RR503 Posted February 21, 2019 Share #26 Posted February 21, 2019 7 minutes ago, Via Garibaldi 8 said: Well the is such an afterthought, that I’m sure that those with other options won’t miss it that much if it were cut back. I personally do my best to not ride it. Sick of seeing those nasty cars from the 70s or whenver the hell they came out. Doors take FOREVER to close, then the hissing and long wait to take off. Everything is painfully slow about that line. One of the big things IMO that would improve service is NEW fleet. I felt the service ran better with the newer cars. It being an afterthought doesn't mean it needs to remain that way... Regardless, the 60k people that the takes under the river each day probably disagree with your characterization, as do the Brooklyn IRT riders who would suffer even more crowding if this came to pass. 0 Quote Link to comment Share on other sites More sharing options...
GreatOne2k Posted February 21, 2019 Share #27 Posted February 21, 2019 If the goes to Essex, wouldn't it be better to bring back the as a Broadway service instead of having two different colored trains? Another option is to make the run on Queens Boulevard 7 days a week in place of the weekend service. If the and have problems both using Whitehall, another option is to re extend the to replace the in Queens on weekdays since QB needs 4 services. 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted February 21, 2019 Share #28 Posted February 21, 2019 4 minutes ago, GreatOne2k said: If the goes to Essex, wouldn't it be better to bring back the as a Broadway service instead of having two different colored trains? Another option is to make the run on Queens Boulevard 7 days a week in place of the weekend service. If the and have problems both using Whitehall, another option is to re extend the to replace the in Queens on weekdays since QB needs 4 services. I don't even understand why we're discussing cutting the to Whitehall. This is an easy operational fix, and there are a slate of route changes I'd make before you spring for changing that end of things. If you want Nassau, extend the . 1 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted February 21, 2019 Share #29 Posted February 21, 2019 34 minutes ago, RR503 said: I use the 4 or so times a week. Trust me when I say I know how bad it is. But I think trying to fix that by cutting the line’s East River crossing is not just an acquiescence to operational incompetence, but is also a really dumb way of making the Brooklyn leg of the shorter. As I’m sure you all are tired of hearing me say, any conversation about routing changes needs to start with one about operations — whether or not just getting that side of the house together fixes the targeted problem, which here seems to be reliability. In this case, the answer to that question is, to an extent, yes, and I think that it’s mitigations that speak to that sort of issue that need to be the focus here. I’ve spent months here detailing specific strategies that I think could be helpful, so I won’t go into detail, but things like dwell control, terminal operation, scheduling, maintenance related operations and speed management seem pertinent to the . Some routing changes, though, address problems that transcend operation issues, and there are some operations issues that can’t be completely solved operationally. While this proposal’s stated raison d’être is operational, and I don’t think that it’s goal is unachievable operationally, I think there are absolutely route changes that could be made to the and related lines that would benefit service delivery/frequency. Examples of this would be Broadway deinterlining, Queens deinterlining, a Nassau-Bay Ridge service, etc. These aren’t far fetched ideas that take some sort of wizard to conceive; a glance at a track map and a service diagram would present the above solutions to a 6th grader with an attention span long enough to absorb the necessary information. What is required is merely care and creativity—elements that seem to have been lacking here. But let’s entertain for a second the possibility that all of this is totally wrong, and the electeds are completely correct in their belief that a shorter is the only way to make a better . Cutting the at Court achieves that goal, yes, but so does running the to Essex, a service pattern that would preserve Lower Manhattan connectivity. Could they not have gone for that pretty objectively better option? I’ll leave it to the forum to decide. *** I’m leaving this as a postscript because I think that this isn’t an important argument in the scheme of things, but there’s no way in hell that Whitehall will be able to turn and service — which means one of them is getting cut to Canal, which means less service to Lower Manhattan, etc etc Perhaps they would be open to an train starting/ending at Essex. Their exact request to cut the at Court on the Brooklyn side and Whitehall on the Manhattan side might not necessarily be written in stone. An Essex is also a much shorter route than the current . Cutting the ’s East River crossing outright would be dumb. I remember back in 2014 (after Montague reopened) Vincent Gentile being open to the idea of having a Nassau service operate to/from Bay Ridge. 0 Quote Link to comment Share on other sites More sharing options...
