UlmerPark B6 Posted December 30, 2008 Share #51 Posted December 30, 2008 BLOCKAGE: Due to a FBI investigation, southbound Dekalb Avenue is closed including the bypass (southbound). TIME: Start of PM Rush Hour ANTICIPATED DURATION: 5 hours Link to comment Share on other sites More sharing options...
Amtrak7 Posted December 30, 2008 Share #52 Posted December 30, 2008 Yes, for mine, eastbound tracks are open. UlmerParkB6- ( SUSPENDED Manhattan side- run to Essex St. and terminate. Local in Manhattan south of 34 St. terminate Hewes St. trains Broad St.-Chambers St. terminate Canal St., deadhead to City Hall. terminate Whitehall if capacity allows, otherwise Canal. Brooklyn side- trains 59 St.-Coney Island trains 36 St.-Coney Island (West End) trains 59 St.-95 St. Prospect Pk-Coney Island buses run as follows- Essex St.-DeKalb-Pacific-36 St. Hewes St.-Essex-Bowery-Canal-Chambers St. Canal St.-Whitehall-Court-Lawrence-36 St. All buses are artics. SUSPENDED Once all reaches northern terminal, suspend northbound service in Bk. MTA CEO gives speech.B) Link to comment Share on other sites More sharing options...
MTR Admiralty Posted December 30, 2008 Share #53 Posted December 30, 2008 BLOCKAGE: Bomb scare at Times Square on the BMT Broadway Line TIME: 5:00 PM ANTICIPATED DURATION: 4 hours Link to comment Share on other sites More sharing options...
SevenEleven Posted December 30, 2008 Share #54 Posted December 30, 2008 Here's my try at this: trains terminate at 34th Street and operate in two sections: 34th Street to Coney Island, Queensboro Plaza to Astoria trains terminate at 34th. trains run between 71 Av and 57th Street runs between 34th and Bay Ridge to provide service in Brooklyn. trains run local in both directions. The trains on layup at 57th can be used for service on the . Another way can also have the rerouted to Bay Ridge with no service to Bay Parkway. Link to comment Share on other sites More sharing options...
Jamaica Express Posted December 30, 2008 Share #55 Posted December 30, 2008 BLOCKAGE: Due to a FBI investigation, southbound Dekalb Avenue is closed including the bypass (southbound).TIME: Start of PM Rush Hour ANTICIPATED DURATION: 5 hours ...this is one is interesting southbound trains termianted at W4 Street from manhattan operates local via to Coney Island southbound trains terminate at 57th Street southbound service suspended in Manhattan south shuttle service between Prospect Park and Coney Island south shuttle service between Pacific St and Coney Island southbound shuttle service between 36th street and 95th street in manhattan terminates at Canal and Whitehall sts alternating with no south brooklyn service Link to comment Share on other sites More sharing options...
UlmerPark B6 Posted December 30, 2008 Share #56 Posted December 30, 2008 Yes, for mine, eastbound tracks are open. UlmerParkB6- ( SUSPENDED Manhattan side- run to Essex St. and terminate. Local in Manhattan south of 34 St. terminate Hewes St. trains Broad St.-Chambers St. terminate Canal St., deadhead to City Hall. terminate Whitehall if capacity allows, otherwise Canal. Brooklyn side- trains 59 St.-Coney Island trains 36 St.-Coney Island (West End) trains 59 St.-95 St. Prospect Pk-Coney Island buses run as follows- Essex St.-DeKalb-Pacific-36 St. Hewes St.-Essex-Bowery-Canal-Chambers St. Canal St.-Whitehall-Court-Lawrence-36 St. All buses are artics. SUSPENDED Once all reaches northern terminal, suspend northbound service in Bk. MTA CEO gives speech.B) You can't run to Essex St. because you can't have 75-footers running on the Jamaica Line. Also, there is a layup you can do south of Canal St. but that would take forever. Link to comment Share on other sites More sharing options...
UlmerPark B6 Posted December 30, 2008 Share #57 Posted December 30, 2008 ...this is one is interesting southbound trains termianted at W4 Street from manhattan operates local via to Coney Island southbound trains terminate at 57th Street southbound service suspended in Manhattan south shuttle service between Prospect Park and Coney Island south shuttle service between Pacific St and Coney Island southbound shuttle service between 36th street and 95th street in manhattan terminates at Canal and Whitehall sts alternating with no south brooklyn service That one can work. Mine would be: ( suspended shuttle runs from Bedford Park-Euclid Avenue via the switch to , , and line south of West 4th St. making the ( run local everywhere runs on the to Coney Island then go back on the West End northbound suspended service limited terminates at Broad St. terminates at Lawerence St. Northbound runs to 21 St- and then relays and runs to Coney Island via line terminates at Whitehall St. Suspended That will be the best service alert ever except the FBI part. Means that someone got killed there. Link to comment Share on other sites More sharing options...
