Lawrence St Posted May 20, 2018 Share #751 Posted May 20, 2018 On 5/19/2018 at 12:48 AM, BM5 via Woodhaven said: The real issue is that local service is not being provided adequately. It's absolutely atrocious when only the runs local. Trains go missing, sometimes even consecutively. Then you have a whole bunch of and trains dumping people off at Roosevelt. I almost always take the Q53 when I'm going to Woodhaven Boulevard, instead of the . I avoid QBL at all costs on the weekends. The last time I was there I got trapped on the between Queens Plaza and Jackson Heights for an hour. But the should not be the sole local on QBL, that just causes uneven ridership levels. But anyway, regarding the RBB, I honestly don't think Woodhaven needs to be converted, at least for right now. What I was thinking in terms of service is this: Extend the Rockaway Park Shuttle (now called ) from Broad Channel to Aqeduct, then over the RBB to the stations that were previously there, connect to the QBL and run local, then terminate at the upper level at Jackson Heights (that level should be repurposed as a station.) This removes the fear of making the or to long if they were extended over the RBB, still gives riders along the RBB connections to the , and gives Rockaway Park more service. And I forgot to point this out the last time I was hiking over there, most of the lines essential parts are still there, the only problem is that Ozone Park needs to be checked for structural damage, the bridge over the Mountak line I believe needs to be replaced since it no longer exists, and the line needs to be elevated at the end of Forest Park and the baseball field because of the new properties that are there. And the platforms as well, those need to be replaced and someone needs to kick that school bus company off of the Woodhaven Station site since they illegally extended their lot into the station and destroyed part of the platform. 1 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted May 24, 2018 Share #752 Posted May 24, 2018 On 5/20/2018 at 7:39 AM, Lawrence St said: I avoid QBL at all costs on the weekends. The last time I was there I got trapped on the between Queens Plaza and Jackson Heights for an hour. But the should not be the sole local on QBL, that just causes uneven ridership levels. But anyway, regarding the RBB, I honestly don't think Woodhaven needs to be converted, at least for right now. What I was thinking in terms of service is this: Extend the Rockaway Park Shuttle (now called ) from Broad Channel to Aqeduct, then over the RBB to the stations that were previously there, connect to the QBL and run local, then terminate at the upper level at Jackson Heights (that level should be repurposed as a station.) This removes the fear of making the or to long if they were extended over the RBB, still gives riders along the RBB connections to the , and gives Rockaway Park more service. And I forgot to point this out the last time I was hiking over there, most of the lines essential parts are still there, the only problem is that Ozone Park needs to be checked for structural damage, the bridge over the Mountak line I believe needs to be replaced since it no longer exists, and the line needs to be elevated at the end of Forest Park and the baseball field because of the new properties that are there. And the platforms as well, those need to be replaced and someone needs to kick that school bus company off of the Woodhaven Station site since they illegally extended their lot into the station and destroyed part of the platform. And this is why I would do it with the becoming the full-time route to Rockaway Park via the RBB (which eliminates the Rockaway Park shuttle), from Whitehall all times except late nights when such would start at 34th Street (and the returning to Astoria 24/7 while the becomes the secondary line there weekdays and goes to 96th-2nd the rest of the time). 0 Quote Link to comment Share on other sites More sharing options...
Lawrence St Posted May 24, 2018 Share #753 Posted May 24, 2018 6 hours ago, Wallyhorse said: And this is why I would do it with the becoming the full-time route to Rockaway Park via the RBB (which eliminates the Rockaway Park shuttle), from Whitehall all times except late nights when such would start at 34th Street (and the returning to Astoria 24/7 while the becomes the secondary line there weekdays and goes to 96th-2nd the rest of the time). But why when you can modify the existing service pattern? 0 Quote Link to comment Share on other sites More sharing options...
Lance Posted May 24, 2018 Share #754 Posted May 24, 2018 Because no Wallyhorse-style service proposal is complete without rearranging the entire B-Division. 9 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted May 24, 2018 Share #755 Posted May 24, 2018 5 hours ago, Lawrence St said: But why when you can modify the existing service pattern? The is too long and the misses to me one key element that could cost re-activating the RBB: Lower Manhattan. There is a psychological element to me that says any RBB line must include service to lower Manhattan to appease those who still think of that area as "The Financial District" (even if its far from what it once was) as there are those who I think will only support it if such a line starts in lower Manhattan. That's why I make the the full-time RBB line while the returns to its pre-1987 routing of 95th-Astoria (and what probably is the 's "natural route") while the is a secondary route to Astoria during the week and runs to 96th/2nd late nights and weekends. The first step is actually GETTING the line re-activated, and that might mean not doing things that are ideal to convince those who have the power to get it re-activated. 0 Quote Link to comment Share on other sites More sharing options...
