RR503 Posted December 24, 2017 Share #126 Posted December 24, 2017 On 12/23/2017 at 3:36 PM, bobtehpanda said: The ROW looks plenty wide enough til Roosevelt (at which point it would be tunnel all the way to Astoria), but honestly, a little eminent domain here and there wouldn't be too terrible. Look at the depth of the tracks -- you'd need to do a massive amount of underpinning if you were to widen it sans ED. ED is a political no go, so while I agree it wouldn't be too terrible, that doesn't make it feasible 4 hours ago, Wallyhorse said: Right. Bay Ridge was always a good area to begin with. While I do understand the idea of bringing back the , I would myself as noted before if that were to be done do it by splitting the and into two separate full-time routes that would meet up at Chambers Street (with a limited number of trains at peak hours running to/from Broad), set up so there (usually, other than the peak-hour trains that continue to Broad) a train waiting at Chambers for those coming from Jamaica on the and likewise those coming from Bay Ridge on the a train waiting at Chambers. As I would do, this new version of the also eliminates the late-night shuttle since this would be a 24-hour line and except for Whitehall would make every stop the does late night. And this does...? A shuttle from Lower Manhattan to Bay Ridge, and another that *almost* gets Jamaica line passengers to fulton st helps no one. If you want more service on fourth avenue, extend the . The nassau loop is cool and all, but its existance doesn't merit its use, especially given that it fails to serve NYC's largest market -- Midtown. Also, the termination procedure at Chambers for those trains you propose sounds like....a mess. Link to comment Share on other sites More sharing options...
CenSin Posted December 24, 2017 Share #127 Posted December 24, 2017 4 hours ago, Wallyhorse said: I would myself as noted before if that were to be done do it by splitting the and into two separate full-time routes that would meet up at Chambers Street (with a limited number of trains at peak hours running to/from Broad), set up so there (usually, other than the peak-hour trains that continue to Broad) a train waiting at Chambers for those coming from Jamaica on the and likewise those coming from Bay Ridge on the a train waiting at Chambers. As I would do, this new version of the also eliminates the late-night shuttle since this would be a 24-hour line and except for Whitehall would make every stop the does late night. As noted before, your idea serves passengers from the Precambrian era. Exactly how large of a market relative to the midtown Manhattan market does this service pattern serve, and at what expense in terms of US currency, train capacity for other destinations, and operational degradation for other routes? Link to comment Share on other sites More sharing options...
Porter Posted December 25, 2017 Share #128 Posted December 25, 2017 5 hours ago, bobtehpanda said: Downtown-only Nassau St service is useless I think you misunderstood a crucial aspect of my proposal. The from Bay Ridge would not terminate downtown; it would run all the way to Metropolitan Avenue, with the returning to normal service (or otherwise using the Chrystie Street Connection for additional service into Brooklyn). Link to comment Share on other sites More sharing options...
RR503 Posted December 25, 2017 Share #129 Posted December 25, 2017 1 minute ago, Skipper said: I think you misunderstood a crucial aspect of my proposal. The from Bay Ridge would not terminate downtown; it would run all the way to Metropolitan Avenue, with the returning to normal service (or otherwise using the Chrystie Street Connection for additional service into Brooklyn). And the purpose of resuscitating an objectively less useful service pattern is...? Look, the route will be long, but it’ll be nothing compared to the , , , or lines. Get over it. As long as trains are dispatched well (ie working with conditions on the line in real time), it should be just fine. Link to comment Share on other sites More sharing options...
quadcorder Posted December 25, 2017 Share #130 Posted December 25, 2017 37 minutes ago, Skipper said: I think you misunderstood a crucial aspect of my proposal. The from Bay Ridge would not terminate downtown; it would run all the way to Metropolitan Avenue, with the returning to normal service (or otherwise using the Chrystie Street Connection for additional service into Brooklyn). I'm not sure what you understand "Downtown-only service" to mean - continuing to Metropolitan Avenue gives both Bay Ridge and Williamsburg customers downtown-only service (versus the downtown-and-midtown service provided by the and respectively) Link to comment Share on other sites More sharing options...