UlmerPark B6 Posted December 30, 2008 Share #58 Posted December 30, 2008 BLOCKAGE: Bomb scare at Times Square on the BMT Broadway LineTIME: 5:00 PM ANTICIPATED DURATION: 4 hours service suspended runs over the North Side of Manhattan Bridge and runs on the from Broadway-Layfeyette to Queens Plaza terminates at 34 th St. while running via Whitehall St. suspended service limited runs on the North Side of Manhattan Bridge then runs to 21 St. Link to comment Share on other sites More sharing options...
MTR Admiralty Posted December 30, 2008 Share #59 Posted December 30, 2008 service suspended runs over the North Side of Manhattan Bridge and runs on the from Broadway-Layfeyette to Queens Plaza terminates at 34 th St. while running via Whitehall St. suspended service limited runs on the North Side of Manhattan Bridge then runs to 21 St. Most of them are correct, however... service stays normal Suspend , runs on North side of M Bridge then via line to 145th Street. Link to comment Share on other sites More sharing options...
Amtrak7 Posted December 30, 2008 Share #60 Posted December 30, 2008 My idea for the TSQ one- SUSPENDED 2 sections-Astoria-57 St. and 57 St. -CI via 6 Av. express via 6 Av local, 53 St, Grand St. via lower Manhattan to City Hall My problem- BLOCKAGE: Disabled train Northbound Grand St. TIME: Afternoon rush hour ANTICIPATED DURATION: 15-30 min. Link to comment Share on other sites More sharing options...
MTR Admiralty Posted December 30, 2008 Share #61 Posted December 30, 2008 My idea for the TSQ one- SUSPENDED 2 sections-Astoria-57 St. and 57 St. -CI via 6 Av. express via 6 Av local, 53 St, Grand St. via lower Manhattan to City Hall My problem- BLOCKAGE: Disabled train Northbound Grand St. TIME: Afternoon rush hour ANTICIPATED DURATION: 15-30 min. What will replace lost service in Upper Manhattan? For yours Send via Broadway Express to 57th Street Select runs express Link to comment Share on other sites More sharing options...
UlmerPark B6 Posted December 30, 2008 Share #62 Posted December 30, 2008 My idea for the TSQ one- SUSPENDED 2 sections-Astoria-57 St. and 57 St. -CI via 6 Av. express via 6 Av local, 53 St, Grand St. via lower Manhattan to City Hall My problem- BLOCKAGE: Disabled train Northbound Grand St. TIME: Afternoon rush hour ANTICIPATED DURATION: 15-30 min. Northbound runs on the Broadway Express to 57th St like the old Northbound runs on the from Coney Island to West 4th St. Some running 6th Avenue express Link to comment Share on other sites More sharing options...
via White Plains Road Posted December 31, 2008 Share #63 Posted December 31, 2008 My problem- BLOCKAGE: Disabled train Northbound Grand St. TIME: Afternoon rush hour ANTICIPATED DURATION: 15-30 min. Ok....I never did this b4 so I'll give this a try: trains can run via Culver Line up to West 4th Street, then resume express service from West 4th Street ( train can run via Broadway Express Line up to 57th Street-7th Avenue.....selected can replace the ( to Bedford Park Blvd Or some ( trains can run via Culver Express Line to Smith-9th Street, when going to Jay Street-Borough Hall cross over onto the (A)/© lines to via 8th Avenue Express Line to 59th Street-Columbus Circle then cross over onto the local tracks Link to comment Share on other sites More sharing options...
MTR Admiralty Posted December 31, 2008 Share #64 Posted December 31, 2008 ( train can run via Broadway Express Line up to 57th Street-7th Avenue.....selected can replace the ( to Bedford Park Blvd D runs to 205th (one stop after Bedford Park Boulevard), so there is no need to terminate at Bedford Park Boulevard. Link to comment Share on other sites More sharing options...
via White Plains Road Posted January 1, 2009 Share #65 Posted January 1, 2009 D runs to 205th (one stop after Bedford Park Boulevard), so there is no need to terminate at Bedford Park Boulevard. Eh I know, it was worth a try lol Link to comment Share on other sites More sharing options...