Lawrence St Posted May 24, 2018 Share #756 Posted May 24, 2018 1 minute ago, Wallyhorse said: The is too long and the misses to me one key element that could cost re-activating the RBB: Lower Manhattan. There is a psychological element to me that says any RBB line must include service to lower Manhattan to appease those who still think of that area as "The Financial District" (even if its far from what it once was) as there are those who I think will only support it if such a line starts in lower Manhattan. That's why I make the the full-time RBB line while the returns to its pre-1987 routing of 95th-Astoria (and what probably is the 's "natural route") while the is a secondary route to Astoria during the week and runs to 96th/2nd late nights and weekends. The first step is actually GETTING the line re-activated, and that might mean not doing things that are ideal to convince those who have the power to get it re-activated. But WHY? Just extend the to the upper level at Jackson Heights and label it the , simple and no confusing service pattern. 0 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted May 24, 2018 Share #757 Posted May 24, 2018 1 hour ago, Lawrence St said: But WHY? Just extend the to the upper level at Jackson Heights and label it the , simple and no confusing service pattern. In a word, politics. 0 Quote Link to comment Share on other sites More sharing options...
Lance Posted May 24, 2018 Share #758 Posted May 24, 2018 You keep using that word. I don't think you know what it means. 14 Quote Link to comment Share on other sites More sharing options...
N6 Limited Posted May 24, 2018 Share #759 Posted May 24, 2018 On 5/20/2018 at 7:39 AM, Lawrence St said: I avoid QBL at all costs on the weekends. The last time I was there I got trapped on the between Queens Plaza and Jackson Heights for an hour. But the should not be the sole local on QBL, that just causes uneven ridership levels. That's horrible, I avoided the QBL on weekends also, defaulted to LIRR City TIcket, but now I avoid QBL all the time, gonna start getting Atlantic Ticket weeklys. As for the being the sole local on weekends. There is always track work so at this point it doesn't make much of a difference, however on "normal" weekends there are a few things they can do. 1) Run and local, turn the at Queens Plaza. - The run frequent and they won't be blocked by at Forest Hills. 2) Run the and local and the express. - The is longer than the so run it express to reduce running time. 3) Run the and express and the local ,turn the at Queens Plaza. - gets screwed up too much, send a more reliable line to cover the QB Local. 4) If the runs by it self, hold it at Roosevelt if there are incoming and trains to reduce transfer times. 5) Send an or local if there is a gap in service. They should be able to breeze through with no in the way once it gets to Forest Hills. The problem with the MTA is that they make 'minor' problems worse by not making quick customer friendly actions. If there is a gap in service, send an or local and then the passengers waiting for local service won't loathe the MTA for the day. There are riders on the or that may be a bit irritated, but the train should move along quickly. Trains are delayed due to track work? Hold a bus at Jamaica for a few mins since there's an incoming or and the bus riders won't loathe the MTA because they missed their bus due to track work. Quick Question: if there are local track conga lines on Queens Blvd into Forest HIlls, why can't they dump a or train at Roosevelt and deadhead on the express track to the yard to clear up the congestion? 1 Quote Link to comment Share on other sites More sharing options...