Deucey Posted February 21, 2019 Share #30 Posted February 21, 2019 Brown - meaning I'd have to walk to BG or Broad Street to get to Flatbush Av? No thanks. Plus, wasn't this already done, partially, as until 2010? I'm with @RR503 - just rationalize operations of the supervisors and watch service improve. Or run to 96th or Astoria, and to 71st. 1 Quote Link to comment Share on other sites More sharing options...
Lawrence St Posted February 21, 2019 Share #31 Posted February 21, 2019 21 minutes ago, Deucey said: Brown - meaning I'd have to walk to BG or Broad Street to get to Flatbush Av? No thanks. Plus, wasn't this already done, partially, as until 2010? I'm with @RR503 - just rationalize operations of the supervisors and watch service improve. Or run to 96th or Astoria, and to 71st. Running the to 96th St makes further merging a problem on Broadway. 0 Quote Link to comment Share on other sites More sharing options...
Deucey Posted February 21, 2019 Share #32 Posted February 21, 2019 7 minutes ago, Lawrence St said: Running the to 96th St makes further merging a problem on Broadway. The same problem existed before when went to Astoria. It's gonna exist when go to 96th. It'll exist if goes to Astoria. IOW, ¯\_(ツ)_/¯ 0 Quote Link to comment Share on other sites More sharing options...
RR503 Posted February 21, 2019 Share #33 Posted February 21, 2019 11 minutes ago, Deucey said: The same problem existed before when went to Astoria. It's gonna exist when go to 96th. It'll exist if goes to Astoria. IOW, ¯\_(ツ)_/¯ Outside Dekalb, the big problem spots on Broadway are 34th St, where the crosses, and the ends of the 11th St cut, where the jogs from QB to 60th. The first is an easy fix — to 96, more to Astoria — and also has the benefit of forcing more trains to run on 4th local (Whitehall can’t turn enough to cover Astoria). The second one requires a larger restructuring of B division service patterns, but is still wholly feasible w/o adding merges. 0 Quote Link to comment Share on other sites More sharing options...
Deucey Posted February 21, 2019 Share #34 Posted February 21, 2019 4 minutes ago, RR503 said: Outside Dekalb, the big problem spots on Broadway are 34th St, where the crosses, and the ends of the 11th St cut, where the jogs from QB to 60th. The first is an easy fix — to 96, more to Astoria — and also has the benefit of forcing more trains to run on 4th local (Whitehall can’t turn enough to cover Astoria). The second one requires a larger restructuring of B division service patterns, but is still wholly feasible w/o adding merges. Just makes me wonder what the system would look like if every line had one express and one local service and no interlining. I guess that'd be the late night map, but still. 0 Quote Link to comment Share on other sites More sharing options...
Around the Horn Posted February 21, 2019 Author Share #35 Posted February 21, 2019 2 hours ago, RR503 said: But let’s entertain for a second the possibility that all of this is totally wrong, and the electeds are completely correct in their belief that a shorter is the only way to make a better . Cutting the at Court achieves that goal, yes, but so does running the to Essex, a service pattern that would preserve Lower Manhattan connectivity. Could they not have gone for that pretty objectively better option? I’ll leave it to the forum to decide. I will give credit where credit is due, Justin Brannon is at least listening to and conversing with people on Twitter who are (rightfully) complaining about losing direct Lower Manhattan service... I would not be surprised if they revise their proposal based off the feedback they're getting from their constituents on this. 1 Quote Link to comment Share on other sites More sharing options...
