R68OnBroadway Posted August 4, 2019 Share #551 Posted August 4, 2019 I still don't understand why they just don't send the to Astoria on weekends when it isn't being butchered; riders would love 8 minute frequencies and not being stuck behind a R46- in the grand scheme of things the should both be going to Astoria full time anyways... 1 Quote Link to comment Share on other sites More sharing options...
bwwnyc123 Posted August 4, 2019 Share #552 Posted August 4, 2019 (edited) Weekdays normal service SB going Express in Manhattan could use the merge crossovers south of 57 St-7Av and NB merge to Local tracks instead of in-between 34 St and 42 St. The and could handle 49 St without . Edited August 4, 2019 by bwwnyc123 0 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted August 4, 2019 Share #553 Posted August 4, 2019 32 minutes ago, bwwnyc123 said: Weekdays normal service SB going Express in Manhattan could use the merge crossovers south of 57 St-7Av and NB merge to Local tracks instead of in-between 34 St and 42 St. The and could handle 49 St without . How about no? You've only moved the merge to 57th instead. This obsession people have that the must run to Astoria is ridiculous... 3 Quote Link to comment Share on other sites More sharing options...
bwwnyc123 Posted August 4, 2019 Share #554 Posted August 4, 2019 21 minutes ago, R68OnBroadway said: How about no? You've only moved the merge to 57th instead. This obsession people have that the must run to Astoria is ridiculous... The N currently does run to Astoria. 0 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted August 4, 2019 Share #555 Posted August 4, 2019 2 minutes ago, bwwnyc123 said: The N currently does run to Astoria. I know it does, but under any plan to make Broadway reliable, you're going to need to send it to 96th and either de-interline 11th or just beef up service. 0 Quote Link to comment Share on other sites More sharing options...
bwwnyc123 Posted August 4, 2019 Share #556 Posted August 4, 2019 The merge at 57 St is better than between 34 St and 42 St. 0 Quote Link to comment Share on other sites More sharing options...
bwwnyc123 Posted August 4, 2019 Share #557 Posted August 4, 2019 Right but they don't need two full time routes serving 96 St all times. 0 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted August 4, 2019 Share #558 Posted August 4, 2019 8 minutes ago, bwwnyc123 said: Right but they don't need two full time routes serving 96 St all times. I say this proves you don't know what you're talking about... 2 Quote Link to comment Share on other sites More sharing options...
bwwnyc123 Posted August 4, 2019 Share #559 Posted August 4, 2019 and are both full time lines they don't need to serve 96 St all times like overnights one of them has to stop serving 96 St. 0 Quote Link to comment Share on other sites More sharing options...
bwwnyc123 Posted August 4, 2019 Share #560 Posted August 4, 2019 4 minutes ago, R68OnBroadway said: I say this proves you don't know what you're talking about... Just now, bwwnyc123 said: and are both full time lines they don't need to serve 96 St all times like overnights one of them has to stop serving 96 St. 0 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted August 4, 2019 Share #561 Posted August 4, 2019 14 minutes ago, bwwnyc123 said: and are both full time lines they don't need to serve 96 St all times like overnights one of them has to stop serving 96 St. And for what reason? If service levels are too high overnight then just cut the frequencies. No need to confuse people by sending the somewhere else overnight especially considering the fact that if anything, 2nd would have higher demand overnight than Astoria... 0 Quote Link to comment Share on other sites More sharing options...
LGA Link N Train Posted August 4, 2019 Share #562 Posted August 4, 2019 (edited) 19 minutes ago, bwwnyc123 said: and are both full time lines they don't need to serve 96 St all times like overnights one of them has to stop serving 96 St. If that’s the case, then truncate one of the routes in Lower Manhattan or Brooklyn for Late Nights. Have the (Or ) take over Astoria full time, and call it a day. The only way I’ll agree with having the stay at Astoria is if SAS Phase 3 gets built as planned, in which there will be no way to send trains up 96. Edited August 4, 2019 by LaGuardia Link N Tra 1 Quote Link to comment Share on other sites More sharing options...
Jemorie Posted August 4, 2019 Share #563 Posted August 4, 2019 1 hour ago, bwwnyc123 said: Weekdays normal service SB going Express in Manhattan could use the merge crossovers south of 57 St-7Av and NB merge to Local tracks instead of in-between 34 St and 42 St. The and could handle 49 St without . I agree that the and can serve 49th Street without the . The no longer terminates at 57 St-7 Av anyway. However, if you still want the to serve Astoria under your proposal, then the crossover switch from express to local and vice-verse would be better off north of 57 St-7 Av, not south of it. Generally and realistically speaking, I gotta go with both R68 and LGA with having all Broadway Express trains serve SAS full time and all Broadway Local trains serve Astoria full time. Not Queens Blvd though to be honest. 6 Av and Broadway are only one block away from each other despite the sidewalk distance being exceptionally long anyway so. 1 Quote Link to comment Share on other sites More sharing options...