Wallyhorse Posted December 25, 2017 Share #131 Posted December 25, 2017 4 hours ago, CenSin said: As noted before, your idea serves passengers from the Precambrian era. Exactly how large of a market relative to the midtown Manhattan market does this service pattern serve, and at what expense in terms of US currency, train capacity for other destinations, and operational degradation for other routes? The idea is, the is in this scenario a supplement to the (except late nights when it would replace the entirely) that takes people along 4th Avenue as a local to where they can transfer to the and along 4th Avenue or the , or at DeKalb. The idea is the combined and is really one long line between 95th-Bay Ridge and Jamaica Center split into two parts: The between Jamaica Center and Chambers Street (with limited rush hour runs to Broad) and between Chambers and 95th Street, set up where it's supposed to be where going "north,", the is waiting for the at Chambers while going south, the is waiting for the . That to me solves the long-talked about problem with the on 4th Avenue. Link to comment Share on other sites More sharing options...
quadcorder Posted December 25, 2017 Share #132 Posted December 25, 2017 5 minutes ago, Wallyhorse said: The idea is, the is in this scenario a supplement to the (except late nights when it would replace the entirely) that takes people along 4th Avenue as a local to where they can transfer to the and along 4th Avenue or the , or at DeKalb. The idea is the combined and is really one long line between 95th-Bay Ridge and Jamaica Center split into two parts: The between Jamaica Center and Chambers Street (with limited rush hour runs to Broad) and between Chambers and 95th Street, set up where it's supposed to be where going "north,", the is waiting for the at Chambers while going south, the is waiting for the . That to me solves the long-talked about problem with the on 4th Avenue. How is this different from just extending the down 4 Av besides making people switch trains excessively at Chambers? Also, how do you get around the issue of fleet availability? oh also - how does this relate to the 2 Av Subway? Link to comment Share on other sites More sharing options...
B35 via Church Posted December 25, 2017 Share #133 Posted December 25, 2017 11 hours ago, Skipper said: I think you misunderstood a crucial aspect of my proposal. The from Bay Ridge would not terminate downtown; it would run all the way to Metropolitan Avenue, with the returning to normal service (or otherwise using the Chrystie Street Connection for additional service into Brooklyn). I'm trying to be objective, but the points being raised by the consensus is too potent to successfully refute.... I have to agree with them; the current is much more useful than a 4th av that would run over to Middle Village.... The combination of [having the M take on such a service pattern being proposed] & a [ revival ] isn't remotely a substitute for the current .... IMO, today's M is one of the more brilliant service alterations this agency's done in quite some time..... As far as "downtown only" service, what they're getting at is, an of sorts would not serve Midtown - not that your suggestion would terminate in Lower Manhattan.... I know you said you agreed with the old 's terminal @ Bay Pkwy being useless, but having the terminal shifted to Bay Ridge in South Brooklyn & making it a full time route, won't have it looming too much more useful within the overall network than the old service pattern.... I don't doubt that you'd get more riders south of 36th using your route (compared to the former usage along the West End), but that'll be the extent of it..... You'd just be shifting the same problem (of "downtown only" service) on the along more of 4th av.... I can fathom a large swathe of Brooklyn riders being like *yeah, thanks but no thanks for the supplemental service* - I need service past Canal st !! In laymens, your would loom more useful than the last rendition of the , but neither of the 2 is more beneficial for the network than the .... Link to comment Share on other sites More sharing options...
Deucey Posted December 25, 2017 Share #134 Posted December 25, 2017 9 hours ago, Wallyhorse said: The idea is, the is in this scenario a supplement to the (except late nights when it would replace the entirely) that takes people along 4th Avenue as a local to where they can transfer to the and along 4th Avenue or the , or at DeKalb. The idea is the combined and is really one long line between 95th-Bay Ridge and Jamaica Center split into two parts: The between Jamaica Center and Chambers Street (with limited rush hour runs to Broad) and between Chambers and 95th Street, set up where it's supposed to be where going "north,", the is waiting for the at Chambers while going south, the is waiting for the . That to me solves the long-talked about problem with the on 4th Avenue. We could just as easily run to 96th St with , express and local on Brighton, local on QBL to 71st and solve the 4th Av and reliability problems except that would still have no yard to start out from. Link to comment Share on other sites More sharing options...
