T to Dyre Avenue Posted November 22, 2018 Share #7251 Posted November 22, 2018 (edited) On 11/18/2018 at 9:35 PM, subwaykid256 said: Sending the to Bay Ridge with no Upper/Midtown Manhattan service is ridiculous. When the went there it wasn't as popular as the . I'm not saying that it shouldn't happen. But it shouldn't happen with it being the sole local train via 4 Av. The plays a big role as it is being the sole train that is local in three boroughs. And connecting popular Neighborhoods like Astoria and Bay Ridge to the city. If you guys are saying that having the run to 71st Av wouldn't work. Then the alone to Bay Ridge wouldn't work But I don’t think anyone has suggested running the alone to 71st Ave. At one time, it was the primary Queens Blvd local train, but that finally stopped in 1987, when the replaced the then-weekdays only . And the QB line local stations serve a much more densely populated area than the 4th Ave local stops. So it’s better for the QB local stops to have as much Midtown-bound service as possible, whereas given how many people bail on the in Brooklyn because of how long the takes to get to Midtown from there, I think you can get away with a Nassau Line service such as the on 4th Ave local, provided it actually goes to Bay Ridge (unlike the old ). Nassau does offer more transfers than Lower Broadway. Edited November 22, 2018 by T to Dyre Avenue 0 Quote Link to comment Share on other sites More sharing options...
BreeddekalbL Posted November 22, 2018 Share #7252 Posted November 22, 2018 1 hour ago, T to Dyre Avenue said: But I don’t think anyone has suggested running the alone to 71st Ave. At one time, it was the primary Queens Blvd local train, but that finally stopped in 1987, when the replaced the then-weekdays only . And the QB line local stations serve a much more densely populated area than the 4th Ave local stops. So it’s better for the QB local stops to have as much Midtown-bound service as possible, whereas given how many people bail on the in Brooklyn because of how long the takes to get to Midtown from there, I think you can get away with a Nassau Line service such as the on 4th Ave local, provided it actually goes to Bay Ridge (unlike the old ). Nassau does offer more transfers than Lower Broadway. But I thought those from South Brooklyn want Broadway service and in my proposal I have the extended to 9th Ave as a rush hour supplement for the Different question If track gauges on lirr and subway are the same say in the future they decide to route the via the Port Washington branch or have the run it's proposed extension you would have to only tear up the platforms to fit the line standards and rip up the 3rd rail and I bet the extension would be much cheaper then the via pw 0 Quote Link to comment Share on other sites More sharing options...
engineerboy6561 Posted November 22, 2018 Share #7253 Posted November 22, 2018 3 hours ago, BreeddekalbL said: But I thought those from South Brooklyn want Broadway service and in my proposal I have the extended to 9th Ave as a rush hour supplement for the Different question If track gauges on lirr and subway are the same say in the future they decide to route the via the Port Washington branch or have the run it's proposed extension you would have to only tear up the platforms to fit the line standards and rip up the 3rd rail and I bet the extension would be much cheaper then the via pw It looks like it would be about the same, with only a slight advantage to the . If you assume the tail tracks are under Brewer Blvd, then you have to bring them under the South Jamaica Houses and you could probably get them to connect to the LIRR tracks around 109 Av. From there you're looking at additional stops at 109 Av-ish, Linden Bl, Foch Bl, Baisley Blvd, between 140 Av and 141 Av, and at N Conduit Av to get reasonable stop spacing. You're also going to need to expand the interlocking near Green Acres Mall to allow for all four branches (Babylon, West Hempstead, Far Rockaway, and Long Beach) to fit on those two tracks between St. Albans and Valley Stream. The would require less new track and fewer sharp curves, as you could extend it along Roosevelt and then S-curve it onto the railroad alignment near Parsons. The big things you'd wind up doing that would be expensive are ripping out the mezzanine at the end of the Main St station, and probably lowering the railroad track about 10 additional feet between Main St and Parsons Bl so that you could do a clean merge with the tracks without wrecking anyone's basement. That said, routing the onto those tracks past Flushing seems a bit like a waste of trackage. What I'd personally be interested in doing would be adding infill stops on the PW line at Junction Blvd and Queens Blvd, splitting those two tracks off at the Sunnyside interlocking and running them under Newtown Av to 30 Av, then under the East River to connect with the 2 Av subway at 86 St. At that point you could conceivably run both the and via 2 Av in Manhattan. At that point, the would serve PW and NE Queens, the would serve the Bronx and Harlem, the would serve Forest Hills/71 Av, and the would serve Astoria, with an transfer point at 30 Av/31 St and an transfer at Main St, Flushing (build a proper station house at Roosevelt Av on the railroad and then add a passage under Main St to the ). 0 Quote Link to comment Share on other sites More sharing options...
