service increases due to the merge between express and local” rants. I had proposed an split similar to how the does it in Queens but the track capacity does not allow for such a split of service to be effective at handling crowds either on 2 Av or in Astoria. So lo and behold, the previous posting I made yesterday was born. Astoria keeps the familiar , the remains a weekday service and a supplement on both Sea Beach/4 Av and on Broadway/2 Av 0 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted December 4, 2017 Share #5828 Posted December 4, 2017 (edited) Just a question: Do you think that moving the Broadway merge to 57th would help? Brooklyn-bound trains won't have to slow down to switch as the curve from 60th street is tight. In turn though, this could delay trains as they use sail into 57th. As for northbound I don't really see any problems. Edited December 4, 2017 by R68OnBroadway 0 Quote Link to comment Share on other sites More sharing options...
darkstar8983 Posted December 4, 2017 Share #5829 Posted December 4, 2017 (edited) 6 minutes ago, R68OnBroadway said: Just a question: Do you think that moving the Broadway merge to 57th would help? Brooklyn-bound trains won't have to slow down to switch as the curve from 60th street is tight. In turn though, this could delay trains as they use sail into 57th. As for northbound I don't really see any problems. I think the problem is the proximity of the station to the switch, in that no northbound trains would be able to platform at 57 St- 7 Av while the crosses over. Also 49 St has too much ridership for just the to handle. southbound would present a similar issue with the forced to stop within the curve under Central Park . i think a similar issue was present at Essex St when the platforms bound for Metropolitan Av. The Jamaica Center train could not platform at Essex St to facilitate the cross-platform transfer. I don’t know if this issue has been resolved yet. Edited December 4, 2017 by darkstar8983 0 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted December 4, 2017 Share #5830 Posted December 4, 2017 45 minutes ago, darkstar8983 said: I think the problem is the proximity of the station to the switch, in that no northbound trains would be able to platform at 57 St- 7 Av while the crosses over. Also 49 St has too much ridership for just the to handle. southbound would present a similar issue with the forced to stop within the curve under Central Park . The switches shouldn't interfere as they don't pass through the platform or anything, and usually when the stops on the northbound side there is still about 6-10 ft of platform by the northern end staircase. If this were somehow an issue though, there are still diamond crossings south of the station. As for 49th, there still is the during busy hours. The will still stop there on weekends and late nights, just not during rush hrs and middays. Evenings could be adjusted based on ridership. For the issue, I would give the priority, and the could hold on the southbound track. Considering that the goes rather fast down Broadway, it would be more efficient to hold the and let the pass than vice versa. 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted December 5, 2017 Share #5831 Posted December 5, 2017 On 12/3/2017 at 7:54 AM, CDTA said: This is a bit out there but I wanna know what you guys think So I was thinking of running the Flushing Express track into a new tunnel going down 34th st, then, when it gets to Hudson Yards, it loops back around and goes down 34th heading East on a second parallel track, in the morning, and reverse in the evening. A new yard would be built at the ConEd site to store the trains during the mid-day since the whole thing is technically only one track (I don't see why ConEd couldn't just build whatever they needed to on top of the yard). Doing this would double capacity on the Flushing Line since the local can now run a full 30TPH, and the express can run a full 30 TPH all while only needing new track up to Queens Plaza. Plus, since the 34th st section is technically double-tracked, when the express isn't running you can still operate the section independently as a 34th st Crosstown line. AND since the tunneling would be all new construction, you can build it to B-division standards for that little bit of extra capacity since the elevated is already built to B-division standards. You'd also need a huge expansion of Corona Yard, but seeing how right now the surrounding area is all surface parking lots that shouldn't be too difficult. The entire issue with running service like this is that the 30TPH in one direction has to come from somewhere, so you need a really huge storage yard at both ends of the third track. 0 Quote Link to comment Share on other sites More sharing options...
BreeddekalbL Posted December 11, 2017 Share #5832 Posted December 11, 2017 To those in the rbb thread who proposed sending the up the L.I.E. what will replace the at from woodhaven to 71st 0 Quote Link to comment Share on other sites More sharing options...
