Sign in to follow this
N6 Limited
Governor Cuomo Unveils Vision For Transformative Redesign of LaGuardia Airport
https://www.governor.ny.gov/news/governor-cuomo-unveils-vision-transformative-redesign-laguardia-airport
First Half of New Unified Terminal Structure – a $4 Billion Construction Project – to Break Ground in First Part of 2016 Via New Public Private Partnership Negotiated by Port Authority
Delta Air Lines Expected to Redevelop Its Terminals – Comprising Second Half of New Unified Terminal Structure – On Parallel Track with Port Authority Project
PHOTOS: LaGuardia Before Redesign; LaGuardia After Redesign
New Layout Designed to Reduce LaGuardia's Current Plague of Aircraft Ground Congestion and Gate Delays, and Set Stage for World-Class Passenger Experience
Governor Cuomo was joined today by Vice President Joe Biden to unveil the vision for the comprehensive redesign of LaGuardia Airport. The airport will be transformed into a single, structurally unified main terminal with expanded transportation access, significantly increased taxiway space and best-in-class passenger amenities. Construction on the first half of the new unified terminal, expected to be a $4 billion project that creates 8,000 direct jobs and 10,000 indirect jobs, will be managed by LaGuardia Gateway Partners, a new public private partnership chosen by the Port Authority of New York and New Jersey to build the project.
Construction on the first half will begin upon final approval from the Board of Directors of the Port Authority of New York and New Jersey. That approval is expected in the first part of 2016; the majority of this first half of the project is expected to open to passengers in 2019, with full completion scheduled for approximately 18 months later. The second half of the new unified terminal is expected to be redeveloped by Delta Air Lines, which has indicated strong support for the new vision, and anticipates beginning the redevelopment of its terminals on a parallel track with the LaGuardia Gateway Partners project to complete the new unified airport.
“New York had an aggressive, can-do approach to big infrastructure in the past – and today, we’re moving forward with that attitude once again,” said Governor Cuomo. “We are transforming LaGuardia into a globally-renowned, 21st century airport that is worthy of the city and state of New York. It’s the perfect metaphor for what we can achieve with the ambition and optimism and energy that made this the Empire State in the first place, and I want to thank our many partners for joining us to build the airport that New York deserves.”
Video of a presentation that details the redesign, led by Dan Tishman, CEO of Tishman Construction Company and Chair of the Governor’s Airport Master Plan Advisory Panel, can be viewed here.
Dan Tishman said, “On behalf of the advisory panel, I want to thank the port authority and the port chairman for working with us so professionally, and I want to thank the Governor for his leadership and support. For me, this has been an engaging and rewarding experience. This is our vision – this is Governor Cuomo’s vision – this is reimagining New York.”
The recommendation for a single, unified terminal is included in a sweeping LaGuardia redesign, developed by the Governor’s Airport Master Plan Advisory Panel, and released today. The report, which can be viewed here, presents the Panel’s recommendations, which will enable LaGuardia to meet the demands of the 21st century.
SINGLE, UNIFIED TERMINAL – LaGuardia’s current terminal layout, comprised of multiple, fragmented terminals (photo here), will be replaced by one main, architecturally unified terminal. This will be accomplished by demolishing the existing Terminal B building, which is operated by the Port Authority, and replacing it with a larger structure, located closer to the Grand Central Parkway, which will include new terminal space and a new Central Arrivals and Departures Hall, and will link to Delta’s Terminals C and D. This represents the western half of the new structurally unified terminal.
The eastern half of the new unified terminal will be constructed on a parallel track by Delta Air Lines redeveloping its existing Terminals closer to the Grand Central Parkway and connecting them to the new Central Arrivals and Departures Hall. Delta Air Lines is strongly supportive of this plan, and will move forward with the Panel’s recommendations in parallel with the construction schedule for the new space and Central Hall.
TERMINAL LOCATION & ISLAND-GATES – To utilize LaGuardia's geographic footprint more efficiently, the new terminal facility will be built closer to the Grand Central Parkway. The redesigned facility will also utilize an island-gate system, in which passengers access their gates via raised pedestrian bridges, high enough for aircraft to taxi underneath, which connect back to the main terminal. A rendering of the island-gate system can be viewed here
Together, the relocated terminals and island-gate system will create nearly two miles of new taxiway space. This allows for a more efficient circulation of aircraft and reduced taxi-in and taxi-out times, which will yield shorter and fewer gate delays – a dramatic difference from today’s LaGuardia. In addition, this change will produce overall reduction in carbon emissions from idling aircraft.
