2 Train Master Posted December 31, 2010 Share #26 Posted December 31, 2010 They work!!! :D I don't think they work properly though because notice that you put it at maximum speed and it only crawls forwards. Then try stopping it and see how long it takes. Oh and do you know how to change the signs on the train? I think it's with a control while in-game but I can't find out. O umm..I'm using a different engine thats why.Thats no issue it can be changed back to its original which I believe is "nycta-subway" or something. Link to comment Share on other sites More sharing options...
Gorgor Posted December 31, 2010 Author Share #27 Posted December 31, 2010 O umm..I'm using a different engine thats why.Thats no issue it can be changed back to its original which I believe is "nycta-subway" or something. Yeah that's what I mean, the original one is so slow and has such bad braking. Is there a way to edit it to make it better, or to give it the same engine as another already existing train? Link to comment Share on other sites More sharing options...
rr4567 Posted December 31, 2010 Share #28 Posted December 31, 2010 Yes sir no errors such as missing attachments or anything. Good. I know what game I'm gonna buy next TRS2006 is pissing me off. Link to comment Share on other sites More sharing options...
KTrainExp Posted December 31, 2010 Share #29 Posted December 31, 2010 Oh and do you know how to change the signs on the train? I think it's with a control while in-game but I can't find out. To manually do it, you have to be in Surveyor. Right click the train and a box should pop up. Then scroll down to where it says Destination or something, look at the list of destinations, click it and then it should turn up. If you want to do it while driving, you have to download a command off the DLS called Switch signs or something. Have fun! Link to comment Share on other sites More sharing options...
Gorgor Posted December 31, 2010 Author Share #30 Posted December 31, 2010 To manually do it, you have to be in Surveyor. Right click the train and a box should pop up. Then scroll down to where it says Destination or something, look at the list of destinations, click it and then it should turn up. If you want to do it while driving, you have to download a command off the DLS called Switch signs or something. Have fun! In surveyor right clicking moves the compass, and I can't find anything close to "Switch signs" in the DLS. Link to comment Share on other sites More sharing options...
Trainlevel2 Posted December 31, 2010 Share #31 Posted December 31, 2010 I got them to work (using CCP and, in the case of the ones with the error: ..../poles.texture will not load, I used PM to IM and it fixed the error). Eric Link to comment Share on other sites More sharing options...
2 Train Master Posted January 1, 2011 Share #32 Posted January 1, 2011 I got them to work (using CCP and, in the case of the ones with the error: ..../poles.texture will not load, I used PM to IM and it fixed the error).Eric Glad to hear that and I did the same thing also the PM to IM or vice-versa.LOL great! Link to comment Share on other sites More sharing options...
GreeneggsnPelham Posted January 18, 2011 Share #33 Posted January 18, 2011 In surveyor right clicking moves the compass, and I can't find anything close to "Switch signs" in the DLS. It's built-in into TS2010. Under the session settings, and "driver commands" select "Change Destination Sign". Then in the main screen for session settings, click "add" and select "DestSignTable". Then, place your subway cars in your route and then right before going into driver mode, go back into the session rules, select "DestSignTable" and click "edit". Then go to "import destination textures" and select the destinations you'd like to use (i.e. if you have only R62's on your route, select the R62 signs). Then, while in driver, hit the command, "Change Destination Sign", and your list of signs should come up, and then you can change it while driving. -A :cool: Link to comment Share on other sites More sharing options...
2 Train Master Posted January 18, 2011 Share #34 Posted January 18, 2011 So everyone who has Trainz 2010 has the subway stuff working? Link to comment Share on other sites More sharing options...
GreeneggsnPelham Posted January 18, 2011 Share #35 Posted January 18, 2011 None of my current stuff is working because I just got a new laptop. I've done everything, and I have to run it in compatibility mode---but with errors. I'm trying to get some CDPs I have saved that were modified to work. Trying not to get frustrated...:mad: Link to comment Share on other sites More sharing options...
2 Train Master Posted January 18, 2011 Share #36 Posted January 18, 2011 None of my current stuff is working because I just got a new laptop. I've done everything, and I have to run it in compatibility mode---but with errors. I'm trying to get some CDPs I have saved that were modified to work. Trying not to get frustrated...:mad: Ok and yea use compatibility mode. Link to comment Share on other sites More sharing options...
Bonanza123d Posted January 25, 2011 Share #37 Posted January 25, 2011 I am thinking about redoing everything when i get 2010, but in the mean time, i am working on BVE stuff. Link to comment Share on other sites More sharing options...
GreeneggsnPelham Posted January 25, 2011 Share #38 Posted January 25, 2011 Everything is finally working. But due to the graphics-heavy nature of 2010, I've gone back to using 2006 which is looking crispy clean! Link to comment Share on other sites More sharing options...
TrainzLover Posted June 5, 2011 Share #39 Posted June 5, 2011 Magicland's trains are for TRS2004. They aren't compatible with TRS2010, which is why I still use TRS2006 So they dont work with Trainz 2009 - 2010 Link to comment Share on other sites More sharing options...
TrainzLover Posted June 5, 2011 Share #40 Posted June 5, 2011 Ok and yea use compatibility mode. How do u get into compability mode Link to comment Share on other sites More sharing options...
2 Train Master Posted June 6, 2011 Share #41 Posted June 6, 2011 So they dont work with Trainz 2009 - 2010 http://www.youtube.com/watch?v=0gIhKrcsFNs&feature=player_embedded How do u get into compability mode You dont need that mode just download them. Link to comment Share on other sites More sharing options...
TrainzLover Posted June 12, 2011 Share #42 Posted June 12, 2011 http://www.youtube.com/watch?v=0gIhKrcsFNs&feature=player_embedded You dont need that mode just download them. SO u just download the stuff off of Trainz Download Station and thats it? Link to comment Share on other sites More sharing options...
2 Train Master Posted June 12, 2011 Share #43 Posted June 12, 2011 SO u just download the stuff off of Trainz Download Station and thats it? Yea if a red exclamation point is present after the download right click for view errors and the main thing should be there is a passenger so u open it in CCP and delete the one highlighted in red save commit boom. Link to comment Share on other sites More sharing options...
TrainzLover Posted June 21, 2011 Share #44 Posted June 21, 2011 Yea if a red exclamation point is present after the download right click for view errors and the main thing should be there is a passenger so u open it in CCP and delete the one highlighted in red save commit boom. Thanks a lot add me as a friend Link to comment Share on other sites More sharing options...
stamenqua Posted July 19, 2011 Share #45 Posted July 19, 2011 i have trainz 2012 theres no compatibilty mode on that but devs promised older content is compatbile what should i do to get them to work ? Link to comment Share on other sites More sharing options...
Pickles3612 Posted September 28, 2011 Share #46 Posted September 28, 2011 does anyone know how to find compatibility mode for trainz 2010 or 12 because i also need help with getting magiclands subway cars to work PLEASE ANY HELP WOULD BE APPRECIATED. Link to comment Share on other sites More sharing options...