shiznit1987 Posted November 22, 2018 Share #7254 Posted November 22, 2018 A lot of people like extending the but IMHO that doesn't really solve anything. is maxed out ATM peak direction. What I would like to see is a 34st Crosstown (8) Train complement the : Start at Hudson Yards-34st Stop at 7/8th Aves-Penn Station (Connect to ) 6th Ave-Herald Sq (Connect to ) 5th Ave/Park Av (Connect to ) Once in Queens, turns under 11th st in LIC: Stop at: Vernon Blvd-Jackson Ave (Connect to ) 45th Rd (Right next to Amazon) 43rd Ave It emerges alongside the Astoria Line portal and goes into a rebuilt N side of QBP. From there it uses the existing 2nd Ave El Trackways to join the then runs along a new 3-track upper level structure all the way to Willets Pt. 0 Quote Link to comment Share on other sites More sharing options...
shiznit1987 Posted November 22, 2018 Share #7255 Posted November 22, 2018 Idea for 5th Ave Subway: Jamaica-Parsons/Archer to 59st-5th Ave, Manhattan Bay Ridge-95st to Jamaica-179st The 5th Ave subway starts at 1st Ave and Delancey Sts where 2 tracks from the Nassau Line and the 2 from the Williamsburg Bridge form a 4 track trunk running up 1st Ave. The line then turns down 14st (Under the ) with a stop at Union Square. Then the line heads up 5th Ave making these stops: 23rd st 34th st 42nd st 50th st 59th st Two tracks terminate at 59th st (provisions for extension built in) for the while the other two take over the 63rd st tunnel to Queens. Queens Blvd would look like this: Current service pattern 71st-Continential to CI via QB Local 179st-Jamaica to Bay Ridge via QB Express/63st tunnel/5th Ave line Same except cut back to Whitehall. The reason I think this works better than continuing the 2nd Ave line south is because a line down 5th puts you within walking distance of all the offices along Park/Madison/6th aves. People will use this versus trying to pack the Lex. 0 Quote Link to comment Share on other sites More sharing options...
BreeddekalbL Posted November 23, 2018 Share #7256 Posted November 23, 2018 16 hours ago, engineerboy6561 said: It looks like it would be about the same, with only a slight advantage to the . If you assume the tail tracks are under Brewer Blvd, then you have to bring them under the South Jamaica Houses and you could probably get them to connect to the LIRR tracks around 109 Av. From there you're looking at additional stops at 109 Av-ish, Linden Bl, Foch Bl, Baisley Blvd, between 140 Av and 141 Av, and at N Conduit Av to get reasonable stop spacing. You're also going to need to expand the interlocking near Green Acres Mall to allow for all four branches (Babylon, West Hempstead, Far Rockaway, and Long Beach) to fit on those two tracks between St. Albans and Valley Stream. The would require less new track and fewer sharp curves, as you could extend it along Roosevelt and then S-curve it onto the railroad alignment near Parsons. The big things you'd wind up doing that would be expensive are ripping out the mezzanine at the end of the Main St station, and probably lowering the railroad track about 10 additional feet between Main St and Parsons Bl so that you could do a clean merge with the tracks without wrecking anyone's basement. That said, routing the onto those tracks past Flushing seems a bit like a waste of trackage. What I'd personally be interested in doing would be adding infill stops on the PW line at Junction Blvd and Queens Blvd, splitting those two tracks off at the Sunnyside interlocking and running them under Newtown Av to 30 Av, then under the East River to connect with the 2 Av subway at 86 St. At that point you could conceivably run both the and via 2 Av in Manhattan. At that point, the would serve PW and NE Queens, the would serve the Bronx and Harlem, the would serve Forest Hills/71 Av, and the would serve Astoria, with an transfer point at 30 Av/31 St and an transfer at Main St, Flushing (build a proper station house at Roosevelt Av on the railroad and then add a passage under Main St to the I knew the would be slightly cheaper cause with the you will have to close main Street to reconfigure it 0 Quote Link to comment Share on other sites More sharing options...