Following final approval by the Port Authority Board which is expected early next year, the first half of the unified terminal structure will be built by LaGuardia Gateway Partners (LGP), which was selected by the Port Authority in May 2015 following a competitive RFP. LGP is a consortium of firms with extensive experience in terminal operations, construction, design and finances, including:
  • Vantage Airport Group – Currently manages nine airports across three continents, and has transitioned 19 airports from public to private management.
  • Skanska and Walsh Construction – construction joint venture
  • HOK and Parsons Brinckerhoff – design joint venture
  • Vantage, Skanska, and Meridiam – a global infrastructure investment fund. Will provide the committed equity investment.
LGP would be responsible for designing, building, financing, operating, and maintaining the new terminal as part of a 35-year lease.
Further Recommendations from the Governor’s Advisory Panel
In addition to the unified terminal structure, the Governor’s Advisory Panel made a number of other recommendations that will complement the new facility and bring LaGuardia into the 21st century. These recommendations are summarized below, and can be found in full in the Panel’s report. The Panel’s report incorporates elements from each of the top submissions to the Governor’s master plan design competition. Those three submissions were made by Dattner Architects, PRESENT Architecture and SHoP Architects.
“We are extremely proud to have been able to contribute planning and design concepts which will transform LaGuardia Airport into a fully integrated multi-model development befitting New York City,” said Dattner Architects.
“Governor Cuomo's initiative to transform LaGuardia Airport into a unique and accessible transportation hub is key for the future of the New York metropolitan area," said ​PRESENT Architecture. "Our firm is proud to be selected as a contributor to the architecture, master plan, and transportation vision to rethink and modernize New York City’s airports."
"As Governor Cuomo has made clear, right now there is a once in a lifetime opportunity to implement a comprehensive design that will make LaGuardia Airport the truly world-class experience New Yorkers and visitors deserve," said SHoP Architects. "SHoP is proud that our ideas for an integrated terminal could contribute to solving that urgent need at this essential gateway to the city and the state."
The Panel has also strongly recommended, with the support of the Port Authority, that a Master Planner be selected by RFP to be issued within 60 days by the Port Authority to help coordinate development of the remaining recommendations, under the oversight of a new committee of the Port Authority’s Board of Directors. A summary of those recommendations can be found below.
EXPANDING TRANSPORTATION ACCESS – As part of his 2015 Opportunity Agenda, Governor Cuomo proposed creating an AirTrain option that directly connects LaGuardia to the New York City subway and Long Island Rail Road at Mets-Willets Point Station. The panel supports the Governor’s call for this AirTrain option, and the new LaGuardia’s unified terminal will be designed to incorporate a future AirTrain terminal.
The Panel recommends that the airport once again be made accessible by ferry service. The panel also calls for an enhanced road configuration to improve passenger access and reduce traffic on local streets in the airport’s vicinity, including the Grand Central Parkway.
The interior of the new unified terminal will also be intuitive for passengers to easily navigate, and will facilitate efficient movement throughout the airport. A transit option to move passengers more quickly within the airport is recommended by the Panel, such as a tram or monorail, to be included as construction moves forward. This transit option would also better integrate the Marine Air Terminal (Terminal A) with the rest of the airport housed in the new unified terminal.
IMPROVING PASSENGER EXPERIENCE – Taking into account the realities of post-9/11 air travel, the Panel recommends that the new unified facility contain additional space for security check-in, which will help diminish wait times for passengers as they pass through mandatory TSA screening. The facility – both in its individual terminals and the central hall – will also be built with significant height and openness in order to allow for a superior passenger experience, clearer signage, greater use of natural light and overall aesthetic improvements. The central hall will also be designed with space for best-in-class passenger amenities in retail, dining, and business and conference center capabilities, as well as the option to include a 200-room boutique hotel option convenient for travelers.
INCREASING STORM RESILIENCY – During Superstorm Sandy, approximately 100 million gallons of saltwater flooded the airport and shut it down for two days, impacting 250,000 passengers and causing an estimated economic loss to the region of roughly $108 million. With this in mind, the Panel recommends elevating critical infrastructure in order to keep the airport operational during a flood event and better prepare the airport for similar extreme weather events.