R68OnBroadway Posted December 25, 2017 Share #135 Posted December 25, 2017 On 12/17/2017 at 4:50 PM, Caelestor said: Most of this map seems fine. I really like the extension to Flushing, which I think is better than the at conecting Queens with Brooklyn. Were this to be built, I'd bring back the and reroute the line back to Broad St to create a one-seat ride from Queens to Lower Manhattan, rerouting the up to 6 Ave in its place. Such a configuration would also prevent the from intersecting itself and creating an awkward route. How is this a problem? London has the Circle Line do something similar to this and it doesn't matter because nobody takes it from Hammersmith to Edgware Road via the giant loop. Link to comment Share on other sites More sharing options...
Porter Posted December 25, 2017 Share #136 Posted December 25, 2017 2 hours ago, B35 via Church said: I'm trying to be objective, but the points being raised by the consensus is too potent to successfully refute.... I have to agree with them; the current is much more useful than a 4th av that would run over to Middle Village.... The combination of [having the M take on such a service pattern being proposed] & a [ revival ] isn't remotely a substitute for the current .... IMO, today's M is one of the more brilliant service alterations this agency's done in quite some time..... As far as "downtown only" service, what they're getting at is, an of sorts would not serve Midtown - not that your suggestion would terminate in Lower Manhattan.... I know you said you agreed with the old 's terminal @ Bay Pkwy being useless, but having the terminal shifted to Bay Ridge in South Brooklyn & making it a full time route, won't have it looming too much more useful within the overall network than the old service pattern.... I don't doubt that you'd get more riders south of 36th using your route (compared to the former usage along the West End), but that'll be the extent of it..... You'd just be shifting the same problem (of "downtown only" service) on the along more of 4th av.... I can fathom a large swathe of Brooklyn riders being like *yeah, thanks but no thanks for the supplemental service* - I need service past Canal st !! In laymens, your would loom more useful than the last rendition of the , but neither of the 2 is more beneficial for the network than the .... I appreciate your point, and you're probably right. I acknowledge that I have a bias in that I used to work in FiDi and commute from Bay Ridge, and I personally would have loved such a service as I'd outlined for the . After rethinking it, I agree with Wallyhorse that it might be better to just make the a separate service south of Broad Street. It would still serve as a skip-stop service as it does today, but it would run beyond Broad Street and serve Bay Ridge during peak hours (which is when skip-stop service operates anyway). Such an arrangement would be a lot less jarring to the system than a return of the , and the could be reserved for the SAS Queens service. Link to comment Share on other sites More sharing options...
LGA Link N Train Posted December 25, 2017 Share #137 Posted December 25, 2017 2 hours ago, Skipper said: I appreciate your point, and you're probably right. I acknowledge that I have a bias in that I used to work in FiDi and commute from Bay Ridge, and I personally would have loved such a service as I'd outlined for the . After rethinking it, I agree with Wallyhorse that it might be better to just make the a separate service south of Broad Street. It would still serve as a skip-stop service as it does today, but it would run beyond Broad Street and serve Bay Ridge during peak hours (which is when skip-stop service operates anyway). Such an arrangement would be a lot less jarring to the system than a return of the , and the could be reserved for the SAS Queens service. Where are you guys getting that Blue (V)?? Aside from that, I agree with everyone that says that the is superior than the ever will be, even though it was cool at the time. Also whoever proposed the going to 4 Av whether it's to Bay Ridge or wherever, I remember making a similar proposal before coming into these forums. But making the terminate at Chambers is a bad idea (even though the Bankers Special is recreated) just split the and and Call it a day Link to comment Share on other sites More sharing options...