RR503 Posted February 21, 2019 Share #36 Posted February 21, 2019 8 minutes ago, Deucey said: Just makes me wonder what the system would look like if every line had one express and one local service and no interlining. I guess that'd be the late night map, but still. Not too hard to put together. You’d have something like: (on the A div) Jerome-Lex Exp-EPW exp-Utica WPR/Dyre-7th exp-New Lots and Flatbush Locals and same (on the B div) Inwood-CPW exp-6th exp-4th exp-West End and Sea Beach Concourse-CPW local-8th local-WTC 179 and Parsons-QB exp-63rd-6th local-Rutgers-Culver (either all exp for full deinterlining or half half) Forest Hills-QB local-53-8th exp-Fulton local/Fulton Exp Astoria-60-Bway Local-Lower Manhattan-4th local SAS-Bway Exp-Brighton Crosstown-Culver local Jamaica/Myrtle-Nassau (you could in theory send these trains to 4th local instead of Bway local) Is this a service plan I’d advocate for? Hell no. Are there parts of it that are valuable, and is the discussion it begs on we must have? Hell yes. 1 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted February 21, 2019 Share #37 Posted February 21, 2019 1 hour ago, RR503 said: I use the 4 or so times a week. Trust me when I say I know how bad it is. But I think trying to fix that by cutting the line’s East River crossing is not just an acquiescence to operational incompetence, but is also a really dumb way of making the Brooklyn leg of the shorter. As I’m sure you all are tired of hearing me say, any conversation about routing changes needs to start with one about operations — whether or not just getting that side of the house together fixes the targeted problem, which here seems to be reliability. In this case, the answer to that question is, to an extent, yes, and I think that it’s mitigations that speak to that sort of issue that need to be the focus here. I’ve spent months here detailing specific strategies that I think could be helpful, so I won’t go into detail, but things like dwell control, terminal operation, scheduling, maintenance related operations and speed management seem pertinent to the . Some routing changes, though, address problems that transcend operation issues, and there are some operations issues that can’t be completely solved operationally. While this proposal’s stated raison d’être is operational, and I don’t think that it’s goal is unachievable operationally, I think there are absolutely route changes that could be made to the and related lines that would benefit service delivery/frequency. Examples of this would be Broadway deinterlining, Queens deinterlining, a Nassau-Bay Ridge service, etc. These aren’t far fetched ideas that take some sort of wizard to conceive; a glance at a track map and a service diagram would present the above solutions to a 6th grader with an attention span long enough to absorb the necessary information. What is required is merely care and creativity—elements that seem to have been lacking here. But let’s entertain for a second the possibility that all of this is totally wrong, and the electeds are completely correct in their belief that a shorter is the only way to make a better . Cutting the at Court achieves that goal, yes, but so does running the to Essex, a service pattern that would preserve Lower Manhattan connectivity. Could they not have gone for that pretty objectively better option? I’ll leave it to the forum to decide. *** I’m leaving this as a postscript because I think that this isn’t an important argument in the scheme of things, but there’s no way in hell that Whitehall will be able to turn and service — which means one of them is getting cut to Canal, which means less service to Lower Manhattan, etc etc Then as I would do it: and remain unchanged EXCEPT for the and all using the outer platform northbound at Essex, A new "Brown " runs 24/7 between 95th and Essex and replaces the late night shuttle (as those going to Whitehall can switch to the or at Court, Jay-Metrotech, etc. ). This eliminates the need to rebuild the connection to the Manny B, though long term that might not be a bad idea to do it anyway because it could in a pinch be used by trains unable to access 6th Avenue and/or Broadway to go back. when not running to 71st-Continental permanently goes to 96th Street-2nd Avenue at all other times. This would likely be the best way to keep the pols happy and keep the as is. 0 Quote Link to comment Share on other sites More sharing options...