MTR Admiralty Posted January 1, 2009 Share #66 Posted January 1, 2009 Eh I know, it was worth a try lol Good try.. how about this? Blockage: 12/9 Location: Bedford Avenue , Canarsie bound track Expected Duration: 3 Hrs Link to comment Share on other sites More sharing options...
UlmerPark B6 Posted January 1, 2009 Share #67 Posted January 1, 2009 Good try.. how about this? Blockage: 12/9 Location: Bedford Avenue , Canarsie bound track Expected Duration: 3 Hrs Run the evry 20 minutes. Canarsie-bound trains crosses over to West-bound tracks after 14 St- runs carefully with Manhattan-bound waiting east of Bedford Ave. Link to comment Share on other sites More sharing options...
via White Plains Road Posted January 2, 2009 Share #68 Posted January 2, 2009 Good try.. how about this? Blockage: 12/9 Location: Bedford Avenue , Canarsie bound track Expected Duration: 3 Hrs Make Shuttle buses run b/w Bedford Avenue and Mrytle-Wyckoff Avenues or Brooklyn bound (L)'s run b/w 1st Avenue and 8th Avenue-14th Street! Link to comment Share on other sites More sharing options...
MTR Admiralty Posted January 2, 2009 Share #69 Posted January 2, 2009 Make Shuttle buses run b/w Bedford Avenue and Mrytle-Wyckoff Avenues or Brooklyn bound (L)'s run b/w 1st Avenue and 8th Avenue-14th Street! Interesting, however there may be a shortage of buses at the depot. The GOs were organised so the depots expected a certain number of buses needed to shuttle the riders. But this is sudden... so what I will do is: -Have ALL trains bypass 3rd Avenue -Switch eastbound trains on the westbound track just before 3rd Avenue -Trains will switch back onto eastbound track after Bedford Avenue -Have select trains from Canarsie terminate at Myrtle Avenue Link to comment Share on other sites More sharing options...
Amtrak7 Posted January 2, 2009 Share #70 Posted January 2, 2009 What would YOU do in this situation? This really happened before. Mechanical problems Manhattan-bound Bway Manhattan Bridge AND Manhattan-bound City Hall. MTA's fix- to 57 St. to 145 St. ( runs on in Manhattan Link to comment Share on other sites More sharing options...
MTR Admiralty Posted January 3, 2009 Share #71 Posted January 3, 2009 What would YOU do in this situation? This really happened before. Mechanical problems Manhattan-bound Bway Manhattan Bridge AND Manhattan-bound City Hall. MTA's fix- to 57 St. to 145 St. ( runs on in Manhattan Yeah it did happen before.. it was discussed on a previous thread. See R160 Q via 6 Av or something of the sort. Link to comment Share on other sites More sharing options...
Daniel The Cool Posted January 3, 2009 Share #72 Posted January 3, 2009 Yeah it did happen before.. it was discussed on a previous thread. See R160 Q via 6 Av or something of the sort. yep it did Link to comment Share on other sites More sharing options...
SevenEleven Posted January 3, 2009 Share #73 Posted January 3, 2009 What would YOU do in this situation? This really happened before. Mechanical problems Manhattan-bound Bway Manhattan Bridge AND Manhattan-bound City Hall. MTA's fix- to 57 St. to 145 St. ( runs on in Manhattan and suspended to 57 St- 6th Ave via the and lines Select trains are local in Queens trains via CPW Local to 145th St Link to comment Share on other sites More sharing options...
Amtrak7 Posted January 8, 2009 Share #74 Posted January 8, 2009 My strategy for the MTA problem- SUSPENDED via 53 St. runs on to 21 St. runs on to 21 St. If congestion starts to build at 21 St., send some trains OOS at 57 St. and run them to the other side of 63 St./Lex. Link to comment Share on other sites More sharing options...
MTR Admiralty Posted January 8, 2009 Share #75 Posted January 8, 2009 My strategy for the MTA problem- SUSPENDED via 53 St. runs on to 21 St. runs on to 21 St. If congestion starts to build at 21 St., send some trains OOS at 57 St. and run them to the other side of 63 St./Lex. Interesting G.O... Link to comment Share on other sites More sharing options...