SUPPORTING SURROUNDING COMMUNITIES – The redesign of LaGuardia is vital to transforming the airport into a 21st century facility and maintaining economic competitiveness throughout the region – but it is also important for the airport to be a good neighbor to its surrounding communities. Currently, the neighborhoods in the immediate vicinity of LaGuardia experience significant automobile traffic on local roads and the Grand Central Parkway from passengers either parking outside of the airport’s ground or from motorists waiting to pick up passengers from the airport as they arrive. Under the new design plan, the Panel recommends increasing parking options on-site and identifying a location for a cell phone waiting area in order to reduce congestion on local streets. Additionally, the Panel also recommends a new rental car facility be created to concentrate the ten car rental companies that currently serve LaGuardia from multiple dispersed locations, further reducing congestion.
The Panel has recommended that the Port Authority will ensure that the project’s employment reflects a broad spectrum of the communities in the region, and should recognize Governor Cuomo’s goal of 30 percent MWBE participation. It will also build on the Port Authority’s longstanding commitment to supporting Airport Concession Disadvantaged Business Enterprises (ADCBE).
Currently, LaGuardia contributes more than $16 billion in economic activity to the region annually, generating about 121,000 total jobs and $5.9 billion in annual wages
Senator Charles E. Schumer said, “LaGuardia is one of New York’s greatest assets, and it’s time that we make the big investments needed to bring it up to speed for the 21st century. By redesigning the airport from top to bottom, this plan gives New Yorkers the facilities that our city and our state deserve. I’m glad Governor Cuomo and the Port Authority are stepping up on this huge infrastructure project, and look forward to seeing it move aheadý."
Senator Kirsten Gillibrand said, “LaGuardia is a vital hub for driving commerce in New York – both by connecting the local and global economy and brining in millions of visitors every year to the Empire State. By reimaging, remodeling and rebuilding LaGuardia’s infrastructure to meet 21st century standards, this investment will meet the critical need to support the future growth of the region and all of New York State.”
Congressman Joe Crowley, whose district includes LaGuardia Airport, said, “The modernization of LaGuardia Airport is long overdue and I’m thrilled it will soon be undergoing a comprehensive overhaul that will bring it into the 21st century. Our first-rate city requires an equally first-rate airport to welcome visitors, and New Yorkers will soon have one they can be proud of. Not only will it become a better-looking, better-equipped, and more efficient airport, but the development will have a tremendous economic impact in Queens with the creation of thousands of new jobs. I thank Governor Cuomo for making this a top priority of his administration and I look forward to seeing this once in a lifetime project take off!”
New York City Mayor Bill de Blasio said, "Bringing LaGuardia Airport into the 21st century is critical to keeping New York City competitive. This is a gateway to New York City and the region for millions of tourists and businesses. I applaud Governor Cuomo and Vice President Biden for undertaking a revitalization of LaGuardia that promises to drive growth across the region and dramatically improve service for passengers."
Former New York City Mayor Mike Bloomberg said, “Access to best-in-the-world transportation infrastructure is crucial to growing a diverse and successful economy. As the gateway to New York for people from around the world, it’s crucial that we redesign LaGuardia Airport with that in mind. I am excited to see Governor Cuomo moving forward with a bold plan to bring about a new LaGuardia, and can’t wait to see it come to fruition.”
Global Gateway Alliance Chairman and Founder Joseph Sitt said, "Global Gateway Alliance has long advocated for smart investments in modern airport terminals, the timely redevelopment of the Central Terminal Building, increased access via public transportation, the addition of modern amenities and increased passenger capacity. So, today’s announcement by Governor Cuomo and Vice President Biden is a win for these efforts, and an important step in bringing New York’s airports into the 21st century. More important, it's a win for the more than 117 million annual passengers that use our airports, and for a regional economy that relies on the airports for more than $50 billion in activity. In the coming weeks and months, we look forward to a public process and the unveiling of specific timelines to realize today's vision and enable New York-area airports to compete with major airports across the country and the world.”
Ed Bastian, President of Delta Air Lines, said, “Delta commends Governor Cuomo on his airport reconstruction plan, which will transform not only the New York City travel experience but also the landscape of the city itself. Delta has invested more than $2 billion in infrastructure upgrades and passenger enhancements at our hubs at LaGuardia and JFK, and the initiatives announced today are aligned with our ongoing commitment to providing an exceptional experience for anyone traveling through New York for business or pleasure. We look forward to working in partnership with the governor’s design commission on a comprehensive and complementary redevelopment plan that realizes our mutual goals and benefits all New York passengers.”