subwaykid256 Posted November 23, 2018 Share #7257 Posted November 23, 2018 I assume the frequency of Montague Tunnel is 24 TPH 71 Av- Euclid Av (via State St) 8 TPH Astoria-Brighton Express 8 TPH B'way Junction - Bay Ridge 95 St 8 TPH 0 Quote Link to comment Share on other sites More sharing options...
KK 6 Ave Local Posted December 2, 2018 Share #7258 Posted December 2, 2018 Nobody's posted in a while, let's start some discussion about proposals that don't need any new track 0 Quote Link to comment Share on other sites More sharing options...
shiznit1987 Posted December 3, 2018 Share #7259 Posted December 3, 2018 6 hours ago, KK 6 Ave Local said: Nobody's posted in a while, let's start some discussion about proposals that don't need any new track This may be cheating, but earlier there was discussion on how to de-interline the Upper IND (Concourse/CPW/Inwood) and my proposal runs like this: Just below 50st/8th Ave, build a switch between the upper level Local track and the Express Track to allow 8th Ave Express Trains to serve 50th St. All trains will slide over to the local track, stopping at 50th St Upper Level ( service is unaffected). The and will both continue up the CPW Local tracks to 168st, while the and will take over the CPW Express. Overall, the service pattern would look like this: 168st-Wash Hts to Mott Av-Far Rock or Lefferts Blvd-Ozone Park via CPW Local, 8th Ave Express, Fulton Express (All Times, Local late nights) 207th St-Inwood to Brighton Beach via CPW Express, 6th Ave Express, Manhattan Bridge, Brighton Express. Cut back to Prospect Park during weekends and overnights (after 10pm) Current routing and schedule. Current routing and schedule. Yes, this technically requires a switch instillation, but in the grand scheme of things this untangles the upper IND a great deal. Wash Heights and Inwood get direct 6th ave express service, the gets shortened somewhat, and CPW has a boost in service. Oh...and Brighton riders get their 6th Ave service back. 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 3, 2018 Share #7260 Posted December 3, 2018 2 hours ago, shiznit1987 said: This may be cheating, but earlier there was discussion on how to de-interline the Upper IND (Concourse/CPW/Inwood) and my proposal runs like this: Just below 50st/8th Ave, build a switch between the upper level Local track and the Express Track to allow 8th Ave Express Trains to serve 50th St. All trains will slide over to the local track, stopping at 50th St Upper Level ( service is unaffected). The and will both continue up the CPW Local tracks to 168st, while the and will take over the CPW Express. Overall, the service pattern would look like this: 168st-Wash Hts to Mott Av-Far Rock or Lefferts Blvd-Ozone Park via CPW Local, 8th Ave Express, Fulton Express (All Times, Local late nights) 207th St-Inwood to Brighton Beach via CPW Express, 6th Ave Express, Manhattan Bridge, Brighton Express. Cut back to Prospect Park during weekends and overnights (after 10pm) Current routing and schedule. Current routing and schedule. Yes, this technically requires a switch instillation, but in the grand scheme of things this untangles the upper IND a great deal. Wash Heights and Inwood get direct 6th ave express service, the gets shortened somewhat, and CPW has a boost in service. Oh...and Brighton riders get their 6th Ave service back. I recall seeing a proposal from 1991 for running the then 6th Avenue in a manner very similar to your proposed and an in a similar manner to you proposed (but fully local and only to Euclid Avenue). It never got implemented. 0 Quote Link to comment Share on other sites More sharing options...