MysteriousBtrain Posted February 21, 2019 Share #38 Posted February 21, 2019 (edited) You had me until you brought up the to second avenue. Cuomo and the hipsters may have won with the shutdown but who is actively going to look for a one seat ride from the east side to sixth avenue as much as a loss of an underwater tunnel with no replacement when lost? Now that I think about it essex st won't be an active weekend terminal for the but late nights the extension is not warranted. Edited February 21, 2019 by MysteriousBtrain 1 Quote Link to comment Share on other sites More sharing options...
biGC323232 Posted February 21, 2019 Share #39 Posted February 21, 2019 I'll simply have the operate with the the way the does with the ...All times expect late night between Astoria-95st..... 2 Quote Link to comment Share on other sites More sharing options...
W4ST Posted February 21, 2019 Share #40 Posted February 21, 2019 The MTA probably wouldn't do this because they haven't been investing in the in general, but I think that a 57th Street Flip would improve the situation greatly. In the 57th Street Flip, the Second Avenue Subway tracks would be connected with the Broadway Local tracks, partially through tunnels that already exist. This would deinterline Broadway (reducing the amount of merges for the ) and increase service and flexibility on the . The new service pattern would be: Broadway Express: Forest Hills to Coney Island via Sea Beach: 10 tph (could be increased to 15 tph if necessary) Broadway Express: Astoria to Coney Island via Brighton: 15 tph Broadway Local: 96th Street to Bay Ridge: 15 tph Broadway Local: Could go from 96 Street to Whitehall or from Whitehall to Bay Ridge or not exist, depending on what commuters want most. This would give Bay Ridge riders a shorter line with no merges and a lot of flexibility due to Whitehall, and would allow more trains to run on all of these lines (except Sea Beach, but they could probably increase service to 15 tph if necessary) 1 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted February 21, 2019 Share #41 Posted February 21, 2019 (edited) 12 hours ago, RR503 said: But let’s entertain for a second the possibility that all of this is totally wrong, and the electeds are completely correct in their belief that a shorter is the only way to make a better . Cutting the at Court achieves that goal, yes, but so does running the to Essex, a service pattern that would preserve Lower Manhattan connectivity. Could they not have gone for that pretty objectively better option? I’ll leave it to the forum to decide. *** I’m leaving this as a postscript because I think that this isn’t an important argument in the scheme of things, but there’s no way in hell that Whitehall will be able to turn and service — which means one of them is getting cut to Canal, which means less service to Lower Manhattan, etc etc Right. They can’t turn both the and at Whitehall. Perhaps then, they’d go for something like this: ( K ) - Runs between 95th Street and Essex via 4th Ave local, Montague Tunnel and Nassau - 24/7. Possibly cut back to Chambers on weekends so as not to interfere with the weekend turning at Essex. - Runs between 71st Avenue and Whitehall full time. No late night service...either use the or transfer to the ( K ) at Canal. -Runs between Ditmars-Astoria and 95th Street weekdays (same weekday hours as now). This way, we can retain through Whitehall service on weekdays and the Bay Ridge service has a much closer home base at Coney Island, rather than Jamaica Yard. So in essence, we’d have a Nassau train providing the full time service in Bay Ridge and a Whitehall service providing the supplemental service. Edited February 21, 2019 by T to Dyre Avenue 0 Quote Link to comment Share on other sites More sharing options...
