Threxx Posted May 8, 2012 Share #51 Posted May 8, 2012 That looks VERY similar to what I was thinking, except I would do it as noted as a from Whitehall Street that would replace the as the QB train (the and would both go to 71st-Continental, the all times and the at least 19/7 if not 24/7 and to avoid any possible conga lines towards 71-Ctl, the (G)/ would rush hours also be extended to 179th Street while the during those times is express all the way). No, QBL can't handle 3 lines, local or express (without signal improvements). 179th is a capable terminal, but it's not the best idea i've heard... An amendment to this plan: Broadway Line: : Rockaway Park-95 Street, express, via Bridge. : Astoria-Coney Island, local. : Bay Parkway-Astoria, local. : 57 Street-Coney Island, to 96 St-2 Avenue when SAS is completed. 6 Avenue Line: (B)/ : Not affected. : Express, full route 179 St-21 St-Queensbridge. : Extended to 179 St, weekdays. Essex St-Metro Avenue on weekends. Crosstown: : With signal improvements, extended to Continental Avenue. 8th Avenue: (A)/ ©/ : No change. When Phase 3 of SAS is completed, if ever, a new line will run Houston St-Rockaway Park, via QBL Local. Broadway line service will return to normal, with & switching places on 4th Avenue & Manhattan. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #52 Posted May 8, 2012 Crazy Idea: Since the is a supplemental line, send the down there from WTC. Please tell me this is a joke, since it says crazy idea... In reply to Roadcrusier1: I'd just rename 63 St-Rego Park as just 63 Street. That was it's original name anyway. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #53 Posted May 8, 2012 No, QBL can't handle 3 lines, local or express (without signal improvements). 179th is a capable terminal, but it's not the best idea i've heard... An amendment to this plan: Broadway Line: : Rockaway Park-95 Street, express, via Bridge. : Astoria-Coney Island, local. : Bay Parkway-Astoria, local. : 57 Street-Coney Island, to 96 St-2 Avenue when SAS is completed. 6 Avenue Line: (B)/ : Not affected. : Express, full route 179 St-21 St-Queensbridge. : Extended to 179 St, weekdays. Essex St-Metro Avenue on weekends. Crosstown: : With signal improvements, extended to Continental Avenue. 8th Avenue: (A)/ ©/ : No change. When Phase 3 of SAS is completed, if ever, a new line will run Houston St-Rockaway Park, via QBL Local. Broadway line service will return to normal, with & switching places on 4th Avenue & Manhattan. Here, if it wasn't clear, the would take over the current , 59 St, Brooklyn-57 St, Manhattan. The would do the same for the , since the longer line should be express... In all seriousness, it would be costly to reactivate the line, but it's cheaper than building the Winfield Spur. Link to comment Share on other sites More sharing options...
Roadcruiser1 Posted May 8, 2012 Share #54 Posted May 8, 2012 Uh no. When were we ever talking about extending the or creating new subway service? There is no room for any extra subway line in Manhattan nor is there room to put the on the IND Queens Boulevard Line making the point moot, and no the will not be made express nor will it cross the Manhattan Bridge. Seriously when did this becoming a foaming contest? The simplest idea should be the one picked and that has to do with extending the , or whatever. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #55 Posted May 8, 2012 Uh no. When were we ever talking about extending the or creating new subway service? There is no room for any extra subway line in Manhattan nor is there room to put the on the IND Queens Boulevard Line making the point moot. Then the isn't extended. Other than that, where did I say anything about a new line in Manhattan? (If the is your problem, there is space for it...) Link to comment Share on other sites More sharing options...
Roadcruiser1 Posted May 8, 2012 Share #56 Posted May 8, 2012 Then the isn't extended. Other than that, where did I say anything about a new line in Manhattan? (If the is your problem, there is space for it...) There is no space for it on the IND Queens Boulevard Line. There is no room for anything. Crazy Idea: Since the is a supplemental line, send the down there from WTC. The runs nowhere near the IND Queens Boulevard Line and it doesn't run to the World Trade Center. It runs to Euclid, and there is no use for the either. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #57 Posted May 8, 2012 There is no space for it on the IND Queens Boulevard Line. There is no room for anything. The isn't on Queens Boulevard. Read my damn post! Link to comment Share on other sites More sharing options...