W4ST Posted December 9, 2018 Share #7261 Posted December 9, 2018 (edited) I've been thinking about Phase 2 of SAS. I would prefer for it to go straight into the Bronx, and end at 3rd Avenue / 149th Street. However, it looks like they will build the segment to 125th and Lexington. Building it to 125th and Lexington alone is relatively useless, as just about nobody already on the will make the transfer, and probably only a few people on the , so I think they must extend it. Going across 125th Street is a good start, but I think that they should make the line go across the river into New Jersey. The line would cross the river, with a stop at Edgewater. Then it would go through Palisades Park, Ridgefield Park, and Bogota, before ending at Hackensack. Edgewater and Palisades Park do not have good transit, with only infrequent buses, so this would help them out. It would also encourage more buildings to be built in this part of New Jersey, which is geographically fairly close to Midtown, but is in a location where it takes a long time (around 45 minutes) to get to Midtown on infrequent buses. These would be the stops, starting from 125th Street and Lexington Avenue. 125th Street and Lexington Avenue (connection to ) 125th Street and Malcolm X Blvd (connection to ) 125th Street and St. Nicholas Ave (connection to ) This station would have 3 tracks so that trains could terminate here if necessary. 125th Street and Broadway (connection to ) This station would have a diamond crossover just east of the station, so that this station could be used as a terminal before the New Jersey portion is built. Edgewater - Hudson Ave Central Blvd and Anderson Ave Central Blvd and Bergen Blvd Central Blvd and Broad Ave Central Blvd and Depot Pl (Connection to HBLR, when it gets extended there) Just before or just after this station, the line would go aboveground. Overpeck Corporate Office Park (west of this station, the line would be built over I-95, and then I-80) Park Ave and I-80 Palisade Ave and I-80 (West of this station, the line would be built next to or over the New York Susquehanna and Western Railroad track) Bogota - River Rd and W Fort Lee Rd Hackensack - Main Street (Connection to the Passaic - Bergen Rail Line, if it gets built) This is not a priority (I think some extensions in Queens and the Bronx should be built first) but if the MTA builds a cross-125th Street line, I think this should be considered. Forgot to add: The Bronx extension can be built as well, this is just another extension that could be built. Edited December 9, 2018 by W4ST 1 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 10, 2018 Share #7262 Posted December 10, 2018 Wow, that’s quite a ways into Jersey for a subway line. Perhaps that should be a project for Port Authority. Maybe have it function strictly as a crosstown line on 125th, and not feed into SAS. 0 Quote Link to comment Share on other sites More sharing options...
Around the Horn Posted December 10, 2018 Share #7263 Posted December 10, 2018 Hackensack sounds like a job for Gateway or the RPA's proposed commuter rail loop, not the subway... 3 Quote Link to comment Share on other sites More sharing options...
W4ST Posted December 11, 2018 Share #7264 Posted December 11, 2018 20 hours ago, T to Dyre Avenue said: Wow, that’s quite a ways into Jersey for a subway line. Perhaps that should be a project for Port Authority. Maybe have it function strictly as a crosstown line on 125th, and not feed into SAS. That's a good idea. Perhaps, once SAS is extended into the Bronx, the station at 125 / Lex can be used for this new PATH-like line, which could start there, at 125/2nd Ave, or at 116/2nd Ave. 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted December 11, 2018 Share #7265 Posted December 11, 2018 On 11/22/2018 at 1:46 AM, engineerboy6561 said: That said, routing the onto those tracks past Flushing seems a bit like a waste of trackage. What I'd personally be interested in doing would be adding infill stops on the PW line at Junction Blvd and Queens Blvd, splitting those two tracks off at the Sunnyside interlocking and running them under Newtown Av to 30 Av, then under the East River to connect with the 2 Av subway at 86 St. At that point you could conceivably run both the and via 2 Av in Manhattan. At that point, the would serve PW and NE Queens, the would serve the Bronx and Harlem, the would serve Forest Hills/71 Av, and the would serve Astoria, with an transfer point at 30 Av/31 St and an transfer at Main St, Flushing (build a proper station house at Roosevelt Av on the railroad and then add a passage under Main St to the ). The tricky thing about the subway via is that it leaves riders east of Great Neck in a precarious situation due to the single track. I'm sure east PW riders will be very pissed if you reduce them to a scoot to the subway. After thinking about it for a long time, I mostly find the 7 via PW a waste of time. Extend the 7 under Roosevelt to Broadway LIRR to move some of the Flushing routes out of that congested black hole; it's past the worst of the Northern traffic. If you still want to go further east, go under Northern Blvd and head to Bell/Northern or QCC. The LIRR route is suboptimally located for bus-train connections, and right now PW helps use up capacity on the LIRR tunnels, so that six tracks east go into six tracks west once ESA opens. 0 Quote Link to comment Share on other sites More sharing options...