LGA Link N Train Posted May 24, 2018 Author Share #760 Posted May 24, 2018 (edited) 34 minutes ago, N6 Limited said: Quick Question: if there are local track conga lines on Queens Blvd into Forest HIlls, why can't they dump a or train at Roosevelt and deadhead on the express track to the yard to clear up the congestion? The Queens Blvd Express can only handle up to 30 TPH. Deadheading a train at Roosevelt would make things worse. Just send a train of 2 to 179, and have an run express to 179. 1 hour ago, Lance said: You keep using that word. I don't think you know what it means. Did you just Roast him? Edited May 24, 2018 by LGA Link N train 1 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted May 25, 2018 Share #761 Posted May 25, 2018 (edited) On 5/23/2018 at 10:57 PM, Wallyhorse said: And this is why I would do it with the becoming the full-time route to Rockaway Park via the RBB (which eliminates the Rockaway Park shuttle), from Whitehall all times except late nights when such would start at 34th Street (and the returning to Astoria 24/7 while the becomes the secondary line there weekdays and goes to 96th-2nd the rest of the time). Presuming 38th St Yard is set up to store and stage revenue service trains (which is actually being considered in the long-term SAS plans), the can be moved there. Then (and only then), the can run to/from Astoria full time and the can go to QBL and possibly also the RBB. Then your plan actually would be a realistic plan - well, except that part about the becoming the secondary Astoria service. The would be able to run far more frequently than now, that there would no longer be a need for a secondary service in Astoria. The could run express all the way in Manhattan and support the on 2nd Ave seven days a week... 21 hours ago, Wallyhorse said: The is too long and the misses to me one key element that could cost re-activating the RBB: Lower Manhattan. There is a psychological element to me that says any RBB line must include service to lower Manhattan to appease those who still think of that area as "The Financial District" (even if its far from what it once was) as there are those who I think will only support it if such a line starts in lower Manhattan. That's why I make the the full-time RBB line while the returns to its pre-1987 routing of 95th-Astoria (and what probably is the 's "natural route") while the is a secondary route to Astoria during the week and runs to 96th/2nd late nights and weekends. The first step is actually GETTING the line re-activated, and that might mean not doing things that are ideal to convince those who have the power to get it re-activated. ...and then you had to mess it up by bringing up the same tired old phony reason why. 😔 There are many factors that need to be considered for restoring the RBB line. Serving Lower Manhattan directly would (and should) be far from the top of the list...especially since RBB already has the providing direct service to the Financial District. The has not one, but two stops in Long Island City (the second being the centrally located 23rd St-Court Sq) and a more central location in East Midtown, which would make a strong case for it to be the RBB service. But its weekdays-only operation (in Manhattan and on QBL), relatively long route and multiple merges could make a strong case [/b]against[/b] rerouting the there. Potentially the would not have nearly as many merges (although it too, is a weekdays-only service). Rule out the because it becomes the new Astoria line with a storage yard in Sunset Park, Brooklyn. If not, then rule out the because it would be far too long of a line. But we must also consider other factors, such as whether or not the ridership is there and how well the existing train services - the , the and the LIRR Atlantic Branch - can handle it. Edited May 25, 2018 by T to Dyre Avenue 3 Quote Link to comment Share on other sites More sharing options...
B35 via Church Posted May 25, 2018 Share #762 Posted May 25, 2018 18 hours ago, Lance said: You keep using that word. I don't think you know what it means. One word answers like that are generally attempts at feigning intelligence..... All it conveys to me, is that the incapacity of a cogent rebuttal is present..... Otherwise, you'd make your argument/counter-argument. 5 Quote Link to comment Share on other sites More sharing options...
CenSin Posted May 26, 2018 Share #763 Posted May 26, 2018 On 5/24/2018 at 11:03 AM, Wallyhorse said: There is a psychological element to me that says any RBB line must include service to lower Manhattan to appease those who still think of that area as "The Financial District" (even if its far from what it once was) as there are those who I think will only support it if such a line starts in lower Manhattan. I don’t know about that; I think it’s all in your head. That Ghost of Subway Past has overstayed its welcome. 5 Quote Link to comment Share on other sites More sharing options...