Richard Anderson, President of the New York Building Congress, said, “For New York to maintain its global prominence and success, our leaders must be willing to make major investments in the infrastructure that underpins our economy. The Governor’s plan to reinvent LaGuardia Airport for the next century does just that. While others around the country are struggling to cope with our nation’s growing infrastructure needs, Governor Cuomo’s vision for a new LaGuardia shows that New York can rise to the challenge.”​
New York State AFL-CIO President Mario Cilento said, "LaGuardia Airport is crucial to the region's economy. We commend the Governor for making the redesign possible. This is a huge construction project that will create good, prevailing wage jobs with benefits for all airport workers, and our union brothers and sisters. It will help grow the middle class both in New York City and in the surrounding communities. This is exactly the type of shot-in-the-arm we need for working families and our economy as a whole."
Robert Caro, award-winning historian and author of The Power Broker, said, “To say we’re going to take it from being a “third-world airport” to being one of the greatest and newest airports, if you think about it, that’s quite a heroic vision. It’s not an improvement, it’s a transformation – and it’s a transformation that of course New York needs. Just as the first LaGuardia airport took New York into the modern age of the 1930s and ‘40s, now we have this new airport which will take New York into the 21st century.”
Kenneth T. Jackson, Director of the Herbert H. Lehman Center for the Study of American History and the Jacques Barzun Professor of History and the Social Sciences at Columbia University, said, “We will have an airport that we can be proud of and say is worthy of the greatest city in the world. I think the idea that it is a comprehensive project, it is a master-plan project, an ‘everything will fit together’ project – I think that initiative by Governor Cuomo is very, very important.”
UPDATE ON JFK, STEWART AND REPUBLIC AIRPORTS
RFP to be issued for Master Planner for JFK Redesign
In addition to the redesign plan for LaGuardia Airport, Governor Cuomo also provided an update on the status of efforts to revolutionize and modernize JFK, Republic and Stewart Airports.
JFK International Airport – JFK is one of the few international airports without an on-airport hotel. Governor Cuomo announced today the construction of a new state-of-the-art hotel at JFK in the historic TWA Flight Center, which was designed by world-renowned architect Eero Saarinen. The hotel will include 505 guestrooms, 40,000 square feet of conference, event, and meeting space, and a 10,000 square foot observation deck. The hotel will also be LEED certified.
The redevelopment of JFK’s TWA Flight Center Hotel will move forward under a public-private partnership between MCR Development, JetBlue and the Port Authority of New York and New Jersey. The $265 million construction project, which is expected to break ground next year, will generate 3,700 jobs, and is expected to open in 2018.
"The TWA Flight Center Hotel will celebrate and preserve Eero Saarinen’s masterpiece, returning the landmark to its original glory and reopening it to the public,” said Tyler Morse, CEO of MCR Development, the New York-based developer responsible for the TWA Flight Center redevelopment plan. “The TWA Flight Center Hotel will be an economic engine and a world-class airport hotel, creating approximately 3,700 construction and permanent jobs, 505 new hotel rooms, and 40,000 square feet of meeting space at JFK. Whether staying the night or simply exploring, international visitors and New Yorkers alike will be able to experience the magic of the Jet Age in this extraordinary mid-century icon. We are proud to play a part in Governor Cuomo’s effort to revitalize New York’s airports for generations to come, and we look forward to working with all of the carriers at JFK to realize this vision.”
"We are thrilled the TWA Flight Center will come alive again," said Rich Smyth, Vice President of Corporate Real Estate, JetBlue. "Saarinen’s aviation icon sits at the front door of our flagship T5 terminal, offering exciting collaboration opportunities that will benefit our customers and crewmembers. As New York’s Hometown Airline, we are proud to be a minority investor in MCR's plan, which celebrates the landmark’s rich history while returning it to public use. We want to thank Governor Cuomo for his leadership in supporting our long-held belief that the TWA terminal can viably be restored and re-opened."
The Governor also announced today plans to move forward to develop a full master plan for future development at JFK airport. The Governor has directed the Advisory Panel to report back in the next twelve months with its recommendations for an implementable master plan for the development of a 21st century JKF International Airport. Within the next 60 days, the Panel will work with the Port Authority to issue an RFP to retain a master planning firm to advise the Governor, the Panel, and the Port Authority on the future development of the airport.
New RFIs for Republic & Stewart – Empire State Development has issued new RFIs with a primary focus on enhancing the regional economic activity at both Republic and Stewart International airports. Specific sites have been identified for future development, and ESD will guide the development of these sites via a new real estate broker: Newmark Knight Grubb Frank.