LGA Link N Train Posted December 12, 2018 Share #7266 Posted December 12, 2018 (edited) On 12/10/2018 at 7:37 PM, bobtehpanda said: After thinking about it for a long time, I mostly find the 7 via PW a waste of time. Extend the 7 under Roosevelt to Broadway LIRR to move some of the Flushing routes out of that congested black hole; it's past the worst of the Northern traffic. If you still want to go further east, go under Northern Blvd and head to Bell/Northern or QCC. The LIRR route is suboptimally located for bus-train connections, and right now PW helps use up capacity on the LIRR tunnels, so that six tracks east go into six tracks west once ESA opens. I'm going to agree with this statement here. In my opinion, No subway line under any circumstance, should take over PW. It sounds like a waste of money if you ask me. Just extend the east, Increase LIRR Port Washington Service (especially when East side Access comes around), Improve the bus Network around Flushing, and you're done. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- On a side note, I've come to fully understand why an service pattern would work perfectly on QBL. I was riding the earlier today, and it got delayed because of an in front of it first, and then an , which didn't help so much. This helped me better understand interlining, and the sometimes negative effects of it. Here's a small proposal I made which only affects QBL and 8th Avenue (Keep in mind that this is under the assumption that QB Local can handle a 3rd Service and Forest Hills wasn't so ..... messed up when it comes to fumigation. Another note I want to point out is that this proposal keeps 8th Avenue Interlined and doesn't affect CPW) - Cut back to WTC and runs at 12 TPH - Altered and now runs between Jamaica Center and Euclid Avenue (15TPH). It will now run express in 8th Avenue. - Unaltered and still running at 15TPH - New Local route from Forest Hills to WTC, via 53rd Street (8 TPH) - Now runs via 63rd Street; Remainder of the route is unaltered (12TPH) - Now Runs to Astoria (15 TPH) with a select 5 to 6 TPH heading to Forest Hills during the Rush Hour. gets increased service of about 12 TPH and the is booted to SAS now running even split headways with the (15+15=30). Any thoughts or questions? Edited December 12, 2018 by LaGuardia Link N Tra 1 Quote Link to comment Share on other sites More sharing options...
shiznit1987 Posted December 13, 2018 Share #7267 Posted December 13, 2018 (edited) 23 hours ago, LaGuardia Link N Tra said: - Now Runs to Astoria (15 TPH) with a select 5 to 6 TPH heading to Forest Hills during the Rush Hour. gets increased service of about 12 TPH and the is booted to SAS now running even split headways with the (15+15=30). Any thoughts or questions? People (Including myself) aren't going to be too pleased about losing service on Queens Blvd. It's actually IMHO tied with the for being the second favorite on QB after the . No one will ride a local that goes through 63rd st. Also, this doesn't really solve the 36st issue. It's a nice thought though. If we're going to go for De-interlining Queens, then we need to simply bite the bullet a build an underground transfer from 63rd/Lex to 59th/Lex so everything flows like this: 63 st/QB Express 53 st/QB Local -> 8th Ave Express/Brooklyn 168 st to WTC 8th Ave Local 207st to Brighton Beach via CPW/6th Ave Exp Current route To SAS via Broadway Express + Bridge Astoria/Broadway Local WIth the exception of the and joining at 145st, the entire B divison is completely merge-less going Bronx/Queens Bound. Edited December 13, 2018 by shiznit1987 Just Thinking 1 Quote Link to comment Share on other sites More sharing options...