LGA Link N Train Posted December 25, 2017 Share #138 Posted December 25, 2017 Does anyone know how to get that blue Link to comment Share on other sites More sharing options...
B35 via Church Posted December 26, 2017 Share #139 Posted December 26, 2017 3 hours ago, LGA Link N train said: Does anyone know how to get that blue It's not in the forum emoticon listing, it was uploaded it to Imgur.... The one's Skipper's using is located at https://i.imgur.com/yD35xgl.png Link to comment Share on other sites More sharing options...
R68OnBroadway Posted December 26, 2017 Share #140 Posted December 26, 2017 6 hours ago, D to 96 St said: Yeah, the doesn't need to really come back. The only way you could realistically do it is if you reroute the up 6 Av and QB in its place, which would be possible, but I am not advocating for this. As for additional service on 4th Av... you have the for the job. However you cannot have both, otherwise the 6 Av tracks will be jammed. Option 1: The will run to/from Bay Ridge-95 St rush hrs and late nights, thus eliminating the need of running the full-time. Option 2: service will be extended down the West End Line to Bay Pkwy rush hrs, 9 Av middays, and Whitehall St other times. Option 3: Make the the express counterpart to the , running express between Sutphin-Archer and Marcy Av. service will terminate at Broad while service continues to Bay Ridge. Option 2 makes the most sense as with the , there is only a one-seat ride to Delancy, a transfer is required to go further north. The meanwhile serves as a one-seat ride to Midtown, the biggest market in NYC. Link to comment Share on other sites More sharing options...
Porter Posted December 26, 2017 Share #141 Posted December 26, 2017 7 hours ago, LGA Link N train said: Where are you guys getting that Blue (V)?? Aside from that, I agree with everyone that says that the is superior than the ever will be, even though it was cool at the time. Also whoever proposed the going to 4 Av whether it's to Bay Ridge or wherever, I remember making a similar proposal before coming into these forums. But making the terminate at Chambers is a bad idea (even though the Bankers Special is recreated) just split the and and Call it a day As @B35 via Church pointed out, it's not an emoticon on these forums. I created it by opening the original vector image of the bullet and changing the RGB hexadecimal color code to match that of the bullet. I made the background transparent, sized it to match the dimensions of the forum bullets, and exported it as a png with an alpha channel. Feel free to use it to your heart's content. This hypothetical would not terminate at Chambers Street like the old Bankers Special had done (or my formerly proposed to Staten Island via 4th Avenue). Instead, the would run the entire length from the Jamaica Center to Bay Ridge, but only during the times when skip-stop service is actually active; when skip-stop service ends, the runs to and from Bay Bridge would end as well. Link to comment Share on other sites More sharing options...
bobtehpanda Posted December 26, 2017 Share #142 Posted December 26, 2017 2 hours ago, Skipper said: As @B35 via Church pointed out, it's not an emoticon on these forums. I created it by opening the original vector image of the bullet and changing the RGB hexadecimal color code to match that of the bullet. I made the background transparent, sized it to match the dimensions of the forum bullets, and exported it as a png with an alpha channel. Feel free to use it to your heart's content. This hypothetical would not terminate at Chambers Street like the old Bankers Special had done (or my formerly proposed to Staten Island via 4th Avenue). Instead, the would run the entire length from the Jamaica Center to Bay Ridge, but only during the times when skip-stop service is actually active; when skip-stop service ends, the runs to and from Bay Bridge would end as well. Skip stop service runs for all of an hour. I really don't see what meaningful benefit this provides. Link to comment Share on other sites More sharing options...
Porter Posted December 26, 2017 Share #143 Posted December 26, 2017 1 minute ago, bobtehpanda said: Skip stop service runs for all of an hour. I really don't see what meaningful benefit this provides. Skip-stop service can be extended, then. Why not? Make it something like 5-9 in the mornings and evenings. Link to comment Share on other sites More sharing options...
quadcorder Posted December 26, 2017 Share #144 Posted December 26, 2017 1 hour ago, Skipper said: Skip-stop service can be extended, then. Why not? Make it something like 5-9 in the mornings and evenings. Why link skip-stop to the extension? Why not just extend some and trains at all times? Link to comment Share on other sites More sharing options...