P3F Posted February 21, 2019 Share #42 Posted February 21, 2019 Y'all are making this much more complicated than it needs to be. The simplest solution is to extend the or to 95th Street to provide additional service. I would advocate for the because extending it would mean that Williamsburg is a simple cross platform transfer away from all of the BMT Southern Division lines. Creating a stub line in this case would be simply wasteful. I read at some point that 95th Street is restricted to turning 10 trains per hour. Since the is scheduled at that, any additional service would require some kind of change at the terminal, assuming the restriction is true. It could be false information for all I know, though. 5 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted February 21, 2019 Share #43 Posted February 21, 2019 10 minutes ago, T to Dyre Avenue said: Right. They can’t turn both the and at Whitehall. Perhaps then, they’d go for something like this: K - Runs between 95th Street and Essex via 4th Ave local, Montague Tunnel and Nassau - 24/7. Possibly cut back to Chambers on weekends so as not to interfere with the weekend turning at Essex. - Runs between 71st Avenue and Whitehall full time. No late night service...either use the or transfer to the K at Canal. -Runs between Ditmars-Astoria and 95th Street weekdays (same weekday hours as now). This way, we can retain through Whitehall service on weekdays and the Bay Ridge service has a much closer home base at Coney Island, rather than Jamaica Yard. So in essence, we’d have a Nassau train providing the full time service in Bay Ridge and a Whitehall service providing the supplemental service. Won't work. You'd have the basically be the pre-1987 that I have previously myself proposed return and lack of a yard is a no-go (which is one reason why in the past I even considered having the come out of 95th with the shifted to the West End to use one example since the has Concourse Yard). As I would do it: "Brown " OR : 24/7 between 95th Street and Essex with yard runs extended to Broadway Junction in both directions (these would be on the schedule). This line replaces the late-night shuttle. : Runs as it does now on weekdays while when not running to 71st-Continental runs at all other times to 96th Street-2nd Avenue. and are unchanged. 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted February 21, 2019 Share #44 Posted February 21, 2019 (edited) 18 minutes ago, Wallyhorse said: Won't work. You'd have the basically be the pre-1987 that I have previously myself proposed return and lack of a yard is a no-go (which is one reason why in the past I even considered having the come out of 95th with the shifted to the West End to use one example since the has Concourse Yard). As I would do it: "Brown " OR : 24/7 between 95th Street and Essex with yard runs extended to Broadway Junction in both directions (these would be on the schedule). This line replaces the late-night shuttle. : Runs as it does now on weekdays while when not running to 71st-Continental runs at all other times to 96th Street-2nd Avenue. and are unchanged. I disagree. Unlike the , the is a part time line. And it does have a yard, Coney Island, and the current service’s end points are not anywhere near Coney Island. That’s why the first few morning and evening trains run in service via the to 59th, then via the to Whitehall. The ran that way in 2004-10 too, so apparently it wasn’t an issue back then either. Having a yard at either end of the line is a much more pressing need for a full time service versus a part time one. Oddly enough, the ’s last stop, Church Avenue, is not all that close to its home base, which like the is Coney Island. It doesn’t seem to be an issue for the 24/7 . Edited February 21, 2019 by T to Dyre Avenue 1 Quote Link to comment Share on other sites More sharing options...
S78 via Hylan Posted February 21, 2019 Share #45 Posted February 21, 2019 3 hours ago, P3F said: Y'all are making this much more complicated than it needs to be. The simplest solution is to extend the or to 95th Street to provide additional service. I would advocate for the because extending it would mean that Williamsburg is a simple cross platform transfer away from all of the BMT Southern Division lines. Creating a stub line in this case would be simply wasteful. I read at some point that 95th Street is restricted to turning 10 trains per hour. Since the is scheduled at that, any additional service would require some kind of change at the terminal, assuming the restriction is true. It could be false information for all I know, though. Extended the ? Absolutely not. I don’t need it delayed when I’m going home because of potential setbacks from increasing the route length. Simply fix 95 Street to allow more trains to turn, extend some rush hour trips and call it a day. 0 Quote Link to comment Share on other sites More sharing options...
paulrivera Posted February 21, 2019 Share #46 Posted February 21, 2019 Here's my idea: Jamaica Center-95th Street all times. 6 minute headways for a longer span during rush hour and skip-stop service discontinued (all other headways unchanged). Myrtle-Marcy express would be unaffected. The J only merges with the (even if it gets extended) and gets held up less often than the by far. Also, late night service would be cost neutral as you're practically merging the together with the late night shuttle. Forest Hills-Whitehall Street .... man, this is a tough one. We need a new interlocking near Whitehall to keep it down there. I don't think having alternating trains terminate at Canal is feasible but the reality is there isn't enough room for both the and to turn at Whitehall as is. A free transfer would be made available between Cortlandt Street ( only) and Fulton Street (any line) to avoid overburdening Canal Street. The passageway at Fulton Center is too well used as is, so it would have to be a MetroCard/NFP transfer with 3 legged options available where necessary. 0 Quote Link to comment Share on other sites More sharing options...
