RailRunRob Posted February 27, 2017 Share #101 Posted February 27, 2017 We need something like Transport for London over here Indeed. What would that look like? More City control? Link to comment Share on other sites More sharing options...
Wallyhorse Posted February 27, 2017 Share #102 Posted February 27, 2017 From an engineering standpoint, that would be extremely expensive. You'd have to tunnel underneath Central Park which would get all sorts of parks and preservation people in a tizzy, then go at least 3 levels below ground at CPW (to get under the IND), then make somewhat tighter radius turns while climbing up beneath plenty of high rise buildings to get to 96th. The cost of this alone would be significantly higher than just the 125th St. piece and the entire rest of the line. I do agree with you about the bus route, if the compromise is a half measure, a dedicated busway for BRT (NOT the M60, however, this must be faster and have significantly fewer stops) is a better option than a stub rail line to WPT only. Which is exactly why I would do it as a branch of the SAS that goes to Willets Point and comes into Manhattan via Randalls Island and 124th Street. This can actually be the that then continues from there to eventually Hanover Square. I suspect such a line would get considerably higher ridership on this branch than people realize. Link to comment Share on other sites More sharing options...
RR503 Posted February 27, 2017 Share #103 Posted February 27, 2017 Which is exactly why I would do it as a branch of the SAS that goes to Willets Point and comes into Manhattan via Randalls Island and 124th Street. This can actually be the that then continues from there to eventually Hanover Square. I suspect such a line would get considerably higher ridership on this branch than people realize. Prove it. With all due respect, this feels like a plan for the sake of one. You still haven't demonstrated the need to spend so many billions of dollars on such a line. Why is this better than a BX extension? Link to comment Share on other sites More sharing options...
Wallyhorse Posted February 27, 2017 Share #104 Posted February 27, 2017 Prove it. With all due respect, this feels like a plan for the sake of one. You still haven't demonstrated the need to spend so many billions of dollars on such a line. Why is this better than a BX extension? I'm not saying its better than a Bronx extension at all, which really should go first. This is more about politics since Cuomo wants to have a line from Willets Point to JFK anyway. Any Bronx extension that I would do would be mainly to recapture what was lost when the 3rd Avenue EL (Bronx Portion) was torn down. Link to comment Share on other sites More sharing options...
RR503 Posted February 27, 2017 Share #105 Posted February 27, 2017 I'm not saying its better than a Bronx extension at all, which really should go first. This is more about politics since Cuomo wants to have a line from Willets Point to JFK anyway. Any Bronx extension that I would do would be mainly to recapture what was lost when the 3rd Avenue EL (Bronx Portion) was torn down. Building from LGA to JFK would be useful if the MTA and PANYNJ could work some agreement out where people can use the air train to move between the line's subway connection stations. Otherwise, it's a useless waste of $$$. Link to comment Share on other sites More sharing options...
bobtehpanda Posted February 27, 2017 Share #106 Posted February 27, 2017 From an engineering standpoint, that would be extremely expensive. You'd have to tunnel underneath Central Park which would get all sorts of parks and preservation people in a tizzy, then go at least 3 levels below ground at CPW (to get under the IND), then make somewhat tighter radius turns while climbing up beneath plenty of high rise buildings to get to 96th. The cost of this alone would be significantly higher than just the 125th St. piece and the entire rest of the line. I do agree with you about the bus route, if the compromise is a half measure, a dedicated busway for BRT (NOT the M60, however, this must be faster and have significantly fewer stops) is a better option than a stub rail line to WPT only. Fair point about the IND. You don't necessarily need to have it climb up since no other crosstown line really does that (I would like to have it under Amsterdam, where there is not much existing infrastructure), and where exactly it connects to the 7th Avenue Line is not really a big deal so long as it is an express station (so, either 72 or 96). How exactly did we dig under the park for 63 St? Fair point about the bus, but the magic of the bus option is that it is usable for literally any route operable by a bus. I just chose the M60 as an example since it's a bus that already exists and can be used as a reference point. The M60 needs less stops in Manhattan, but the Queens stops are already far apart, and the busway into LGA would make it even farther apart since there wouldn't be any stops on 23 Av anymore. Link to comment Share on other sites More sharing options...
Juelz4309 Posted February 27, 2017 Share #107 Posted February 27, 2017 Eminent domain should be used to just extend the N W To lga...The needs of the greater good should overule all that nimby noise..Its so ass bakwards to backtrack thru willets pt when you have a good subway line not far off...a direct seat to times sq...This extension shoulda been built Yrs ago...drop the line underground and be done with it already Sent from my iPhone using NYC Transit Forums mobile app Link to comment Share on other sites More sharing options...
agar io Posted February 27, 2017 Share #108 Posted February 27, 2017 Eminent domain should be used to just extend the N W To lga...The needs of the greater good should overule all that nimby noise..Its so ass bakwards to backtrack thru willets pt when you have a good subway line not far off...a direct seat to times sq...This extension shoulda been built Yrs ago...drop the line underground and be done with it already Sent from my iPhone using NYC Transit Forums mobile app Agreed. Nothing wrong with extending an already existing subway to LGA. I think the original subway extension proposal was canceled in 2003 since the residents would have taken it to the US Supreme Court if they'd tried hard enough. That would have cost the MTA tens or even hundreds of millions of dollars that it doesn't need to waste. Also, it would have been politically unpopular. Link to comment Share on other sites More sharing options...