Coney Island Av Posted May 26, 2018 Share #764 Posted May 26, 2018 On 5/24/2018 at 11:03 AM, Wallyhorse said: The is too long and the misses to me one key element that could cost re-activating the RBB: Lower Manhattan. There is a psychological element to me that says any RBB line must include service to lower Manhattan to appease those who still think of that area as "The Financial District" (even if its far from what it once was) as there are those who I think will only support it if such a line starts in lower Manhattan. That's why I make the the full-time RBB line while the returns to its pre-1987 routing of 95th-Astoria (and what probably is the 's "natural route") while the is a secondary route to Astoria during the week and runs to 96th/2nd late nights and weekends. If you want a ride to Lower Manhattan, you're in the wrong place. You should've hopped off at the casino if you wanted to take a much faster route on + speed. Think back to 2010, where the was rerouted up 6th and combined with the for one reason. Oh you can't remember it? Riders in Ridgewood/Glendale wanted to go UP, not down the drain on a Nassau train. Still can't remember what I mean? 22,000 riders transferred to other lines that went to Midtown, 17,000 stayed on the train to Lower Manhattan, and the was carrying dust along the West End. Despite the fact that Lower Manhattan has the World Trade Center, Midtown is arguably where most businesses are concentrated today. Instead of this complex rearrangement of the entire B-division, why don't you leave them alone and let riders.... Transfer. 5 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted May 26, 2018 Share #765 Posted May 26, 2018 4 hours ago, Coney Island Av said: If you want a ride to Lower Manhattan, you're in the wrong place. You should've hopped off at the casino if you wanted to take a much faster route on + speed. Think back to 2010, where the was rerouted up 6th and combined with the for one reason. Oh you can't remember it? Riders in Ridgewood/Glendale wanted to go UP, not down the drain on a Nassau train. Still can't remember what I mean? 22,000 riders transferred to other lines that went to Midtown, 17,000 stayed on the train to Lower Manhattan, and the was carrying dust along the West End. Despite the fact that Lower Manhattan has the World Trade Center, Midtown is arguably where most businesses are concentrated today. Instead of this complex rearrangement of the entire B-division, why don't you leave them alone and let riders.... Transfer. And in a perfect world, I actually agree. Politics aside, 2 av would actually be a perfect point to start such a line if it went up 6 av and then QB (perhaps where such runs with the via 63rd and skips Queens Plaza but otherwise runs local after that. This could be a revival of the train. My concern has always been those who would greenlight such a project or be willing to support it. Would they be willing to if such a line did not serve what to some still is "The Financial District?" If that is NOT a sticking point with those in power, then yes, you can perhaps have the operate on the RBB to Rockaway Park as it would make much more sense than the (R). 0 Quote Link to comment Share on other sites More sharing options...
BreeddekalbL Posted May 26, 2018 Share #766 Posted May 26, 2018 If this project is done do they give the racetrack/casino station another platform for Rockaway passengers? 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted May 26, 2018 Share #767 Posted May 26, 2018 I’d prefer they replace the northbound-only Aqueduct station with a proper station at Linden Blvd/Centreville St. That seems like it would attract more people to use the Rockaway Branch of the , rather than take the buses along Cross Bay Blvd to Rockaway Blvd. 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted May 26, 2018 Share #768 Posted May 26, 2018 5 hours ago, Wallyhorse said: And in a perfect world, I actually agree. Politics aside, 2 av would actually be a perfect point to start such a line if it went up 6 av and then QB (perhaps where such runs with the via 63rd and skips Queens Plaza but otherwise runs local after that. This could be a revival of the train. My concern has always been those who would greenlight such a project or be willing to support it. Would they be willing to if such a line did not serve what to some still is "The Financial District?" If that is NOT a sticking point with those in power, then yes, you can perhaps have the operate on the RBB to Rockaway Park as it would make much more sense than the (R). I don't know what your obsession with the Financial District is. It's clearly not that big a deal; we dumped LIRR to WTC in favor of East Side Access. Hudson Yards and Midtown East are the new priorities today. 6 Quote Link to comment Share on other sites More sharing options...
B35 via Church Posted May 26, 2018 Share #769 Posted May 26, 2018 1 hour ago, bobtehpanda said: I don't know what your obsession with the Financial District is. It's clearly not that big a deal; we dumped LIRR to WTC in favor of East Side Access. Hudson Yards and Midtown East are the new priorities today. "FiDi" is what it is & AFAIC, what it's always going to be.... Flavor of the month, it's definitely not..... Not only am I glad the MTA prioritized ESA over direct Lower Manhattan access w/ the LIRR, it simply made more sense..... Anyone heralding the locale of the Financial District with any increased relevancy here in 2018 is seriously stuck in a time warp..... 0 Quote Link to comment Share on other sites More sharing options...
bobtehpanda Posted May 27, 2018 Share #770 Posted May 27, 2018 1 hour ago, B35 via Church said: "FiDi" is what it is & AFAIC, what it's always going to be.... Flavor of the month, it's definitely not..... Not only am I glad the MTA prioritized ESA over direct Lower Manhattan access w/ the LIRR, it simply made more sense..... Anyone heralding the locale of the Financial District with any increased relevancy here in 2018 is seriously stuck in a time warp..... Not to mention, the first version of the World Trade Center was built to revitalize Lower Manhattan in the '70s. We've been through this before, and WTC 2: Electric Boogaloo isn't doing too hot. Quote It was recently revealed that One World Trade Center still has a 25 percent vacancy rate four years after opening its door, and that number is about to grow. The first tenant to move into the building in 2014, Condé Nast is now looking to sublease a third of its one-million-square-foot office space. Source: https://www.6sqft.com/conde-nast-to-sublease-350000-square-feet-of-its-one-world-trade-center-headquarters/ 1 Quote Link to comment Share on other sites More sharing options...
