R44 5278 Posted October 28, 2009 Share #1 Posted October 28, 2009 I am currently researching about the old automobile inductive ignition system with a distributor and I'm stuck in calculating certain components. I chose the ratio of 1:70 coil turns from the primary to secondary coil, which results roughly around 243 primary coil turns and 17000 secondary coil turns. If I were to use 12v for the primary coil, how do I calculate the output on the secondary coil for around 10000v using mutual inductance and Faraday's Law of Induction? After that, how do I solve for charge time , voltage rise time , and spark duration using the distributor? Please also include an equations/formulas in addition to the numbers. Link to comment Share on other sites More sharing options...
Messino Posted October 28, 2009 Share #2 Posted October 28, 2009 Google is your friend. http://www.fas.harvard.edu/~scphys/courses/E1b/E1b_3b.pdf Link to comment Share on other sites More sharing options...
Olegkha Posted October 29, 2009 Share #3 Posted October 29, 2009 I am currently researching about the old automobile inductive ignition system with a distributor and I'm stuck in calculating certain components. I chose the ratio of 1:70 coil turns from the primary to secondary coil, which results roughly around 243 primary coil turns and 17000 secondary coil turns. If I were to use 12v for the primary coil, how do I calculate the output on the secondary coil for around 10000v using mutual inductance and Faraday's Law of Induction? After that, how do I solve for charge time , voltage rise time , and spark duration using the distributor? Please also include an equations/formulas in addition to the numbers. Yo ! was that in English ! sorry Link to comment Share on other sites More sharing options...
R44 5278 Posted October 29, 2009 Author Share #4 Posted October 29, 2009 Google is your friend.http://www.fas.harvard.edu/~scphys/courses/E1b/E1b_3b.pdf Thanks, that helped a lot! Yo ! was that in English ! sorry Are you serious? Just b/c you don't know Physics doesn't mean you should mock me for still learning about my interest. Link to comment Share on other sites More sharing options...
Olegkha Posted October 29, 2009 Share #5 Posted October 29, 2009 Thanks, that helped a lot! Are you serious? Just b/c you don't know Physics doesn't mean you should mock me for still learning about my interest. Dude I was not mocking you, i was just making a joke. I dont know physics and chemistry, and i envy people who know any of these subjects Link to comment Share on other sites More sharing options...