LGA Link N Train Posted December 13, 2018 Share #7268 Posted December 13, 2018 27 minutes ago, shiznit1987 said: People (Including myself) aren't going to be too pleased about losing service on Queens Blvd. It's actually IMHO tied with the for being the second favorite on QB after the . No one will ride a local that goes through 63rd st. Also, this doesn't really solve the 36st issue. It's a nice thought though. If we're going to go for De-interlining Queens, then we need to simply bite the bullet a build an underground transfer from 63rd/Lex to 59th/Lex so everything flows like this: 63 st/QB Express 53 st/QB Local -> 8th Ave Express/Brooklyn 168 st to WTC 8th Ave Local 207st to Brighton Beach via CPW/6th Ave Exp Current route To SAS via Broadway Express + Bridge Astoria/Broadway Local WIth the exception of the and joining at 145st, the entire B divison is completely merge-less going Bronx/Queens Bound. Well, as a Queens Blvd Rider myself, I would understand the concern of removing the from QBL, which is why I proposed a Rush Hour Split service (With an Increased service of course). Another concern I’d like to bring up is the 36th Street issue. If trains were put under a strict schedule and ran certain headway’s (under the scenario that our signal system was properly maintained) then it wouldn’t be much of an issue. (Say for example - via 53rd and via 63rd run next to each other entering/exiting 36th Street. The next minute, it would have to be an and doing the same process). Your proposal works too, but I was more or less focusing on a rearrangement of service in order to create more reliable headway’s rather than fully deinterlining. 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted December 13, 2018 Share #7269 Posted December 13, 2018 1 hour ago, shiznit1987 said: People (Including myself) aren't going to be too pleased about losing service on Queens Blvd. It's actually IMHO tied with the for being the second favorite on QB after the . No one will ride a local that goes through 63rd st. Also, this doesn't really solve the 36st issue. It's a nice thought though. If we're going to go for De-interlining Queens, then we need to simply bite the bullet a build an underground transfer from 63rd/Lex to 59th/Lex so everything flows like this: With you here on the Lex-63 connection. Instead of making heavy-handed and questionably necessary investments like ESA, Fulton Center, CBTC, etc, we should be focusing on this sort of 'quick win' investment -- there are *so* many little things we could do with massive effect for low cost. Others on the I'd say are the reconfiguration of the Astoria terminal, a station in Livonia Yard, crossover replacement at Jamaica Center, a flyover for Dyre, etc, etc. About deinterlining 36: the interlocking there isn't inherently limited by geometry or configuration. I'd at least attempt to operate interlined service through there before we throw in the towel -- the is quite popular for a reason, after all... 4 Quote Link to comment Share on other sites More sharing options...
MysteriousBtrain Posted December 14, 2018 Share #7270 Posted December 14, 2018 Without taking Hudson yards into consideration, does anyone think it's possible to have the extend to 12 cars or two 6 car sets in order to improve on maintenance and car consistency? 0 Quote Link to comment Share on other sites More sharing options...
Lance Posted December 14, 2018 Share #7271 Posted December 14, 2018 On 12/12/2018 at 9:41 PM, RR503 said: With you here on the Lex-63 connection. Instead of making heavy-handed and questionably necessary investments like ESA, Fulton Center, CBTC, etc, we should be focusing on this sort of 'quick win' investment -- there are *so* many little things we could do with massive effect for low cost. Others on the I'd say are the reconfiguration of the Astoria terminal, a station in Livonia Yard, crossover replacement at Jamaica Center, a flyover for Dyre, etc, etc. About deinterlining 36: the interlocking there isn't inherently limited by geometry or configuration. I'd at least attempt to operate interlined service through there before we throw in the towel -- the is quite popular for a reason, after all... ¿Por qué no los dos? I'm not saying your ideas don't have merit, far from it, I actually like what you come up with, even if I don't always agree with the ideas. However, the so-called "questionably necessary investments" you mentioned do serve a purpose as well. ESA will free up much needed space at Penn Station by allowing the LIRR to travel to Grand Central. It also has the unintended benefit of facilitating the push for Penn Station Access for Metro-North. The Fulton Center project has streamlined the formerly abysmal transfer at Fulton St without rebuilding the Nassau St tracks, all while recouping some of the costs with the shops above. As for CBTC, well, I've already said my piece on that. We do need to take a more progressive stance on these easier projects, but we cannot ignore the big ones either. 0 Quote Link to comment Share on other sites More sharing options...
transitfan111 Posted December 14, 2018 Share #7272 Posted December 14, 2018 15 hours ago, MysteriousBtrain said: Without taking Hudson yards into consideration, does anyone think it's possible to have the extend to 12 cars or two 6 car sets in order to improve on maintenance and car consistency? You have to purchase new cars, extend platforms, reconfigure some signals, etc and it’ll be more expensive (or about the same) than just fixing the Main Street terminal which is the real chockpoint. It takes trains forever to get in there. 0 Quote Link to comment Share on other sites More sharing options...