R68OnBroadway Posted August 4, 2019 Share #564 Posted August 4, 2019 19 minutes ago, LaGuardia Link N Tra said: If that’s the case, then truncate one of the routes in Lower Manhattan or Brooklyn for Late Nights. Have the (Or ) take over Astoria full time, and call it a day. The only way I’ll agree with having the stay at Astoria is if SAS Phase 3 gets built as planned, in which there will be no way to send trains up 96. Even if phase 3 is built (which I don’t see happening for another 30 years), it’s better to just keep the at 96th until the issue of the arises. 2 Quote Link to comment Share on other sites More sharing options...
JeremiahC99 Posted August 4, 2019 Share #565 Posted August 4, 2019 22 minutes ago, Jemorie said: Generally and realistically speaking, I gotta go with both R68 and LGA with having all Broadway Express trains serve SAS full time and all Broadway Local trains serve Astoria full time. Not Queens Blvd though to be honest. 6 Av and Broadway are only one block away from each other despite the sidewalk distance being exceptionally long anyway so. I agree as well. If you run both the and at 6 minute interval (10 trains per hour), Second Avenue and Broadway Express service would see a train every three minutes, which is a big boon for the Upper East Side, and compete with the , , and . With the on Astoria at 15 trains per hour, we would see more frequent service on the Astoria, Broadway, and in Brooklyn. 0 Quote Link to comment Share on other sites More sharing options...
Lawrence St Posted August 4, 2019 Share #566 Posted August 4, 2019 If Phase 3 gets built wouldnt the have a merging delay at 72nd St? 0 Quote Link to comment Share on other sites More sharing options...
Deucey Posted August 4, 2019 Share #567 Posted August 4, 2019 1 hour ago, Lawrence St said: If Phase 3 gets built wouldnt the have a merging delay at 72nd St? Most likely. Delays at Prospect Park, delays at Canal St, Delays at 34-57th St, then at 2 Av. TBH, for how brief it is, Broadway Express seems pretty useless and unnecessary. 0 Quote Link to comment Share on other sites More sharing options...
JeremiahC99 Posted August 4, 2019 Share #568 Posted August 4, 2019 8 minutes ago, Deucey said: Most likely. Delays at Prospect Park, delays at Canal St, Delays at 34-57th St, then at 2 Av. TBH, for how brief it is, Broadway Express seems pretty useless and unnecessary. A Broadway Express In Second Avenue allows for direct access between the Upper East Side and West Midtown, which sure beats taking the to 59th Street and transferring there. From here, the Broadway Express trains would go into Brooklyn via the Manhattan Bridge. Since the and travel via Lower Manhattan, Broadway express allows for faster service into West Midtown and into Brooklyn. In fact, there was one person in an MTA Video who said their trip from Upper East Side to BAM at Barclays Center was much quicker with the new line. For more information: If they has the to Astoria at 15 trains per hour and the and both on Second Avenue at 10 trains per hour, then we will really see when more frequent and reliable service. 1 Quote Link to comment Share on other sites More sharing options...
Around the Horn Posted August 5, 2019 Author Share #569 Posted August 5, 2019 1 hour ago, Deucey said: Most likely. Delays at Prospect Park, delays at Canal St, Delays at 34-57th St, then at 2 Av. TBH, for how brief it is, Broadway Express seems pretty useless and unnecessary. The first thing you have to understand about express runs is that they're designed for crowd control not speed. So yeah its "brief" but it allows for the to handle most Midtown <--> Brooklyn passengers over the bridge which creates room on the for Lower Manhattan <--> Brooklyn passengers via the tunnel 0 Quote Link to comment Share on other sites More sharing options...
