Via Garibaldi 8 Posted May 22, 2015 Share #1 Posted May 22, 2015 Just curious as to what the procedures are for a sick passenger? There was a Northbound train held at Columbus Circle last night for what seemed like an eternity, as there was an stuck behind the . Unfortunately, I got off of a packed train on the local track (as did other folks) thinking the one across the platform was going soon, only to find out that wasn't the case, and after that one left and a came, there were no trains after that, and I really didn't feel like going local to my destination. The train eventually left about 20 minutes later, just as I was texting my client to inform them that I would have to cancel my private session with them due to me being stuck with no uptown subway service. All of this was due to a sick passenger. I'm sympathetic of the situation, but this was during rush hour and this one passenger basically affected several lines. Are they required to keep the passenger on the train? Link to comment Share on other sites More sharing options...
itmaybeokay Posted May 22, 2015 Share #2 Posted May 22, 2015 I've listened to these situations on the radio, so I can't speak to what the procedure in the book is, but I can tell you what I've heard actually happen. When there's a report of a sick passenger the C/R will go investigate. If the passenger can be assisted onto the platform, generally another MTA staffer will come and wait with the customer for EMS and the C/R will return to their position and the train will proceed. If, however, the passenger is completely unconscious or otherwise immobile, there's little choice other than the train waiting right where it is for EMS. I'm all for "the needs of the many outweigh the needs of the one", but I don't think we can have conductors literally dragging unconscious passengers off the train. I'm not sure what could be done better other than pre-staging EMS at busy stations, but that would be prohibitively expensive and relatively infrequently helpful. Link to comment Share on other sites More sharing options...
Q113 LTD Posted May 22, 2015 Share #3 Posted May 22, 2015 I think passengers would notify train crew and then the train crew would radio dispatch(about the incident) and they suppose to let the sick passenger off the train until EMS arrive so trains won't be delay. One time, I was on the train(leaving Far Rockaway) and when the train arrived at Broad Channel, the conductor announced that there was a sick passenger on board. The train was held there for like a minute or two. When I am at home, I usually get notifications from my app saying sick passenger at Chambers St, 59 St - Columbus Circle, 145 st, etc. Link to comment Share on other sites More sharing options...
smileyjapa Posted May 22, 2015 Share #4 Posted May 22, 2015 Basically it gets called to control the conductor investigates. The passenger is asked if they want medical assistance or not. If they can get off the train then they do. They then wait for EMS If they are with someone then the conductor can return to their position. If the customer is alone then the train gets discharged because the conductor has to remain with the sick passenger. Link to comment Share on other sites More sharing options...
GojiMet86 Posted May 23, 2015 Share #5 Posted May 23, 2015 Happened about a month ago at 49th Street, the conductor had to get off the train to help someone, and the train had to go out of service. Link to comment Share on other sites More sharing options...
Dj Hammers Posted May 23, 2015 Share #6 Posted May 23, 2015 and I really didn't feel like going local to my destination. Common sense dictates that if an express is more than 5 minutes behind the local, the local will get you there either faster or in the same amount of time. The stigma against locals is strong, but in a lot of cases unfounded, especially on IND lines in Manhattan below 59th Street. Link to comment Share on other sites More sharing options...
Via Garibaldi 8 Posted May 24, 2015 Author Share #7 Posted May 24, 2015 Common sense dictates that if an express is more than 5 minutes behind the local, the local will get you there either faster or in the same amount of time. The stigma against locals is strong, but in a lot of cases unfounded, especially on IND lines in Manhattan below 59th Street. I'm aware of that fact and have used the local from time to time. The thing is sometimes I don't feel like making all of those stops. I don't sit down, so fewer stops means that I don't have to move around allowing people to get off. Link to comment Share on other sites More sharing options...
Daniel The Cool Posted May 24, 2015 Share #8 Posted May 24, 2015 I'm aware of that fact and have used the local from time to time. The thing is sometimes I don't feel like making all of those stops. I don't sit down, so fewer stops means that I don't have to move around allowing people to get off. SMH. Link to comment Share on other sites More sharing options...
peacemak3r Posted May 24, 2015 Share #9 Posted May 24, 2015 I'm not going to lie, if I could avoid stopping frequently, I'd tend to take that route then. Hence I usually take the home rather the . It's not even if it were faster or not, I just don't like dealing with many stops. (I stand most of the time also as VG8 does.) -- I had an incident similar to VG8 though involving a sick customer, but I had also signal problems. The northbound I was on was stuck right before Broadway-Lafayette. I eventually got off at W 4 to take the but ended up being stuck there as well. I actually ended up taking the cab to my destination. Link to comment Share on other sites More sharing options...
