CBTC - General Discussion
Jcb
On 3/11/2020 at 10:39 AM, Lex said:
Because he's the one to blame for it...
59 minutes ago, T to Dyre Avenue said:
The City Council Speaker makes transportation policy in this City now? That’s news to me. Wouldn’t de Blasio and his DOT commissioner, Polly Trottenberg, be to blame for that since it’s DOT that makes the City’s transportation policy? Even then, I wouldn’t say they’re entirely to blame for why we’re expanding the subway slower than a snail’s pace. What about absurdly high construction costs?
Personally, I wouldn't engage with people who have a history of spewing nonsense.
Some characters on these forums are best off left alone.
  • Replies 390
As far as transfers to Jamaica and cars that will be running on the QBL when CBTC begins. It is obvious that the (E)(F)(R) will be full 10 car R160s running out of Jamaica yard some of which came from CI. In regards to the (M), will the (L) and (M) share ENYs CBTC fleet of R143s and R160s making the (M) partially R143s as well as R160s?
I think someone said before that they can’t share because the two kinds of cbtc aren’t compatible
22 minutes ago, happy283 said:
What two kinds? This is the first I'm hearing of this.
The R143s used for (L) service have an earlier generation of equipment than what is being used for more recent projects, which includes Queens Boulevard. Their replacements won't have this issue, but it's far too early to talk in-depth about that matter.
It may extend to the R160s used for (L) service, but I'm not certain. Someone else will have to answer that.
  • 3 months later...
Since the (L) was the first CBTC project, it uses an old system that (MTA) does not want to use on other lines since there is no sufficient back up signaling system in case CBTC goes down, if memory serves me correctly. The (7) uses a newer and improved version of CBTC by another company that has a backup signal system installed.
However, this does raise a question as to what (MTA) will do with the Carnarsie-CBTC equipped R160's since they won't be compatible with QBL-CBTC.
The potential overlap is limited to potential sharing of the 8 car 160s between the (L) and (M) . Does the (M) currently have any ENY based 160s?
As far as storage goes, Fresh Pond is like Canarsie, which serves as an ancillary facility for East New York.
Make of that what you will.
To my understanding the (M) shares the R160 fleet from Fresh Pond Yard and ENY, and ENY has the Canarsie-CBTC equipped R143's and R160's.
And the (M) has ran R143's before recently.
Edited by Lawrence St
The CBTC R160s were fairly common on weekdays and occasionally on the weekend (M) to 96th Street. You're more likely to see one on the (J)(Z) however.
well... that R143 was from the (J) to Metropolitan G.O. the weekend before
The R143 I am thinking about is the one that ran the full (M) route, I think the (L) had a G.O that day.
  • 3 months later...
So this is a picture I found online, would this basically confirm that NTT's need to be running on the (G) soon? If so, would that mean that all the R160's that still remain at Coney Island Yard are going to be used for the (G) and have the (G)'s equipment used for (N)(Q) and (W)? Obviously, not the (B) since they usually get extended into the Bronx used as storage in Concourse. Also, would this also confirm that R211's would be assigned on the (G) as well?
Edited by Vulturious
Not necessarily. What likely could be going on is that CBTC is going on just south of Church Av (right after the (G) train diverges into the storage facility) and the (F) would just cross back over just north of Ditmas Avenue.
correct me if I’m wrong but the CBTC installation for the (F) route is only going to be from Kew Gardens/Union Turnpike (eventually Jamaica 179 St) to 21 St Queensbridge, and then Just south of Church Av to West 8 St
Edited by darkstar8983
Do the NIS deadhead (G) trains from CIY need to have CBTC installed as well?
Thats actually a good question. I assumed that non NTT trains could still travel through the line, just like a work train would normally do in CBTC territory on the (7) and (L) lines, but the exact nature of the protocols necessary to facilitate such moves I don't really know. It is important, now that you are going to have CBTC-only lines (Queens Blvd, eventually 8 Av) and the potential for reroutes of non-CBTC rolling stock in the event of a disruption.
I don't remember hearing anything about Kew Gardens/Union Turnpike getting CBTC, then again I could be wrong, but you are right about CBTC south of Church to West 8th. However, even with that, that would mean they would have to switch off CBTC in order to allow deadheading (G) trains through to Coney Island, at least from what I've heard about how they allow non-CBTC trains through. I don't know exactly how frequent NIS (G) trains deadheading to CIY are since I don't live by the (F) to really know nor have I taken the (F) long enough to really know either, but I think if it does happen occasionally, I think that would just be a hassle to turn CBTC off and on again just for that.
CBTC Will be in effect from Kew To 21st street or Queens Plaza when ready..
Right now the CBTC test train is only running in full CBTC mode from Kew to Roosevelt..
Two trains per day are running in a form of CBTC...
Most G lay Ups are along B3/4 track so that wont effect any CBTC train on B1 or B2 track...
My bad, I did not read the last bit about 21st St-Queensbridge, I thought he meant towards Jamaica which I wasn't aware of. Although, I am aware of QBL CBTC, but when you say B3/4 tracks, you mean the layup tracks at Church Avenue? Even then, they still need a way to get to Coney Island regardless.
B3/4 track=Middle track
All CBTC lines allow non-NTT trains to use them in AWS mode, the legacy automatic block system. Its just a severe capacity restriction to have an AWS train on the line unless its 20 min headways overnight.  AWS is automatic block, but 1-2 mile long blocks. 1 signal head ever 2-3 stations or only at interlocks. Similar to WMATA's wayside signals which is red (no go), flashing white (proceed only if cab signals workings), white (clear to next interlocking, no cab signals needed).
QBL CBTC is vendor independent and has a vendor independent (in theory lol) SCADA system. 7 and L's dispatching software/user interface is specific to Thales and Siemens. Minor radio packets, axle counter, and accel/brake curve calculations (in terms of staying to timetable in ATO) differences exist between 7/L/QBL but nothing about QBL's design prohibits trains from being OTA back compatible onto 7/L's protocol.
L uses a higher resolution but less reliable (MTBF) axle/rotation counter and less bailses. 7 has a cheaper axle counterbut higher MTBF and more bailses to recalibrate it. QBL will use 7 line's high bailse count design.
Edited by bulk88
design diffs
So if I'm understanding this correctly, a train equipped for QBL can theoretically run on the 7/L's CBTC but a train equipped for the 7/L can't run on QBL?
Correct. Grapevine says 7 line's software can never deal with variable length or variable weight consists (Thales equipment) on any TA in the world. Siemens/L deals with variable length/coal trains under CBTC. QBL's OTA protocol will be Siemens's spec, Thales SKUs will always talk Siemens OTA even if Thales Zone controller to Thales VOBC if I read the PDF correctly.
Hint, regardless of technical superiority, MTA will be loyal to Siemens since Lex/7 Ave ATS was a Siemens product, and that was MTA's 1st attempt at fake CBTC since the TImes Square shuttle.
Edited by bulk88
siemens
  • 1 month later...
6 hours ago, Emil said:
this is random but I know this is the correct thread, when would 8th avenue CBTC start? there has been so much construction this part weekend I'm thinking it's for CBTC. I'm probably certain it's delayed and such.
Aren't they still working on QBL CBTC? Regardless, 8th Av is going to need the R211s to arrive before they can start on construction since there isn't enough to really run CBTC and it would basically be useless.
