metsfan Posted February 21, 2009 Share #26 Posted February 21, 2009 Shuttle bus from lexington ave! - A Link to comment Share on other sites More sharing options...
MTR Admiralty Posted February 22, 2009 Share #27 Posted February 22, 2009 I believe that RI needs a bridge to Manhattan Island. Link to comment Share on other sites More sharing options...
metsfan Posted February 22, 2009 Share #28 Posted February 22, 2009 I believe that RI needs a bridge to Manhattan Island. Technically it does. There was a one point a car lift on the QBB. There really isn't room for a bridge, plus how would you keep it clear for ships? I think a ferry would be a good choice, supplemented by shuttle bus as a back up. - A Link to comment Share on other sites More sharing options...
MTR Admiralty Posted February 22, 2009 Share #29 Posted February 22, 2009 Technically it does. There was a one point a car lift on the QBB. There really isn't room for a bridge, plus how would you keep it clear for ships? I think a ferry would be a good choice, supplemented by shuttle bus as a back up. - A Well true, given the constraints that you mentioned it would be technically impossible. But also, we did all mention about the tide thing right? Link to comment Share on other sites More sharing options...
metsfan Posted February 22, 2009 Share #30 Posted February 22, 2009 Well true, given the constraints that you mentioned it would be technically impossible. But also, we did all mention about the tide thing right? It's not the most ideal solution due to the tides, but it would work if they used the right combo of berth & boat. For a hundred years they had railcar float docks, i'm sure people wouldn't be any harder... - A Link to comment Share on other sites More sharing options...
MTR Admiralty Posted February 22, 2009 Share #31 Posted February 22, 2009 It's not the most ideal solution due to the tides, but it would work if they used the right combo of berth & boat. For a hundred years they had railcar float docks, i'm sure people wouldn't be any harder... - A Yeah, you think NY Water Taxi could do it? Link to comment Share on other sites More sharing options...
metsfan Posted February 22, 2009 Share #32 Posted February 22, 2009 Yeah, you think NY Water Taxi could do it? That is exactly what i was thinking. - A Link to comment Share on other sites More sharing options...
MattTrain Posted February 22, 2009 Share #33 Posted February 22, 2009 Leave it as is, I think the trains are enough to serve Roosevelt Island. If anything, why not extend the from 57th Street, via the 63rd Street Connector and make local stops to Forest Hills, but then again, you can't have five different routes running at one line. Link to comment Share on other sites More sharing options...
Urbanfortitude Posted February 22, 2009 Share #34 Posted February 22, 2009 Leave it as is, I think the trains are enough to serve Roosevelt Island. If anything, why not extend the from 57th Street, via the 63rd Street Connector and make local stops to Forest Hills, but then again, you can't have five different routes running at one line. If they extend the anywhere it should be Astoria...if the gets cut that would be a great replacement for it. Link to comment Share on other sites More sharing options...
Joe Posted February 22, 2009 Share #35 Posted February 22, 2009 What about sending the R through the BMT 63rd Street Line, and run it along the F. Switch to the local tracks at 36th Street. Send the Q through the 60th Street Tunnel replacing W service? Oh god, i'm starting to sound like a crazy subchatter MUST STOP MUST STOP! Link to comment Share on other sites More sharing options...
metsfan Posted February 22, 2009 Share #36 Posted February 22, 2009 Roosevelt Island has a ~70% occupancy rate, and new projects on the line that will likely bring that number higher as word of mouth spreads the idea of lving there. It will need something better, because if the 63rd st tunnel section of the line is interrupted, they have no alternative while the tram isn't running in the future. Yea yea there's the one bus line, but that won't be enough for stand-in. - A Link to comment Share on other sites More sharing options...
R32 3348 Posted February 22, 2009 Share #37 Posted February 22, 2009 What about sending the R through the BMT 63rd Street Line, and run it along the F. Switch to the local tracks at 36th Street. Send the Q through the 60th Street Tunnel replacing W service? Oh god, i'm starting to sound like a crazy subchatter MUST STOP MUST STOP! The and many Queens Blvd. riders will no longer have access to the and , and one less transfer to the . Link to comment Share on other sites More sharing options...
Joe Posted February 22, 2009 Share #38 Posted February 22, 2009 The and many Queens Blvd. riders will no longer have access to the and , and one less transfer to the . There's the OOS transfer between Lexington-63rd and 59th street right? Link to comment Share on other sites More sharing options...
Tbirdbassist Posted February 23, 2009 Share #39 Posted February 23, 2009 It was already mentioned in this thread that very few peopel use that transfer. Infact, it is a very inconvenient transfer. People won't like having to make that trip. It takes a good 2-3 minutes just to get out of 63rd-Lex, then there's the walk to 59th st which is another 5 minutes... not very fun at all. I doubt the 6 months of no tram will warrant more subway service, and I doubt Roosevelt Islands pop/ il lever be great enough to warrant more service. Link to comment Share on other sites More sharing options...
via White Plains Road Posted February 23, 2009 Share #40 Posted February 23, 2009 There's the OOS transfer between Lexington-63rd and 59th street right? Yes with your Metro-Card transfer! Link to comment Share on other sites More sharing options...
metsfan Posted February 23, 2009 Share #41 Posted February 23, 2009 I still think that a ferry would be best. - A Link to comment Share on other sites More sharing options...
KeystoneRegional Posted February 23, 2009 Share #42 Posted February 23, 2009 Please, watch the Nazi Banksters Crimes Ripple Effect at http://jforjustice.co.uk/banksters Link to comment Share on other sites More sharing options...
MTR Admiralty Posted February 24, 2009 Share #43 Posted February 24, 2009 Roosevelt Island has a ~70% occupancy rate, and new projects on the line that will likely bring that number higher as word of mouth spreads the idea of lving there. It will need something better, because if the 63rd st tunnel section of the line is interrupted, they have no alternative while the tram isn't running in the future. Yea yea there's the one bus line, but that won't be enough for stand-in. - A Exactly, if there is a GO along this stretch during this time period, the Islanders are pretty much screwed. There's the OOS transfer between Lexington-63rd and 59th street right? Yeah... go ahead and tell them to walk 4 blocks from one station to another. Oh, I forgot to mention, the Lex station on the F is pretty darn deep, so yeah, have fun going out into the street from the tunnel, down the street and into another hole. Link to comment Share on other sites More sharing options...