bobtehpanda Posted February 27, 2017 Share #109 Posted February 27, 2017 Agreed. Nothing wrong with extending an already existing subway to LGA. I think the original subway extension proposal was canceled in 2003 since the residents would have taken it to the US Supreme Court if they'd tried hard enough. That would have cost the MTA tens or even hundreds of millions of dollars that it doesn't need to waste. Also, it would have been politically unpopular. I don't remember the place I read it, but someone in a blog post somewhere made the point that most of those elected officials and community members who originally opposed it are now probably long gone. Unsure if the current populace would be okay with it, though. Link to comment Share on other sites More sharing options...
RR503 Posted February 28, 2017 Share #110 Posted February 28, 2017 I don't remember the place I read it, but someone in a blog post somewhere made the point that most of those elected officials and community members who originally opposed it are now probably long gone. Unsure if the current populace would be okay with it, though. Throw a stop or two, and increase train turn capacity over Ditmars at the new terminal, and they should be a-ok. Link to comment Share on other sites More sharing options...
Around the Horn Posted February 28, 2017 Share #111 Posted February 28, 2017 Throw a stop or two, and increase train turn capacity over Ditmars at the new terminal, and they should be a-ok. Definitely. A stop in Steinway (well, technically a second stop in Steinway; Ditmars isn't actually in Astoria) and a stop in East Elmhurst. Link to comment Share on other sites More sharing options...
Italianstallion Posted March 1, 2017 Share #112 Posted March 1, 2017 Definitely. A stop in Steinway (well, technically a second stop in Steinway; Ditmars isn't actually in Astoria) and a stop in East Elmhurst. That's funny. I know the history of Astoria backwards and forwards. I know the historical Astoria is around Newtown Ave. and 21st St. That said, I grew up in what you would call Steinway, and no one there ever called it that. It was, and is, always called Astoria. Some call it the Ditmars area. Never Steinway. Link to comment Share on other sites More sharing options...
agar io Posted March 1, 2017 Share #113 Posted March 1, 2017 Throw a stop or two, and increase train turn capacity over Ditmars at the new terminal, and they should be a-ok. I'd do Steinway St, Hazen St, LGA Terminal A, LGA Terminal B/C/D. Link to comment Share on other sites More sharing options...
Wallyhorse Posted March 1, 2017 Share #114 Posted March 1, 2017 Building from LGA to JFK would be useful if the MTA and PANYNJ could work some agreement out where people can use the air train to move between the line's subway connection stations. Otherwise, it's a useless waste of $$$. Obviously, I meant LaGuardia in that post. And as said above, a Bronx branch of the SAS (that mainly recaptures what was lost when the 3rd Avenue EL was torn down in 1973) should be first priority. Link to comment Share on other sites More sharing options...
Kamen Rider Posted March 6, 2017 Share #115 Posted March 6, 2017 reasons why I think Willets Point isn't that bad an idea. #1. the design is much more straight forward. no weaving around or under bridges. No avoiding the runway. #2. Should the FAA ever change thier minds, it's a closer step towards an line between the two airports. #3. Willets Point offers better regional connections. Sure, a quick ride to manhattan is great, but not everyone using the airport wants to go there. Extending the bus routes that terminate in downtown Flushing to a Willets point station gives you not only a two seat ride to the airport from as far away as Hicksville, but in can include an off street layover/terminal area, which means no me bus gridlock clogging up Main and Roosevelt. #4. They have space to build the support facilities. A distinct Airtrain is going to need a shop and storage space. Sure, JFK had some room to spare, but LaGuardia doesn't. With Willets Point, there is plenty of room. Astoria, not so much. The IRT station is due for a renovation anyway, so integrating the new station would be even easier. #5. If/When they ever get around to building anything next to Citi Field, your first stop in the city could be a destination in and of itself. Link to comment Share on other sites More sharing options...
Wallyhorse Posted March 6, 2017 Share #116 Posted March 6, 2017 reasons why I think Willets Point isn't that bad an idea. #1. the design is much more straight forward. no weaving around or under bridges. No avoiding the runway. #2. Should the FAA ever change thier minds, it's a closer step towards an line between the two airports. #3. Willets Point offers better regional connections. Sure, a quick ride to manhattan is great, but not everyone using the airport wants to go there. Extending the bus routes that terminate in downtown Flushing to a Willets point station gives you not only a two seat ride to the airport from as far away as Hicksville, but in can include an off street layover/terminal area, which means no me bus gridlock clogging up Main and Roosevelt. #4. They have space to build the support facilities. A distinct Airtrain is going to need a shop and storage space. Sure, JFK had some room to spare, but LaGuardia doesn't. With Willets Point, there is plenty of room. Astoria, not so much. The IRT station is due for a renovation anyway, so integrating the new station would be even easier. #5. If/When they ever get around to building anything next to Citi Field, your first stop in the city could be a destination in and of itself. Not bad points, but I would still do it as subway and continue it to Randalls Island and then via a new branch of the SAS. If they are going to build it anyway, tying it to the SAS and giving Randalls Island subway service as a bonus would work. Link to comment Share on other sites More sharing options...