CenSin Posted February 21, 2019 Share #47 Posted February 21, 2019 (edited) 1 hour ago, paulrivera said: Here's my idea: Jamaica Center-95th Street all times. 6 minute headways for a longer span during rush hour and skip-stop service discontinued (all other headways unchanged). Myrtle-Marcy express would be unaffected. The J only merges with the (even if it gets extended) and gets held up less often than the by far. Also, late night service would be cost neutral as you're practically merging the together with the late night shuttle. Forest Hills-Whitehall Street .... man, this is a tough one. We need a new interlocking near Whitehall to keep it down there. I don't think having alternating trains terminate at Canal is feasible but the reality is there isn't enough room for both the and to turn at Whitehall as is. A free transfer would be made available between Cortlandt Street ( only) and Fulton Street (any line) to avoid overburdening Canal Street. The passageway at Fulton Center is too well used as is, so it would have to be a MetroCard/NFP transfer with 3 legged options available where necessary. Upper East Side to Coney Island Upper East Side to Coney Island Forest Hills to South Ferry Astoria to Bay Ridge with short turns at Astoria Boulevard and 9 Avenue to handle peak demand Trains coming from the yard or going to the yard will be extended via West End as a local to Bay Parkway. Now you insulate the problems between the expresses and the locals. And the locals are both shortened. Edited February 21, 2019 by CenSin 0 Quote Link to comment Share on other sites More sharing options...
Yankees4life Posted February 21, 2019 Share #48 Posted February 21, 2019 No thanks The 's problem is that the old brown died and the train has failed to replace it Brooklyn bound. There needs to be more s running in Brooklyn especially during rush hour every day and every week... 0 Quote Link to comment Share on other sites More sharing options...
NewFlyer 230 Posted February 21, 2019 Share #49 Posted February 21, 2019 (edited) This is interesting cause I was thinking about this recently. I have seen horrifying wait times up to 27 minutes in between trains especially on the weekend and during the late evening when the is not providing supplemental service. The does suffer quite a bit from being all local and running through 3 boroughs. Thats why I was thinking that the should run from Whitehall Street to Forest Hills 71st Ave while the runs from Astoria to Bay Ridge. I know we still run into that lack of yard access but the did that for years when it ran from Astoria to Bay Ridge but today the switches trains with the so I don’t think it would be as bad. At night the should run the current shuttle like the does now while the completely stops running after 11:30pm/12am. Its either that or you switch the QBL but you still end up with an issue. stays the same runs from 71st to WTC local stays the same. runs from Jamaica Center to Bay Ridge via Queens Blvd Express and 63rd street but then you have that weird track switch around 57th, unless the is made completely local and the is instead Express. However then the will be slow and unreliable like the is now. It seems like no matter what is done, there will be some problem that will arise. Edited February 21, 2019 by NewFlyer 230 2 Quote Link to comment Share on other sites More sharing options...
MysteriousBtrain Posted February 21, 2019 Share #50 Posted February 21, 2019 (edited) 56 minutes ago, NewFlyer 230 said: It seems like no matter what is done, there will be some problem that will arise. Spliting up the is no easy issue. I think you have to rewrite most of the BMT to make this split work. Something like this could kind of work for bay ridge residents but can cause trouble elsewhere: K between Essex St and Bay Ridge at all times between 2 Av and Coney Island via Sea beach and Broadway express between Astoria and Coney Island via Broadway, Montague and Brighton local; extra service between Whitehall st and Astoria to replace between Bay Ridge and Forest Hills weekdays, running express between 34 St and DeKalb Av with some trips to Second Av Weekend provided to Forest Hills Edited February 21, 2019 by MysteriousBtrain 0 Quote Link to comment Share on other sites More sharing options...