Deucey Posted May 27, 2018 Share #771 Posted May 27, 2018 2 minutes ago, bobtehpanda said: Not to mention, the first version of the World Trade Center was built to revitalize Lower Manhattan in the '70s. We've been through this before, and WTC 2: Electric Boogaloo isn't doing too hot. It’s why I’m telling my bosses to move our startup to FiDi - cheaper rent and three lines to get them there. Plus Midtown sucks. 0 Quote Link to comment Share on other sites More sharing options...
Via Garibaldi 8 Posted May 27, 2018 Share #772 Posted May 27, 2018 15 minutes ago, Deucey said: It’s why I’m telling my bosses to move our startup to FiDi - cheaper rent and three lines to get them there. Plus Midtown sucks. lol@FiDi 0 Quote Link to comment Share on other sites More sharing options...
Deucey Posted May 27, 2018 Share #773 Posted May 27, 2018 10 minutes ago, Via Garibaldi 8 said: lol@FiDi I like FinDis better, but I’m not a trendsetter. 6 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted May 27, 2018 Share #774 Posted May 27, 2018 4 hours ago, bobtehpanda said: I don't know what your obsession with the Financial District is. It's clearly not that big a deal; we dumped LIRR to WTC in favor of East Side Access. Hudson Yards and Midtown East are the new priorities today. It's not an obsession. It's just I know people who are in fact stuck in a time warp (I see this all the time with Horse Racing for instance) and many of those types still remember lower Manhattan as such for example. It's just a lot of time TPTB who can decide matters forget how much things have changed and lower Manhattan is clearly not what it once was (why for instance when the Fulton Transportation Center was built I would have put a 45-50 story residential tower on top of it). My concern was there is still a mentality among some about Lower Manhattan (even if they should know better) that would have me concerned. As long as that is NOT an issue, I would as noted THEN go with the or better a revived train that would operate from 2nd Avenue to Rockaway Park and be MUCH more useful than the old version of the (while the in that scenario would go to 96th St-2nd Avenue at all times and later 125th-2nd, at least until the comes aboard). 1 hour ago, bobtehpanda said: Not to mention, the first version of the World Trade Center was built to revitalize Lower Manhattan in the '70s. We've been through this before, and WTC 2: Electric Boogaloo isn't doing too hot. Source: https://www.6sqft.com/conde-nast-to-sublease-350000-square-feet-of-its-one-world-trade-center-headquarters/ 😂🤣 (on the Electric Boogaloo part). Very interesting on Conde Nast. Might have been better to rebuild the WTC as a residential complex. 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted May 27, 2018 Share #775 Posted May 27, 2018 12 hours ago, Wallyhorse said: It's not an obsession. It's just I know people who are in fact stuck in a time warp (I see this all the time with Horse Racing for instance) and many of those types still remember lower Manhattan as such for example. It's just a lot of time TPTB who can decide matters forget how much things have changed and lower Manhattan is clearly not what it once was (why for instance when the Fulton Transportation Center was built I would have put a 45-50 story residential tower on top of it). My concern was there is still a mentality among some about Lower Manhattan (even if they should know better) that would have me concerned. As long as that is NOT an issue, I would as noted THEN go with the or better a revived train that would operate from 2nd Avenue to Rockaway Park and be MUCH more useful than the old version of the (while the in that scenario would go to 96th St-2nd Avenue at all times and later 125th-2nd, at least until the comes aboard). "I'm not obsessed! I just have a passion!" Wally, if there is a forum that understands obsession, it's this one. You're obsessed. With hospitals, horse racing, the phrase "as I noted," and the letter T. Now, to address your claim about the supposed psychology of the Financial district, may I kindly request some contemporary evidence? Because having worked for/met/heard some of these "powers that be," they are under no illusion about Lower Manhattan's position in the city. Remember, they're the ones that created its situation -- they get where it is, and why it is there. This discussion, of course, ignores the fundamental flaws of the RBB as a corridor, but that's for a different day when we have learned not to use psychology and politics as crutches for failing arguments. 3 Quote Link to comment Share on other sites More sharing options...