Tokkemon Posted May 8, 2012 Share #58 Posted May 8, 2012 Roadcruiser, shockingly, you are not always right. Carry on. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #59 Posted May 8, 2012 Roadcruiser, shockingly, you are not always right. Carry on. 'Bout time the truth was served. Quite frankly, I crunched some numbers, and the can fit on Queens Boulevard. He's saying nothing can fit like there is a serious TPH problem in the subway. Link to comment Share on other sites More sharing options...
Far Rock Depot Posted May 8, 2012 Share #60 Posted May 8, 2012 What are you talking about? The portal to connect to the Rockaway Beach Branch already exist on the IND Queens Boulevard Line. They just need to do a little bit more construction and then the ROW needs to be rebuilt, but then it is done, and what are you talking about it the being extended through Middle Village? The will be turned south of Woodhaven Boulevard. I never mentioned the M at all. The original 1929 plan had the rockaway beach line turning south on 78th St after stopping at its own platform at Roosevelt then using garfield, 65th place then fresh pond road till central where it was to merge with the bushwick ave subway branch that turned north on Myrtle (not merging with the M) untill it turns south on the RoW. Heres the map: http://www.vanshnookenraggen.com/_index/wp-content/uploads/2010/01/1929_IND_winspur.jpg The terminal platform and ramp to the QBL was mostly built. Not what portal are you refering to? is it the bellmouths around 63rd drive? Link to comment Share on other sites More sharing options...
Far Rock Depot Posted May 8, 2012 Share #61 Posted May 8, 2012 to be honest IMO, 1) IF the RB RoW ever gets reactivated chances are CBTC will be in effect on the QBL and may just allow one more line. 2) Extending ANY current line that already serves Manhattan will require a significant increase in that line's travel and run time. The creation of a "Queens Crosstown" whether it me a whole new line or utilizing an extended version of the Rock Pk train would be the most logical for 24/7 service with maybe a peak or weekday only extention to manhattan somewhere or somehow without building any new tunnels. Extending the M if its still operating to and from Metrop Ave is....well.....since most of you like to just look at maps, imagine its routing. Thats one nighmare of a run. Extending the G....same thing. And would negate the "want" for a one seat ride to Manhattan. Simple as simple is, the concept of reopening the row, and have it just connect to the QBL from the rockaways would be a big step in making the commute to midtown manhattan a little quicker and easier. and most would use the line to get to QB more than those to midtown. Link to comment Share on other sites More sharing options...
Roadcruiser1 Posted May 8, 2012 Share #62 Posted May 8, 2012 Because of constant requests about the being extended instead, the will be extended in the Rockaway map instead. Introducing the Queens Boulevard super express. The only stop the will be making is at Roosevelt Avenue to allow transfers to Manhattan, this route isn't circuitous, and the isn't a long line right now so delays would be minimal. However some digging would be required underneath the express tracks to fit the in especially at Roosevelt Avenue. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #63 Posted May 8, 2012 I never mentioned the M at all. The original 1929 plan had the rockaway beach line turning south on 78th St after stopping at its own platform at Roosevelt then using garfield, 65th place then fresh pond road till central where it was to merge with the bushwick ave subway branch that turned north on Myrtle (not merging with the M) untill it turns south on the RoW. Heres the map: http://www.vanshnook...IND_winspur.jpg The terminal platform and ramp to the QBL was mostly built. Not what portal are you refering to? is it the bellmouths around 63rd drive? This was the Winfield Spur I spoke of, the Roosevelt station shell is there, tiled & everything, just no light fixtures or track. With the work that would have to be done on the old line, it could equal the costs of building the spur line. Link to comment Share on other sites More sharing options...
Vistausss Posted May 8, 2012 Share #64 Posted May 8, 2012 The runs nowhere near the IND Queens Boulevard Line and it doesn't run to the World Trade Center. It runs to Euclid, and there is no use for the either. He didn't say the runs to WTC. He says "run it FROM WTC" in his idea. Link to comment Share on other sites More sharing options...