Lance Posted December 11, 2017 Share #5833 Posted December 11, 2017 I'd imagine it would be expanded service during the daytime hours. 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 11, 2017 Share #5834 Posted December 11, 2017 (edited) That too could be an issue...even more so than if the were to be extended onto the RBB. Because in the case of the via RBB, the with its 480-foot trains, would be left as the only service at one QB local station, 67th Ave. In the case of extending the via the L.I.E., two QB local stations would definitely be affected, 67th Ave and the much busier 63rd Drive. Possibly three stations, depending whether the turns off QB east or west of Woodhaven. Presumably, the would be upgraded to 7-day service. Much better than having to send the or down the local tracks between 71st and Roosevelt on weekends to cover for the . Or Woodhaven, if that station were to be converted to an express stop and have crossover switches installed. Edited December 11, 2017 by T to Dyre Avenue Additional info 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted December 11, 2017 Share #5835 Posted December 11, 2017 I mean, if you’re worried about train length, you could just send the up the LIE... That also has the benefit of not lengthening the insane route.. 0 Quote Link to comment Share on other sites More sharing options...
Coney Island Av Posted December 11, 2017 Share #5836 Posted December 11, 2017 18 hours ago, BreeddekalbL said: To those in the rbb thread who proposed sending the up the L.I.E. what will replace the at from woodhaven to 71st I think an extension of service would cover Forest Hills, because the RBB is a line in waiting. If both are built, nothing will cover 67 Av. 2 Quote Link to comment Share on other sites More sharing options...
BreeddekalbL Posted December 12, 2017 Share #5837 Posted December 12, 2017 (edited) 8 hours ago, Lance said: I'd imagine it would be expanded service during the daytime hours. Thats for if the rbb and LIE HHE line were built where the takes the rbb while the takes the L.I.E hhe line Edited December 12, 2017 by BreeddekalbL 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted December 12, 2017 Share #5838 Posted December 12, 2017 On 12/10/2017 at 6:55 PM, BreeddekalbL said: To those in the rbb thread who proposed sending the up the L.I.E. what will replace the at from woodhaven to 71st Are those stations really so busy that they need two local services? Personally, I think LIE subway service is just never going to happen because it's way too complex to build; how exactly should it weave through the Woodhaven/Queens Blvd/LIE interchange? 0 Quote Link to comment Share on other sites More sharing options...
BreeddekalbL Posted December 12, 2017 Share #5839 Posted December 12, 2017 3 hours ago, bobtehpanda said: Personally, I think LIE subway service is just never going to happen because it's way too complex to build; how exactly should it weave through the Woodhaven/Queens Blvd/LIE interchange? The way i would is dive it before junction blvd 0 Quote Link to comment Share on other sites More sharing options...
IAlam Posted December 12, 2017 Share #5840 Posted December 12, 2017 (edited) Quick Question cause I'm almost never on this thread. But has anyone ever suggested combined strip maps for the R143? It seem there is enough space for both lines to use that strip map. Edited December 12, 2017 by IAlam 2 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 12, 2017 Share #5841 Posted December 12, 2017 (edited) The point of doing a combined strip map is if the lines on the map actually run on the same tracks for a significant portion of their routes, like the and do. The and only have one transfer point at Broadway Junction and they don't share any tracks with each other, so a combined strip map for them wouldn’t be worth doing. Now, if you wanted to run a part-time service from Canarsie via the Williamsburgh Bridge to the 6th Ave line using R143s, then you could have a combined strip map. Because then you’d have the and sharing tracks/stations from Rockaway Parkway to Broadway Junction (with the stopping on the platform at Bway Jct). Of course, that all depends on track capacity on the Willy B and 6th Ave, how many cars would be available for the service and, of course, what the forecasted ridership might be. Edited December 12, 2017 by T to Dyre Avenue 0 Quote Link to comment Share on other sites More sharing options...