RR503 Posted December 26, 2017 Share #145 Posted December 26, 2017 That'd make for an insanely long route -- 46 stops and all local. With the already running subpar headways, the extra length would just serve to aggrivate train bunching, delays, etc. With skip stop, the lose 5 and 4 stops respectively (once Myrtle/Canarsie is done, 10 and 9), so the number of stops becomes fewer, and therefore more managable. Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 26, 2017 Share #146 Posted December 26, 2017 On 12/23/2017 at 6:30 PM, Skipper said: The and would revert to their pre-2010 states, except that the would serve Brooklyn (Bay Ridge this time, ideally). If you want to bring the back, then why not make it the skip-stop partner of the rerouted ( J ) ? I suppose then it would be a ( J ) / skip-stop service instead of a / . But at least then you'd have the back and in a more useful role than in its pre-2010 configuration. On 12/25/2017 at 10:28 AM, R68OnBroadway said: How is this a problem? London has the Circle Line do something similar to this and it doesn't matter because nobody takes it from Hammersmith to Edgware Road via the giant loop. I suppose the extended to Flushing intersecting with the at the Elmhurst Ave station wouldn't be much different from the Circle Line interchanging with itself at Edgware Road, though I wonder how London Underground makes the distinction between where to catch the Circle Line at the two different locations at Edgware and how Transit would do it in this case. Though Caelestor's suggestion to make the Flushing extension the would allow it to function as a sort-of radial route, because then you've got a route that runs between Brooklyn and Queens in a more central location, goes deeper into Queens than the does and connects to more subway and bus routes in both boroughs. It would just happen to also serve Lower Manhattan. Even if you extend the to Bay Ridge via the Montague Tunnel, I think it could still function effectively as a mostly-radial route. Maybe not as well as the Rx, but still better than the . 23 hours ago, D to 96 St said: Yeah, the doesn't need to really come back. The only way you could realistically do it is if you reroute the up 6 Av and QB in its place, which would be possible, but I am not advocating for this. I agree that it should either be the OR the on Nassau St. No need for both. If the goes up 6th in place of the , then the goes with it (either as a ( Z ) or bring back for the service). Possibly also expand ( J ) / service to run for the entire duration of morning and evening rush, instead of just one hour each rush period. Link to comment Share on other sites More sharing options...
Lance Posted December 26, 2017 Share #147 Posted December 26, 2017 If you're going to run the from Jamaica-Parsons to Forest Hills, you might as well close the loop and run it from Jamaica upper to Jamaica lower. Of course, that is not a serious idea and nobody should consider running such a long-winded and meandering route. This suggestion takes two routes that work fairly well as it is and creates one extremely long and potentially delay-prone route and another that its primary ridership don't want. If the idea is to bring more service to the 4th Avenue corridor, I'd much rather extend the from its present terminal at Broad St over flipping the and lines. Link to comment Share on other sites More sharing options...
T to Dyre Avenue Posted December 27, 2017 Share #148 Posted December 27, 2017 I will agree that if the idea is to provide more 4th Avenue local service, then just extend the , or there and leave the as is. But I think the idea behind the train in this thread is to function primarily as a radial line that better connects riders traveling between Brooklyn and Queens that just happens to continue into Lower Manhattan. It probably should just terminate at Broad St then. But the more I think about how London’s Circle Line has a transfer to itself at Edgware Road and Paddington, maybe transferring from the to the at Elmhurst Ave and Broadway might not really be that big of a problem. They could just give the new platform a different name. I suppose there’s no real reason why the can’t function as a radial line between Flushing and Ridgewood and still provide direct Midtown service to Ridgewood and Bushwick riders. Link to comment Share on other sites More sharing options...