darkstar8983 Posted August 5, 2019 Share #570 Posted August 5, 2019 (edited) 2 hours ago, JeremiahC99 said: A Broadway Express In Second Avenue allows for direct access between the Upper East Side and West Midtown, which sure beats taking the to 59th Street and transferring there. From here, the Broadway Express trains would go into Brooklyn via the Manhattan Bridge. Since the and travel via Lower Manhattan, Broadway express allows for faster service into West Midtown and into Brooklyn. In fact, there was one person in an MTA Video who said their trip from Upper East Side to BAM at Barclays Center was much quicker with the new line. For more information: If they has the to Astoria at 15 trains per hour and the and both on Second Avenue at 10 trains per hour, then we will really see when more frequent and reliable service. or the could be cut off from Brooklyn and run only from 71 Av to Whitehall St and the extended to Bay Ridge. This way, Queens Boulevard keeps their designation, Astoria keeps their designation, and Bay Ridge gets a more frequent service. We also end up doing away with 90-minute route run times, which increase the likelihood for delays. Frequency - 10TPH - route run time 64 minutes - 10 TPH - route run time 66 minutes - 7 TPH (due to terminal constraints at Whitehall St and lower demand for Queens Blvd/Broadway service, but still a demand nonetheless, and a requirement due to inability to reroute Queens Boulevard locals to another Manhattan- trunk line (route run time - 52 minutes) -16TPH (with maybe 14TPH to Bay Ridge and remaining trains short-turn at 59 St-Brooklyn or Canal St) (route run time - 70 minutes) Edited August 5, 2019 by darkstar8983 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted August 5, 2019 Share #571 Posted August 5, 2019 I would be in favor of truncating the at Whitehall (perhaps using the or another letter for the designation). 0 Quote Link to comment Share on other sites More sharing options...
LGA Link N Train Posted August 5, 2019 Share #572 Posted August 5, 2019 2 hours ago, darkstar8983 said: or the could be cut off from Brooklyn and run only from 71 Av to Whitehall St and the extended to Bay Ridge. This way, Queens Boulevard keeps their designation, Astoria keeps their designation, and Bay Ridge gets a more frequent service. We also end up doing away with 90-minute route run times, which increase the likelihood for delays. Frequency - 10TPH - route run time 64 minutes - 10 TPH - route run time 66 minutes - 7 TPH (due to terminal constraints at Whitehall St and lower demand for Queens Blvd/Broadway service, but still a demand nonetheless, and a requirement due to inability to reroute Queens Boulevard locals to another Manhattan- trunk line (route run time - 52 minutes) -16TPH (with maybe 14TPH to Bay Ridge and remaining trains short-turn at 59 St-Brooklyn or Canal St) (route run time - 70 minutes) This is a good plan. But if I were you, I’d switch the and designations. 0 Quote Link to comment Share on other sites More sharing options...
darkstar8983 Posted August 5, 2019 Share #573 Posted August 5, 2019 8 hours ago, LaGuardia Link N Tra said: This is a good plan. But if I were you, I’d switch the and designations. That would probably confuse more people than the previously mentioned idea Its pretty much either confuse all of Queens or just confuse Bay Ridge 0 Quote Link to comment Share on other sites More sharing options...
Wallyhorse Posted August 5, 2019 Share #574 Posted August 5, 2019 11 hours ago, darkstar8983 said: or the could be cut off from Brooklyn and run only from 71 Av to Whitehall St and the extended to Bay Ridge. This way, Queens Boulevard keeps their designation, Astoria keeps their designation, and Bay Ridge gets a more frequent service. We also end up doing away with 90-minute route run times, which increase the likelihood for delays. Frequency - 10TPH - route run time 64 minutes - 10 TPH - route run time 66 minutes - 7 TPH (due to terminal constraints at Whitehall St and lower demand for Queens Blvd/Broadway service, but still a demand nonetheless, and a requirement due to inability to reroute Queens Boulevard locals to another Manhattan- trunk line (route run time - 52 minutes) -16TPH (with maybe 14TPH to Bay Ridge and remaining trains short-turn at 59 St-Brooklyn or Canal St) (route run time - 70 minutes) There are a considerable number of old timers who would never accept the having a southern terminal OTHER than 95th-Bay Ridge (something I was reminded of when I was putting together some of my ideas in the past). Keeping that in mind: and would both run as has been suggested to 96th and 2nd. runs 95th-Bay Ridge to Essex full time with scheduled in-service yard runs that end and begin at Broadway Junction that are in the schedule. Late nights and weekends could be extended to Metropolitan Avenue to replace the if the is not permanently extended after the shutdown ends. becomes the full-time Broadway local, running to either 9th Avenue or Bay Parkway (alternating trains, late nights operating from 9th Avenue) to Astoria. The can be beefed up to become a full-time service to 71st-Continental if the is taken off Broadway. 0 Quote Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted August 5, 2019 Share #575 Posted August 5, 2019 (edited) 3 hours ago, darkstar8983 said: That would probably confuse more people than the previously mentioned idea Its pretty much either confuse all of Queens or just confuse Bay Ridge That’s sort of what the did with the current service. They confused “all of Queens,” instead of just Middle Village and Ridgewood. Otherwise, we’d still have a train (going to/from Metropolitan) and no train today. Edited August 5, 2019 by T to Dyre Avenue 0 Quote Link to comment Share on other sites More sharing options...