IAlam Posted December 13, 2017 Share #5842 Posted December 13, 2017 2 hours ago, T to Dyre Avenue said: The point of doing a combined strip map is if the lines on the map actually run on the same tracks for a significant portion of their routes, like the and do. The and only have one transfer point at Broadway Junction and they don't share any tracks with each other, so a combined strip map for them wouldn’t be worth doing. Now, if you wanted to run a part-time service from Canarsie via the Williamsburgh Bridge to the 6th Ave line using R143s, then you could have a combined strip map. Because then you’d have the and sharing tracks/stations from Rockaway Parkway to Broadway Junction (with the stopping on the platform at Bway Jct). Of course, that all depends on track capacity on the Willy B and 6th Ave, how many cars would be available for the service and, of course, what the forecasted ridership might be. The idea would be to have both strip maps side by side. Although no portions of the strip map would be shared, it seems there is enough space to fit both lines there. 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 14, 2017 Share #5843 Posted December 14, 2017 (edited) That's confusing. Especially because the and have a transfer point at Broadway Junction and both have separate stations at Halsey and Lorimer streets and Myrtle Ave, so all four of those station names would have to be printed twice. Edited December 14, 2017 by T to Dyre Avenue 0 Quote Link to comment Share on other sites More sharing options...
IAlam Posted December 17, 2017 Share #5844 Posted December 17, 2017 On 12/14/2017 at 4:28 PM, T to Dyre Avenue said: That's confusing. Especially because the and have a transfer point at Broadway Junction and both have separate stations at Halsey and Lorimer streets and Myrtle Ave, so all four of those station names would have to be printed twice. It doesn't make sense to have the R143's operate on the without a proper strip map to accommodate it. On the strip map they have a lot of stops with the same name in Manhattan. If it works fine over there, I don't see why it's an issue for the . 1 Quote Link to comment Share on other sites More sharing options...
Lance Posted December 18, 2017 Share #5845 Posted December 18, 2017 The problem with this comparison is that the and share quite a large number of stops in both the Bronx and in Brooklyn, which allows for a shared line map. This is not the case as it pertains to the and lines. The only stop that is shared by the two lines is at Broadway Junction. A combined line map would not be possible. In fact, it would have to be in essence two separate line maps on one sheet. It would likely fit on the line map matrix, but I cannot see the benefit here. There are in fact so few 143s that operate in service that I feel it's not worth the effort. Perhaps if the 143s car assignment was actually split between the and lines, I could see the value, but this is not the case. These cars pop up on the as often as the 160s do on the line. 3 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 18, 2017 Share #5846 Posted December 18, 2017 Exactly, and those R143s (along with the R32s and 42s) won't be on the for much longer anyway once there are enough R179s in service as well. 2 Quote Link to comment Share on other sites More sharing options...
Jemorie Posted December 19, 2017 Share #5847 Posted December 19, 2017 On 12/4/2017 at 2:30 PM, T to Dyre Avenue said: If you just add more trains, then you’d have even more trains backing up the local tracks waiting to get into 71st - Continental. And you’d be over-serving the Sea Beach Line with all the extra trains that would be needed to make up for the loss of the . Seems like an awfully complicated solution for 2nd Ave train frequency. Cutting midday Brighton Local service down to just 6 tph isn’t going to sit well with Brighton Line riders. I don't think the Brighton Line is that busy during the non-rush hours. 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 19, 2017 Share #5848 Posted December 19, 2017 It may not be, but I don't think Brighton Line ridership is so light during middays that it can justify only 6 tph. 0 Quote Link to comment Share on other sites More sharing options...
P3F Posted December 19, 2017 Share #5849 Posted December 19, 2017 2 hours ago, T to Dyre Avenue said: It may not be, but I don't think Brighton Line ridership is so light during middays that it can justify only 6 tph. It gets enough ridership for the to run the there at the time, even though it doesn't run to Concourse. 0 Quote Link to comment Share on other sites More sharing options...
CDTA Posted December 20, 2017 Share #5850 Posted December 20, 2017 Here's a thought. What about connecting PATH from WTC to Atlantic Terminal, and up the Atlantic Branch? This would be much more useful than the Atlantic Branch in its current form, and it'd allow people from NJ to get a one seat ride to a new office hub, Downtown Brooklyn. You don't have to do any work on the Atlantic Branch itself because PATH is FRA compliant, and you could easily from there expand it to JFK, providing for the first time a one seat ride to downtown, Floral Park, and Valley Stream, not only providing eastern Queens with vital rail service but also allowing the LIRR to speed up service and focus on its main job of commuting customers from LI. You wouldn't have to really do any work either aside from JFK because again, PATH is FRA compliant so you don't need to do anything special for them to run. 0 Quote Link to comment Share on other sites More sharing options...