Additional news available at www.governor.ny.gov
New York State | Executive Chamber |press.office@exec.ny.gov | 518.474.8418
______________________________________________________________________
Sounds interesting, no additional runways? (not enough airspace?)
Share this post
Link to post
Again with this AirTrain nonsense?
Have an extension of the N via Astoria Blvd to the Airport. Have a shuttle and some N trains serve Ditmars.
  • Upvote 1
Share this post
Link to post
The elevated cannot run above the Grand Central Pkwy because it would be in the way of air traffic due to runway placement.
  • Upvote 1
Share this post
Link to post
As long as the Port doesn't raise the PATH fare and the JFK Airtrain fare to pay for this I'm all for it.
As for JFK, only T2 and T7 need to be torn down and rebuilt, the other terminals are fine as they are imo.
Share this post
Link to post
The Q70 will still be faster and cheaper, assuming they don't change it when the AirTrain opens (if it will be built).  :mellow:
Building it to Willet's Point is such a round-about route, though.
Share this post
Link to post
Yes. And it must be like that! Airtrain is okay enough. The (N) can stay at Ditmars.
Well it's about damn time! Now let's get to JFK next!!!
Damn right!
Share this post
Link to post
i would build the subway to LGA who cares what the nimbys say  if they don't like they can get out of the way!
The (N) and (W) should to LGA and screw the nimbys the feds in to step in.
  • Upvote 2
Share this post
Link to post
Its time to think beyond the Astoria line, and just build a new commuter and/or subway line to LGA direct from midtown.
Share this post
Link to post
An AirTrain or the LIRR would be more attractive.  Businessmen are not going to use the subway.
Why? Aside from the US Open and a maybe Mets game, I can't picture the Willets Point station being used full time.
Share this post
Link to post
We're talking about LGA correct? If so because if businessman are going to use public transit with any regularity it wouldn't be a subway.  Those types of people would use the LIRR or AirTrain.
Edited by Via Garibaldi 8
Share this post
Link to post
Yes, I was talking about the proposed Air Train from LGA to Willets Point. The LIRR doesn't even stop at Willet's Point unless there's Mets game or the US Open.
Share this post
Link to post
I'm talking about travel to and from LGA period.  There should be an LIRR train and an AirTrain to accommodate those commuters.  They're not going to take the subway.  These are individuals that I usually see waiting for taxis like myself when going to business meetings/meeting clients, etc.
Share this post
Link to post
But those Businessmen are going to have to put up with the subway because the MTA isn't going to send the LIRR out LGA. They're just going to build the AirTrain, unless Governor Cuomo changes his mind and suddenly decides he wants LIRR extended to the airport.
Share this post
Link to post
So then they'll use a taxi that's all.  My point was if you want those types of folks to use public transit (excluding taxis), subways won't do it.
Share this post
Link to post
VG8, I see what you're saying, which is correct. Lets wait until the Airtrain's built from Willets Point to LGA, that way riders can have easier access to the (7) . They should extend it so it can be from
(JFK) LGA
(JFK) Willets Point
(JFK) Woodside
(JFK) Rego Park
To make it easier to go around Queens, it can be built underground after Willets Point. From LGA To Rego Park should be good. It can give you access to your (E)(F)(G)(M) and (R) trains around Jackson Heights, Corona, Elmhurst, and Queens Blvd.
Share this post
Link to post
(JFK) LGA
(JFK) Willets Point
(JFK) Woodside
(JFK) Rego Park
Aside from that, I don't see how the (7) can handle any more crowding.
Share this post
Link to post
The (7) is only crowded during rush hours, it can handle itself well during middays.
Share this post
Link to post
I beg to differ.  I've used the (7) during middays and it was quite crowded.  My colleague gets motion sickness, otherwise I would've taken the QM4 to go to a business meeting out in Queens.  Would've been a much more comfortable and civilized ride.  Instead I dealt with a packed (7) train (going and coming) and the "lovely" Q44.  <_<
Share this post
Link to post
(JFK) LGA
(JFK) Willets Point
(JFK) Woodside
(JFK) Rego Park
If they could extend it down the GCP or VWE to Jamaica, that would be nice.
Share this post
Link to post
(JFK) LGA
(JFK) Willets Point
(JFK) Woodside
(JFK) Rego Park
This should be the way the LGA Airtrain SHOULD run, but of course, the authorities might take the cheep way and just make it stop at willets point, and maybe even flushing.
Share this post
Link to post