RR503 Posted March 7, 2017 Share #117 Posted March 7, 2017 reasons why I think Willets Point isn't that bad an idea. #1. the design is much more straight forward. no weaving around or under bridges. No avoiding the runway. Actually, not quite. You'll have to build it through the GCP-Van Wyck-CIP interchange without getting in the way of planes flying the expressway arrival to 31. #2. Should the FAA ever change thier minds, it's a closer step towards an line between the two airports. And since when is spending 3+billion on a line with a teensy market a good idea? BRT would be best. #3. Willets Point offers better regional connections. Sure, a quick ride to manhattan is great, but not everyone using the airport wants to go there. Extending the bus routes that terminate in downtown Flushing to a Willets point station gives you not only a two seat ride to the airport from as far away as Hicksville, but in can include an off street layover/terminal area, which means no me bus gridlock clogging up Main and Roosevelt. Fair point, but remember that the VAST majority of users are going to Manhattan. Not giving them a quick and easy way to their destination will not take them off the roads, leaving us with basically status quo. Same problem with LI. FIrst off, most LI travelers use JFK because LGA is such $#!t. Secondly, making them transfer between LIRR trains with luggage (much more leisure/VFR traffic from LI, most business stuff is from the city) will not be popular. And lastly, there is the issue that, you know, it's a bit of a roundabout route. #4. They have space to build the support facilities. A distinct Airtrain is going to need a shop and storage space. Sure, JFK had some room to spare, but LaGuardia doesn't. With Willets Point, there is plenty of room. Astoria, not so much. The IRT station is due for a renovation anyway, so integrating the new station would be even easier. You could squeeze it in between the airport and the neighborhoods to the west. #5. If/When they ever get around to building anything next to Citi Field, your first stop in the city could be a destination in and of itself. Or your first stop could be close to midtown.... Link to comment Share on other sites More sharing options...
Italianstallion Posted March 7, 2017 Share #118 Posted March 7, 2017 I'd do Steinway St, Hazen St, LGA Terminal A, LGA Terminal B/C/D. That's about right. I always wondered though where this new presumably elevated line would be routed once it got past Hazen St. Likely some NIMBY action there from the garden apartments nearby. Link to comment Share on other sites More sharing options...
BreeddekalbL Posted March 7, 2017 Share #119 Posted March 7, 2017 can someone please tell me how prince andrew was able to strong arm the LIRR 3rd track yet he wont strong arm the to LGA? Link to comment Share on other sites More sharing options...
Around the Horn Posted March 7, 2017 Share #120 Posted March 7, 2017 can someone please tell me how prince andrew was able to strong arm the LIRR 3rd track yet he wont strong arm the to LGA? Simple, the 3rd track doesn't need the approval of the FAA. Link to comment Share on other sites More sharing options...
BreeddekalbL Posted March 7, 2017 Share #121 Posted March 7, 2017 Simple, the 3rd track doesn't need the approval of the FAA. i know that but the way i would have the N extension it would be going north of ditmars not via the GCP thats a stupid idea Link to comment Share on other sites More sharing options...
Around the Horn Posted March 7, 2017 Share #122 Posted March 7, 2017 i know that but the way i would have the N extension it would be going north of ditmars not via the GCP thats a stupid idea Even if you go via 20th Avenue, you still have to use that stretch of the GCP thats the issue... Link to comment Share on other sites More sharing options...
BreeddekalbL Posted March 7, 2017 Share #123 Posted March 7, 2017 Even if you go via 20th Avenue, you still have to use that stretch of the GCP thats the issue... I would go north to 31st then sink down into 19th into the MAT and runway drive follow under the Central Terminals Link to comment Share on other sites More sharing options...
collagedchen300 Posted March 7, 2017 Share #124 Posted March 7, 2017 That’s only good for editing and creating vectors. Screenshots of Google Maps needs to be aligned to the pixel when stitched. I use vector maps and Adobe Illustrator. Or, use Brand New Subwayhttp://brandnewsubway.com/ Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Gotham Bus Co. Posted March 8, 2017 Share #125 Posted March 8, 2017 #3. Willets Point offers better regional connections. Sure, a quick ride to manhattan is great, but not everyone using the airport wants to go there. Extending the bus routes that terminate in downtown Flushing to a Willets point station gives you not only a two seat ride to the airport from as far away as Hicksville, but in can include an off street layover/terminal area, which means no me bus gridlock clogging up Main and Roosevelt. Where would the off-street layover be? Remember that the whole Casey Stengel Depot property would be wiped away to make room for the AirTrain staton and maintenance shop. Link to comment Share on other sites More sharing options...