shiznit1987 Posted December 15, 2018 Share #7273 Posted December 15, 2018 4 hours ago, Lance said: ¿Por qué no los dos? I'm not saying your ideas don't have merit, far from it, I actually like what you come up with, even if I don't always agree with the ideas. However, the so-called "questionably necessary investments" you mentioned do serve a purpose as well. ESA will free up much needed space at Penn Station by allowing the LIRR to travel to Grand Central. It also has the unintended benefit of facilitating the push for Penn Station Access for Metro-North. The Fulton Center project has streamlined the formerly abysmal transfer at Fulton St without rebuilding the Nassau St tracks, all while recouping some of the costs with the shops above. As for CBTC, well, I've already said my piece on that. We do need to take a more progressive stance on these easier projects, but we cannot ignore the big ones either. Just to piggyback on this: If for anything, ESA should've gone whole hog and moved all LIRR operations to Grand Central. The new terminal should've then continued down Park as two tracks and then take over the existing tunnels 3 & 4 under the east river, thus giving the LIRR a WTC-esque loop under the east side of Manhattan. The freed up space @ Penn coupled with two new Hudson tubes would have given NJT all the space it'd need for expansion for 100 years. 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted December 15, 2018 Share #7274 Posted December 15, 2018 5 hours ago, Lance said: ¿Por qué no los dos? I'm not saying your ideas don't have merit, far from it, I actually like what you come up with, even if I don't always agree with the ideas. However, the so-called "questionably necessary investments" you mentioned do serve a purpose as well. ESA will free up much needed space at Penn Station by allowing the LIRR to travel to Grand Central. It also has the unintended benefit of facilitating the push for Penn Station Access for Metro-North. The Fulton Center project has streamlined the formerly abysmal transfer at Fulton St without rebuilding the Nassau St tracks, all while recouping some of the costs with the shops above. As for CBTC, well, I've already said my piece on that. We do need to take a more progressive stance on these easier projects, but we cannot ignore the big ones either. I think "heavy handed" was the key phrase in my previous post -- my bad for not, well, making it key syntactically. My big criticism of ESA, SAS, CBTC, Fulton etc is that all of those projects solve issues that could have been operated away. In order, Penn is shit because the railroads are too afraid of competence to through-run (and b/c the LIRR won't run proper service/have proper fares for people to get the at HPA), UES SAS is necessary because the rate at which Lex peak ridership is declining is slower than that of MTA's operational decay, CBTC...well, you know what I say, and Fulton could have been an incremental fix (did they really need to spend 1.4b on that weird ass glass thing?). Real estate won't even begin to pay that back, btw -- I can't imagine they're getting more than 10 or 20 mil a year from all of those tenants. To return to my point, though, the reason I focus so much on incrementalism is because so many of the perceived civic disasters are solvable through small, targeted investments instead of these massive capital spends. Let's reserve the megaprojects for when we have controlled/controllable costs, and we can conceive of things like... 51 minutes ago, shiznit1987 said: ...ESA should've gone whole hog and moved all LIRR operations to Grand Central. The new terminal should've then continued down Park as two tracks and then take over the existing tunnels 3 & 4 under the east river, thus giving the LIRR a WTC-esque loop under the east side of Manhattan. The freed up space @ Penn coupled with two new Hudson tubes would have given NJT all the space it'd need for expansion for 100 years. 2 Or better yet, send it down the East Side to ATL or somewhere in Jersey. 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted December 16, 2018 Share #7275 Posted December 16, 2018 (edited) 22 hours ago, RR503 said: Or better yet, send it down the East Side to ATL or somewhere in Jersey. Honestly, I like this better than through running, just because all of the major rail systems use different traction systems and have already, or are two far down the process of replacing their fleets. You'd more than double LIRR capacity with two new inbound tracks. And honestly with how much ESA overran you'd probably get it for the same amount of money, since you'd no longer need to excavate an Empire State Building sized hole 150 ft below Grand Central. Edited December 16, 2018 by bobtehpanda 0 Quote Link to comment Share on other sites More sharing options...