Roadcruiser1 Posted May 8, 2012 Share #65 Posted May 8, 2012 He didn't say the runs to WTC. He says "run it FROM WTC" in his idea. Still not possible. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #66 Posted May 8, 2012 Still not possible. Is your purpose to oppose every single idea that's not yours? He said it was a crazy idea, a joke, but yet you turn it into an unnecessary debate. Link to comment Share on other sites More sharing options...
Roadcruiser1 Posted May 8, 2012 Share #67 Posted May 8, 2012 Not really. I just stated the current situation... Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #68 Posted May 8, 2012 Not really. I just stated the current situation... But it's not just that. It's my idea and other ideas in this thread. It was the Culver situation that got the first thread locked. As it has been said, you're not always right... Link to comment Share on other sites More sharing options...
Brighton Express Posted May 8, 2012 Share #69 Posted May 8, 2012 Because of constant requests about the being extended instead, the will be extended in the Rockaway map instead. Introducing the Queens Boulevard super express. The only stop the will be making is at Roosevelt Avenue to allow transfers to Manhattan, this route isn't circuitous, and the isn't a long line right now so delays would be minimal. However some digging would be required underneath the express tracks to fit the in especially at Roosevelt Avenue. As if this couldn't get worse. You must think the MTA are billionaires or something. A project like this would take ages. Link to comment Share on other sites More sharing options...
Threxx Posted May 8, 2012 Share #70 Posted May 8, 2012 As if this couldn't get worse. You must think the MTA are billionaires or something. A project like this would take ages. Not really, it is just the connection to the Queens Blvd line that's the kicker. There are some huge trees that would have to be cut down, and the stations have to be rebuilt, but those are the major elements of any possible reactivation. Link to comment Share on other sites More sharing options...
GojiMet86 Posted May 8, 2012 Share #71 Posted May 8, 2012 And a tunnel for the connection to the Queens Boulevard line. I know there are some sort of portals on the line already built. Link to comment Share on other sites More sharing options...
Roadcruiser1 Posted May 8, 2012 Share #72 Posted May 8, 2012 As if this couldn't get worse. You must think the MTA are billionaires or something. A project like this would take ages. Then we would be back to square 1 with the or , and etc. It's one of the proposals that might be picked, and this was also the 1929 proposal. Link to comment Share on other sites More sharing options...
Trainmaster5 Posted May 9, 2012 Share #73 Posted May 9, 2012 It's wasn't that long ago that I posted in this thread yet here we are, in "Foamer's Paradise" any way. The way I understood the article it was the author's idea to use the ROW to connect the northern part of Queens with the southern part of the borough. A direct connection within the borough instead of one via Manhattan. IMO the simplest way to do that, and the cheapest, is to rebuild Liberty Junction and reconnect the Rockaway line with the existing LIRR ROW and have riders TRANSFER to the LIRR or subway on the northern end if they wished to continue toward Manhattan. I don't think the author envisioned any connection with the QB lines or a Super Express but an easier way to travel within his own borough. Since the MTA and the state are crying poverty at the moment it's my opinion that if any plan is enacted the author's plan is the only realistic one and we should focus on that right now. I'd love to see the IND Second System be built but let's be real and focus on what's possible. Just my opinion. Carry on. Link to comment Share on other sites More sharing options...
Grand Concourse Posted May 9, 2012 Share #74 Posted May 9, 2012 Because of constant requests about the being extended instead, the will be extended in the Rockaway map instead. Introducing the Queens Boulevard super express. The only stop the will be making is at Roosevelt Avenue to allow transfers to Manhattan, this route isn't circuitous, and the isn't a long line right now so delays would be minimal. However some digging would be required underneath the express tracks to fit the in especially at Roosevelt Avenue. That is basically my idea about sending the to the Rockaways, but the should still be the local with the . The via 63rd would run under the length of QB and then at Woodhaven the would replace the heading to 71st. Crazy Idea: Since the is a supplemental line, send the down there from WTC. You would just clog up QB with an extra 8th av line that's not needed. Plus what runs on the Fulton local? The is needed with the . Link to comment Share on other sites More sharing options...
N6 Limited Posted May 9, 2012 Share #75 Posted May 9, 2012 The Queens Blvd line can handle more than 2 locals, the issue is that Continental can barely turn them fast enough. If you have a 3rd local branching off to Far Rockaway, that would be fine. Link to comment Share on other sites More sharing options...
